Gear tooth chart
Peter Krogh11/06/2016 00:57:30
228 forum posts
20 photos
Gear tooth gauges are available but are extremely expensive, like $100 for a set. Can't afford that nor do I need
those. Silly prices for some bits of stamped sheet metal!
Where can I get a printed, or printable, gear tooth chart I can use to identify various gear pitches? I've been all over Google with no joy. I just need something I can hold a gear up to and identify what the pitch is.
Anyone?
Pete
Bazyle11/06/2016 01:07:48
6956 forum posts
229 photos
Well you can pay $100 I suppose, but most people make do with something cheaper.
Peter Krogh11/06/2016 02:54:42
228 forum posts
20 photos
That's a screw pitch gauge, not a gear tooth gauge!!! Geeezzzz.
Pete
Sandgrounder11/06/2016 05:40:22
256 forum posts
6 photos
I think it was Davall Gears that used to give out a free plastic disc about 3" dia with a wide range of teeth moulded on the circumference, whether they still do I don't know, and I don't know what happened to mine.
John Hinkley11/06/2016 06:45:54
1545 forum posts
484 photos
I found this company in India:
http://www.measuringtestinginstrument.com/kristeel-precision-gauges.html
They do what you're after for 1,100 Rupees (about GBP11.50 or USD16.50 ) for a set of 22 gauges.  Didn't look to see how much postage was, though!  Gauges are available in metric module 20° and DP 14.5°.
edited to improve clarity!
Edited By John Hinkley on 11/06/2016 06:47:41
Boiler Bri11/06/2016 06:49:13
856 forum posts
212 photos
Try. HPC gears at Chesterfield. They have downloadable catalogues. SH Muffet. Daval. They are all searchable on Google
JasonB11/06/2016 07:44:34
Boston Gear show the profile of each of the DP gears that they do in this pdf which you could lay the gear against. I don't know of a chart that will show the tooth shape as the number of teeth change as well as the DP/Mod.
Nigel Bennett11/06/2016 09:12:08
500 forum posts
31 photos
You should be able to determine roughly what size of tooth you're dealing with by measuring the tooth depth. If it's a metric gear (Module), then the tooth depth is a little over twice the Module - e.g. if the tooth depth is 2,25mm or so, it's possibly a 1 Module gear.
If you're dealing with a DP gear (perhaps more likely in Model Engineering) then the method is similar. Full depth of tooth on a DP gear is 2.157/DP. So if your tooth depth is a little over 1/8", then it's probably 16DP.
Once you've determined the approximate pitch size, then you can use the David Brown Base Tangent method, whereby you use a vernier caliper to measure over 2 or 3 teeth (it depends on the number of teeth in the gear) and you can then decide whether it's (say) 8DP or 3 Module.
Be aware that there are two standard "pressure angles" for gears - 14.5 degrees and 20 degrees. This affects the shape of the teeth and hence the Base Tangent measurement. Older DP gears may well be 14,5 deg, most module gears are 20 deg.
Machinery's Handbook gives dimensions for BTM, but in my 1957 edition they hadn't invented millimetres.
Neil Wyatt11/06/2016 09:26:15
19226 forum posts
749 photos
86 articles
Roll the gear over a fairly thin layer of plasticine, and it will leave behind a 'rack'. You can then measure pitch and estimate the angle by looking at it from the side more easily than by looking at the gear.
DMB11/06/2016 10:32:53
1585 forum posts
Hullo Peter,
I think Harold Hall showed a set of black silhouettes of gear teeth for comparison, not sure if on his website or in one of his books.
HTH.
Ian S C11/06/2016 12:09:14
7468 forum posts
230 photos
I seem to remember the black silhouettes were on this forum somewhere, I'v got a print out somewhere, but I don't think I have it on my hard drive. Ian S C
JasonB11/06/2016 13:08:57
Silhouettes are in the link I posted earlier
Emgee11/06/2016 16:33:20
2610 forum posts
312 photos
Peter
Sandgrounder is right about Davall Gears give away gear size disc, I have scanned mine and put a couple of hole dimensions in to enable the correct sizing, it is only for MOD gears 0.5 to 6.0
Emgee
Peter Krogh12/06/2016 02:59:18
228 forum posts
20 photos
Posted by JasonB on 11/06/2016 07:44:34:
Thanks Jason. The problem is that there is no associated 'scale' with which to size it while printing. This is true of
all the profile charts I've found. Google is rife with them!
Pete
Peter Krogh12/06/2016 03:00:31
228 forum posts
20 photos
Posted by Emgee on 11/06/2016 16:33:20:
Peter
Emgee
Thanks Emgee! I'll print that out. I don't need a Mod size gauge yet but I just might.
Pete
Peter Krogh12/06/2016 03:16:47
228 forum posts
20 photos
Posted by John Hinkley on 11/06/2016 06:45:54:
John, I'll be contacting them pretty soon. That price is realistic for a gauge like that and, from what I can see on their web page they should be able to make one of those pretty well so there is a low risk I'm sure.
Thanks,
Pete
