Looking for a 1/4" ratchet
John Stevenson08/02/2017 22:05:42
5068 forum posts
Not a 1/4" drive as such I want a hollow ratchet with 1/4" hex hole in it so I can directly drive the 1/4" replaceable screwdriver and allen key tips.
Sure I have seen one but as soon as you type in 1/4" drive you get every socket set supplied by man and beast.
Any clues ??
This is for getting in some real tight spaces.
[EDIT]   Got the 1/4" square ratchets where you have an adapter from square to hex but this makes the overall high too great.
Edited By John Stevenson on 08/02/2017 22:08:11
Nick_G08/02/2017 22:16:44
1808 forum posts
744 photos
Do you mean like a 'normal' ratchet but instead of a 1/4" sq male drive sticking out the ratchet has a female 1/4 hex socket.?
Nick
Edit :- if so https://www.amazon.co.uk/BERGEN-Female-Ratchet-Spline-BER4077/dp/B00OBFG6VM
Or
https://www.amazon.co.uk/d/Home-Kitchen/Sealey-AK6962-Driver-Ratchet-Stainless/B00K1UNJ52/ref=pd_bxgy_60_img_2?_encoding=UTF8&psc=1&refRID=QPW3A78BEWFB41JJ4VHH
Edited By Nick_G on 08/02/2017 22:23:36
John Reese08/02/2017 22:23:55
1071 forum posts
Does Amazon serve the UK? They list several.
Andy Holdaway08/02/2017 22:24:27
167 forum posts
15 photos
John, here's one but it's a bit pricey. I bought a really cheap one a few years ago from Lidl but haven't seen them since.
Andy
edit: Nick beat me to it, although it's a different one.
Edited By Andrew Holdaway on 08/02/2017 22:25:42
Les Jones 108/02/2017 22:35:53
2292 forum posts
159 photos
I found this one on ebay. And also this one.
Les.
Michael Gilligan08/02/2017 22:38:36
23121 forum posts
1360 photos
Maplin does [or did] one by Pro'sKit
"Offset Ratchet & Socket Driver Set"
1PK-202A (Metric Size)
1PK-202B (Inch Size)
Same ratchet, different sockets
Has 1/4" square male one side and hex female t'other.
Alan Waddington 208/02/2017 22:47:03
537 forum posts
88 photos
I've got a couple of Teng ratchets like you are describing, but they come in small sets with a range of 1/4 bits £30 or so, well worth the money,, great quality, lifetime guarantee. They do a couple of variations, but the difference is the bits rather than the ratchets.One of my sets has sockets up to 13mm and a hex to square adapter to mount them to the ratchet.
http://www.ebay.co.uk/itm/Teng-TM029-29pc-ratchet-1-4-screwdriver-socket-bit-set-Pz-Ph-Slot-Tx-Tpx-Rob-Hx/262380325394?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3Df1a1b8cc7d7c4f5a8f78857fb7e4ad1e%26pid%3D100338%26rk%3D1%26rkt%3D15%26mehot%3Dag%26sd%3D291446632415
Edited By Alan Waddington 2 on 08/02/2017 22:53:35
Michael Briggs08/02/2017 22:48:38
221 forum posts
12 photos
Hello John,
I can recommend this Wera reversible ratchet, sold as a set here but you can get the ratchet for about £20, top quality, as reflected in the price. The overall length of the ratchet is 87mm or 79 mm from the centre of the hex socket to the end of the handle:
Regards, Michael
duncan webster08/02/2017 22:59:16
5307 forum posts
83 photos
from the 'well known auction site'
you can also getsets of ratchet spanners for about the same price, no idea on quality
peter walton08/02/2017 23:28:41
84 forum posts
Hi John,
Try this **LINK**
Good quality and small in size.
peter
Mike Poole08/02/2017 23:45:12
3676 forum posts
82 photos
Search fo Bahco 2058s26, I have this set as it fits in your pocket and was handy when I used to go to work, in fact it is still handy even though I don't work any more.
John Stevenson09/02/2017 00:47:44
5068 forum posts
Mike, are the sockets 6 sided or 12 sided.
I know I didn't ask but it's for another application
peak409/02/2017 02:04:57
2207 forum posts
210 photos
John, I've been using one of these for a while now, quite compact, and got me out of various difficulties.
Mine came from Clas Ohlson in Doncaster for about a tenner, but sadly they've now closed.
I should be able to sort you out some close up photos and measurements if you need them, just let me know.
For other readers, these are on offer at Aldi at the moment, probably too big for John's application, bit worth investigating for other uses; I find them quite handy on the motorbikes.
Bill ( the ugly bugger with the beard and the 3/4 flute core drills @ Doncaster last year)
Nicholas Farr09/02/2017 06:48:09
3988 forum posts
1799 photos
Hi John, here's another **LINK** and **LINK**
Regards Nick.
JasonB09/02/2017 07:27:44
John just put "1/4 hex ratchet" into your favorite search engine rather than 1/4 frive and you will get loads of them , Wera are OK, though I use one like this
Edited By JasonB on 09/02/2017 07:29:28
mgnbuk09/02/2017 07:39:11
1394 forum posts
103 photos
I use a Wera 8001 1/4" ratchet bit driver, like this :
RS Components used to sell them (where I got mine from), but I can't find it now with their hopeless search engine.
It is very small, but beautifully made & gets into very confined spaces - it has got me out of trouble on many occasions. Not cheap, but very worthwhile.
Nigel B
Neil Wyatt09/02/2017 08:07:26
19226 forum posts
749 photos
86 articles
You need to search 1/4 ratchet spanner John
www.ebay.co.uk/itm/5pc-SAE-Ratchet-Spanner-Set-1-4-7-8-inch-Ratchet-Ring-Spanners-Wrench-Set-UK-/252187895083
JasonB09/02/2017 08:10:17
Neil problem withusing a ratcheting spanner is that don't have any means to retain the screwdriver bit so it either drops out also you can't apply any pressure to it to keep it in the screw head as the spanner just slides along the shank.
J
Neil Wyatt09/02/2017 08:24:28
19226 forum posts
749 photos
86 articles
Or there's this:
www.amazon.co.uk/Laser-2562-Mini-Ratchet-Bit/dp/B002VJ7K88/ref=pd_sbs_60_t_0?_encoding=UTF8&psc=1&refRID=YQQX013QRADB6YKVKDQA
Simon Williams 309/02/2017 08:53:22
728 forum posts
90 photos
John I sent you a PM.
HTH Simon
