Steve Withnell | 27/08/2016 09:29:15 |
![]() 858 forum posts 215 photos | I bought an old Bell & Howell 16mm movie projector a while back for a bit of fun. It's an amazing piece of engineering produced around 1962. Just to add to the fun, the audio amplifier uses EL84's Anyway, the retaining screws that hold the case to the frame were a right mixed bag of threads shapes and sizes, but my best guess was they should have been 6-32 slotted panheads (but bigger heads than normal). I decided to drill and tap 4mm all the holes and use flange head screws. Reading the service manual I spotted a warning that the frame is a magnesium alloy casting and proper workshop practice must be followed. What is the appropriate "workshop practice" for drilling and tapping this material? I'm assuming there is a fire risk when machining the alloy. The first one drilled and tapped just fine Steve |
I.M. OUTAHERE | 27/08/2016 10:17:46 |
1468 forum posts 3 photos |
Tweaked my interest this one as i know nothing about working with magnesium alloys so Wikipedia to the rescue ! I didn't see anything other than a mention that these alloys are highly inflammable in dust or small chip form and to keep the temperature below 470 C . I don't think you will achieve this drilling and tapping a few holes . I'm sure some one with more experience will come along shortly !
Ian.
DMB | 27/08/2016 10:19:13 |
1585 forum posts 1 photos | Steve, When job finished have a good clean up to get rid of all mag ali swarf as its a very real fire hazard. BR used to use a mix of iron and magnesium filings to do onsite welding of rails. Stuff used to burn like hell white hot. Somewhere on this forum a long time ago there were comments about the potential dangers and I think at least one shed man had a fire. Take care! John Edited By DMB on 27/08/2016 10:20:03 Edited By DMB on 27/08/2016 10:20:44 Edited By DMB on 27/08/2016 10:22:07 Edited By DMB on 27/08/2016 10:23:09 |
Andrew Johnston | 27/08/2016 10:21:02 |
![]() 7061 forum posts 719 photos | I don't think it's an issue with the metal working techniques per se. I recently cut up some magnesium sheet on my guillotine as a favour to a client, and it was no different to aluminium. Possible problems are due to the combustion of magnesium. In the form of fine swarf or thin ribbons it can spontaneously ignite. Once burning you either need a class D fire extinguisher or a bucket of dry sand to put it out. The same problem occurs with some other metals, notably titanium. Having looked at the cost of a class D extinguisher I turned down a job machining titanium for the same client. In practise I suspect there is unlikely to be an issue. But since my garage/workshop is integral to the house I didn't fancy explaining to the household insurers how I'd managed to burn the lot down. Andrew |
Brian Wood | 27/08/2016 10:27:07 |
2742 forum posts 39 photos | Steve, Then gather the swarf and burn it |
SillyOldDuffer | 27/08/2016 11:13:58 |
10668 forum posts 2415 photos | Posted by Brian Wood on 27/08/2016 10:27:07:
Steve, Then gather the swarf and burn it But be aware that trying to put out a magnesium fire with water will cause an explosion. Burning magnesium + water = burning magnesium + steam + hydrogen + air = whoosh bang! If I was going to work magnesium on any scale I'd research how to do it first, including what to do with the scrap. Dave |
roy entwistle | 27/08/2016 11:24:36 |
1716 forum posts | Brian A fire hazard and using paraffin ? I wouldn't have thought so |
mechman48 | 27/08/2016 11:44:53 |
![]() 2947 forum posts 468 photos | Would any of the above apply to 'ZAMAK' ... Zinc Alloy; also known as Mazak 'ZAMAK is an acronym for Zinc Aluminium Magnesium and "Kopper". Has any one machined Zamak / Mazak as they both contain elements of Magnesium ?... Just curious George. |
Andrew Johnston | 27/08/2016 11:51:07 |
![]() 7061 forum posts 719 photos | A small amount, not a problem. The percentage of magnesium is very small, the alloys are mainly zinc. Andrew |
Geoff Theasby | 27/08/2016 11:54:06 |
615 forum posts 21 photos | Drilling and tapping Mg shouldn't be a problem, since any heat will be conducted rapidly away. Consequently, the metal in the mass never gets hot enough to ignite. Dust and swarf, though, Beware! As it is light and insubstantial, heat rapidly builds up. Geoff |
Brian Wood | 27/08/2016 11:57:04 |
2742 forum posts 39 photos | Roy, |
roy entwistle | 27/08/2016 12:22:31 |
1716 forum posts | Yes I once had a small quantity of very fine aluminium swarf ( like spider web ) go up on the lathe, not something to relish |
Circlip | 27/08/2016 12:42:21 |
1723 forum posts | Yonks ago I bought a speedboat with a 65Horse Mercury outboard hung on it. The whole rig was cheap because the motor "Didn't work". Hardly surprising with a broken con rod poking through a hole in the crankcase. Top and bottom (front and back cos the engine crank is vertical) crankcase halves, like a VW is line bored to clamp the main bearings and checking with supplier would have meant a new crankcase complete. Coupled with the fact the cylinder head is part of the "Top" casing, deferably an expensive replacement. What about welding the hole closed, filling a 25mm x 15mm piece of missing case? "No, it's a Magnesium Aluminium casting" was the agents retort. "Yes, but is it Magnesium Aluminium or Aluminium Magnesium" Attacking a broken piece with a blowlamp confirmed the latter so a local welder with Tig welding Aluminium experience costing £30 (35 years ago) was a considerable saving. A bit of internal scraping cleaned it up and on reassembly ran like a dream. Depends which is the major element when thinking of repairs and safety precautions.
Regards Ian. |
John Stevenson | 27/08/2016 12:44:16 |
![]() 5068 forum posts 3 photos | Gordon Bennett it's 3 or 4 tapped holes not a bloody space shuttle.
You stand more chance setting fire to your moleskin trousers trying to cut the welds to get you out your armchair. |
Andrew Johnston | 27/08/2016 13:19:57 |
![]() 7061 forum posts 719 photos | Posted by John Stevenson on 27/08/2016 12:44:16:
Gordon Bennett it's 3 or 4 tapped holes not a bloody space shuttle. ...........but look what happened to the space shuttle! |
John Stevenson | 27/08/2016 13:46:59 |
![]() 5068 forum posts 3 photos | Don't think a Myford has that horsepower !! |
mark smith 20 | 27/08/2016 14:00:44 |
682 forum posts 337 photos | Posted by DMB on 27/08/2016 10:19:13:
Steve, When job finished have a good clean up to get rid of all mag ali swarf as its a very real fire hazard. BR used to use a mix of iron and magnesium filings to do onsite welding of rails. Stuff used to burn like hell white hot. Somewhere on this forum a long time ago there were comments about the potential dangers and I think at least one shed man had a fire. Take care! John Edited By DMB on 27/08/2016 10:20:03 Edited By DMB on 27/08/2016 10:20:44 Edited By DMB on 27/08/2016 10:22:07 Edited By DMB on 27/08/2016 10:23:09 Hi, You sure it wasn`t aluminium BR were using, though they often use a magnesium ribbon fuse to set the reaction off. Thermite reaction. |
Andrew Tinsley | 27/08/2016 15:17:50 |
1817 forum posts 2 photos | You don't need to worry about doing drilling and tapping on a magnesium casting, unless your drill is totally blunt and ignites the stuff. It depends a lot on the exact composition of the alloy. Magnesium with just 2% iron is non flammable,or maybe it was silicon, I can't remember right now and I don't have my notes here. It seems to be very difficult to get hold of. At least I cannot source it. If you think you have a problem, I am casting the stuff! You should see the remote control set up that I have. If the argon atmosphere fails then I have somewhat bigger problems than you might have! Before the engineering community comes down on me with much wrath. I might say that my casting setup is highly professional and is operated remotely. If anything did go wrong, then I am in a remote area free from housing or for that matter the melt is remote from myself! At least two people are present during a casting operation. So safety is absolutely paramount. I would not recommend trying this for yourself, I still have not got a clean casting and I have put a lot of work into the set up. So much so that I can't give up now! Andrew.
steamdave | 27/08/2016 15:39:33 |
526 forum posts 45 photos | When I was a lad, we used to buy strips of magnesium in the local chemist shop, about 1/8" wide and 12" long from memory. 'Twas great fun to set fire to it with a match. Dave |
Steve Withnell | 27/08/2016 15:55:31 |
![]() 858 forum posts 215 photos | Sounds like the only risk is the dust and chips dropping into that nice valve amplifier. Thanks!
Steve |
