Polycarbonate sheet
Problems with removing protective covering
Jonathan Garside14/02/2017 13:42:04
52 forum posts
I have some sheets of Beyer Makrolon 6mm polycarbonate which has been stored in cold conditions for some years.
I now find that the protective covering which should peel off has deteriorated to the extent that it will not peel off and only comes off in very small pieces.
I have tried heat both with a hair dryer and also flame but to no avail. I have also tried thinners which was brilliant at wiping off the print on the covering but nothing else. I have tried a scraper but without success.
Does the collective knowledge of forum members have any valid suggestions for speedy removal, or am I consigned to several days work in picking very small pieces off the sheets and rapidly going mad?
yours in hope
Jonathan
Dave Daniels14/02/2017 14:01:19
87 forum posts
You might try something like 'Label Off' spray.
I get it from Rapid Electronics but no doubt similar stuff is available elsewhere.
Fairly benign, I've used to to get the damn sticky labels of plastic stuff many times and it does not seem to affect them.
D.
https://www.rapidonline.com/kontakt-chemie-208106091230-label-off-50-label-remover-200ml-87-0655
Edited By Dave Daniels on 14/02/2017 14:03:22
Michael Gilligan14/02/2017 14:04:37
23121 forum posts
1360 photos
Jonathan,
I can't vouch for its suitability for your unusual requirement, but: The 'sticky label remover' aerosol, sold by Maplin [and made, I think, by Servisol] is my first choice for removing sticky stuff.
Looks like Dave is of similar mind, and beat me to the post.
Edited By Michael Gilligan on 14/02/2017 14:06:20
Vic14/02/2017 14:11:53
3453 forum posts
23 photos
You don't say how large the piece is, can you soak it in hot soapy water?
mark smith 2014/02/2017 14:17:58
682 forum posts
337 photos
Sticky removers wont penetrate the plastic film. I sympathize with you, around 10 years ago i bought a conservatory for self build. After building the dwarf walls , I got waylaid erecting it for 2-3 years and when it came to fitting the polycarbonate roof sheets , the plastic film had deteriorated and would only come off in small pieces. Nothing i tried helped ,took ages to remove it all.sad
Edited By mark smith 20 on 14/02/2017 14:18:49
Edited By mark smith 20 on 14/02/2017 14:19:31
Dave Daniels14/02/2017 14:26:39
87 forum posts
Doesn't have to penetrate ... I've used it to get adhesive heat shrink off. If you can get an edge it appears to creep in and destroy the bond.
Not a quick job I admit, but it worked.
Relatively cheap to try it. If it doesn't work you still have the can for attacking sticky labels.
D.
Michael Gilligan14/02/2017 14:59:51
23121 forum posts
1360 photos
Posted by Dave Daniels on 14/02/2017 14:26:39:
Doesn't have to penetrate ... If you can get an edge it appears to creep in
+1
I used it recently to gently lift the aluminium-foil labels from a set of Hellerman sleeve-expanders.
The labels were peeling at the edges, but very well stuck elsewhere ... patience and the spray allowed me to lift them cleanly [to keep the product details for reference, in case anyone wonders why].
Edited By Michael Gilligan on 14/02/2017 15:09:58
Neil Wyatt14/02/2017 15:11:28
19226 forum posts
749 photos
86 articles
What about buying some cheap Fablon or similar and sticking that onto the protective film they may peel off together?
Jonathan Garside14/02/2017 15:31:40
52 forum posts
Vic
The sheets are approx 4' x 4' and 5' x 5' so too big for a washing up bowl.
Dave and Michael The film is not glued on so I suspect sticky label remover would remain ineffective.
Mark I suspect my experience is likely to mirror yours and days in the shed being bored and frustrated loom large on the horizon
It would appear that the film has lost its flexibility with age.
Thanks all for your ideas but I will wait a little longer in case the magic bullet answer arrives.
Jonathan
Muzzer14/02/2017 15:48:46
2904 forum posts
448 photos
Pressure washer?
And incidentally, I noticed yesterday that Lidl are selling label remover, rust stain remover etc at the moment. IIRC, they were £2 for around 100ml, whether or not they are any good in this instance.
Edited By Muzzer on 14/02/2017 15:50:50
John Haine14/02/2017 15:56:57
5563 forum posts
322 photos
I recently bought a piece of 4mm polycarbonate for a chip guard on my mill so the new blower doesn't spread chips round the workshop. I bought it from these people - highly recommended:
May be worth giving them a call to see if they could advise?
Brian Oldford14/02/2017 16:08:59
686 forum posts
18 photos
You have to balance the value of your time to that of new polycarbonate. If it looks like it's going to take forever buy some more polycarbonate sheet and scrap the old stuff. As I've got older, despite retirement, my time get more and more valuable.
Michael Gilligan14/02/2017 16:23:09
23121 forum posts
1360 photos
Posted by Jonathan Garside on 14/02/2017 15:31:40:
Jonathan,
Yes, I understand that ^^^
The hope was that the spray would 'wet' the surfaces more effectively than other options.
It appears that the film is polyethylene and normally adheres by molecular attraction, or some-such [yes, I'm way out my depth here] ... But; it seems likely to me, that the film has been degraded by exposure to U.V. and will therefore be crazed with fine cracks.
Do please let us know how you get on.
P.S. This is the nearest I can find to supporting evidence for the film being polyethylene:
8) Protective masking film
All Areco Poly sheets are supplied with a polythene film on both sides and tape on both ends to protect the sheet during transit and installation.
... of course, other products may vary.
not done it yet14/02/2017 17:21:45
7517 forum posts
20 photos
The same thing happens to items like double glazing units covered in it, too. Even some masking tapes can become a nightmare to remove, if left on and exposed to light. BTDT on both counts! Get the protective film of fascia boards, and the like, as well.
This thread reminds me I have three sheets of damaged acrylic. I had better sort them, or probably scrap them.
Sam Stones14/02/2017 19:30:25
922 forum posts
332 photos
Hi Jonathan,
I'd be concerned about the chemical resistance of PC.
Some chemicals (stress-crack agents) could ruin your PC and your day.
Take a look here -
https://en.wikipedia.org/wiki/Polycarbonate#Properties_and_processing
Sam
Vic14/02/2017 19:58:45
3453 forum posts
23 photos
Don't discount PETG. Very tough and cheaper than Polycarbonate the last time I bought some.
Martin 10014/02/2017 20:00:31
287 forum posts
6 photos
Leave it out in the sun and let the UV do the work. It might take a few months.
The adhesive heat shrink mentioned above only needs a suitable alcohol like IPA to rapidly degrade. Hot melt glue releases in the same way in a few seconds.
john carruthers15/02/2017 08:55:57
617 forum posts
180 photos
We used a lot of polycarbonate sheet for security screens and safety aplications, yes it can be a swine to peel.
It seemed to be certain batches just would not peel off.
We tried a hot air gun and various solvents, eventually we gave it to the aprentice to do in the nice warm shop on a bench instead of standing in a gale on the end of Deal pier :-/
Jonathan Garside15/02/2017 09:49:12
52 forum posts
Oh for an apprentice! But how did he do it?
john carruthers15/02/2017 14:04:00
617 forum posts
180 photos
He sat and picked away at it for hours, and was soundly thrashed if he scratched the surface.
Ours was GE 'Lexan' I believe.
Edited By john carruthers on 15/02/2017 14:04:24
