Help wanted . someone with a mill
toolpost mod
Simon Geary23/12/2016 20:40:19
16 forum posts
Hi all . my kids have bought me a quick change toolpost for Chrimbo . I need to modify my compound to lower the centre height . its a 100 year old Drummond lathe that I inherited from dad . what I need is 5 mm milling off the top flat square and a couple off mm taking off the bottom . if theres anyone around the Hinckley Leicestershire area with a mill who would be interested in helping me . would you get in touch please
Hacksaw23/12/2016 21:00:32
474 forum posts
202 photos
They're very very hard , i did it after annealing it and still needed a carbide cutter... I suggest a surface grinder ?
Bah sorry ! I miss read  thought you wanted to shorten the T P !  It's them that's rock hard...
Edited By Hacksaw on 23/12/2016 21:02:22
Simon Geary23/12/2016 21:18:06
16 forum posts
Posted by Hacksaw on 23/12/2016 21:00:32:
yes I made a couple of marks in the bit I want milling with a hacksaw .and a file .fairly soft . and it has been used at some time for milling and had a chunk cut out of the front face so it should be fairly easy to machine
Hopper24/12/2016 04:44:14
7881 forum posts
397 photos
Grip a milling cutter in the chuck, bolt or clamp the piece to be milled on to the cross slide, using various packing pieces to adjust height and Bob's your grandmother's daughter's brother. A carriage lock is pretty much essential. Nipping up a bit of shim in the lift plate under the rear shear will do at a pinch.
Peter Dobson27/12/2016 22:56:27
9 forum posts
Simon
I have sent you a message. I might be able to help.
Peter D
bodge28/12/2016 01:08:41
186 forum posts
Hi
You could pack the head stock & poppet head with some 1/4" or 5/16" br,ms plate, would save on thinning down an original part .........................b
sean logie28/12/2016 06:39:16
608 forum posts
7 photos
Just a thought ... Can you not return and swap it out for one that gives you the correct height for your lathe . I had the same problem just with the tool holders they needed about 3mm off the bottom . I tried a carbide cutter whilst holding the part in the 4 jaw without much success . Ended up using a grinder ,a bit rough I know but needs must and it worked .
fizzy28/12/2016 10:03:29
1860 forum posts
121 photos
At 3 hours to Burnley I doubt you would want to but if you drive up I will happily do the machining for you.
Alan .20428/12/2016 16:14:48
304 forum posts
14 photos
I'll do it for you but I'm a fair way of I think, Market Rasen North Lincs, let me know what you think.
Alan.
Phil super728/12/2016 16:59:17
24 forum posts
I could do this for you if interested quite close to you I l live in tamworth
Phil
Simon Geary29/12/2016 12:01:40
16 forum posts
Posted by Alan .204 on 28/12/2016 16:14:48:
Alan. Thanks matey but a little too far
Nick_G29/12/2016 13:12:14
1808 forum posts
744 photos
Have you got a 4 jaw chuck and a set of flange jaws for it.?
If so you could probably do this yourself providing you were careful with the setup.smiley
Nick
Simon Geary29/12/2016 14:41:53
16 forum posts
I have got a 4 jaw I also have a back plate but the swing on my lathe is not big enough as the compound is about 6 inches long
Gary Wooding29/12/2016 14:48:29
1074 forum posts
290 photos
Simon, I have a mill and live in Leamington Spa. Is that too far away?
Chris Evans 630/12/2016 07:32:10
2156 forum posts
Simon, if Phil super 7 does not get you sorted in Tamworth I am a little further up the A5 in Kings Bromley, Chris.
David George 101/01/2017 16:07:42
2110 forum posts
565 photos
Hi Simon I recently fitted a quick change toolpost to my Drummond M type and wondered if this information is useful as I didn't have to reduce the heights but anyway have a look.
David
Edited By David George 1 on 01/01/2017 16:13:56
Simon Geary11/01/2017 13:12:48
16 forum posts
Thanks for all the offers of help . a member of this group Michael W ,has done the job for me , so ne xt thing is the choose what tools go into the 4 holders and get them centred ready for use ... Happy new year to all ...
Mike Poole11/01/2017 13:54:43
3676 forum posts
82 photos
Hi Simon, you are on the slippery slope now, it's near certain that you will want more tool holders, I am up to 20 now but some are spare at the moment, I am sure it won't last.
Edited By Mike Poole on 11/01/2017 13:55:20
