Why do you?
Tractor man | 29/01/2016 19:28:47 |
426 forum posts 1 photos | How do you solve this little machining quandary? |
Tractor man | 29/01/2016 19:29:47 |
426 forum posts 1 photos | Dovetails set at 90 degrees to each other cut in steel and brass. |
Michael Gilligan | 29/01/2016 19:36:39 |
![]() 23121 forum posts 1360 photos | Presumably it's a single dovetail, running at 45° across the square. ... unless, of course it's a neat bit of inlay work MichaelG. |
Ian P | 29/01/2016 19:42:10 |
![]() 2747 forum posts 123 photos | Could it be two dovetails parallel to each other at 45degrees across the square face. Ian P |
JA | 29/01/2016 19:45:08 |
![]() 1605 forum posts 83 photos | How about two dovetails in the form of a cross and a very large hammer? Err, no! [Sorry, I could not resist it] JA Edited By JA on 29/01/2016 19:45:58 |
Mike Poole | 29/01/2016 19:48:52 |
![]() 3676 forum posts 82 photos | If all 4 faces have a dovetail then it is 2 dovetails at 45°, if only the 2 faces shown then it is one at 45° Mike |
Graham Butcher | 29/01/2016 19:59:11 |
21 forum posts 3 photos | For those that want to know how to make one. This video will explain... https://youtu.be/a3V42KwLTeE
Graham |
Bodger Brian | 29/01/2016 20:09:16 |
![]() 187 forum posts 40 photos | There was a 'how to' article in the ME quite a few years ago. Brian |
Tractor man | 29/01/2016 21:04:22 |
426 forum posts 1 photos | Yes its a 45 degree dovetail job. Got me scratching my head when I first saw one and I just had to have a go. Looks easy but crikey it took some thinking out. Mick |
Robert Dodds | 29/01/2016 22:32:30 |
324 forum posts 63 photos | Think turning not milling. And taper turning at that!! Then twist to lock. Bob D Edited By Robert Dodds on 29/01/2016 22:34:28 |
John Olsen | 30/01/2016 04:16:34 |
1294 forum posts 108 photos 1 articles | Back when I used to write for Model Engineer I wrote up how to make one of these. Mine was done on a shaper since these are a good machine for doing dovetails without fancy dovetail cutters. The usual approach is the two dovetails at 45 degrees to the faces. You can also make them by setting up each block with one corner along the axis of the lathe and making the dovetails on each part as a quarter circle, then as Robert described above they twist in together. Either way the work wants to be accurate and close fitting, or else it becomes easy to see how it works. I first saw this idea as a woodworking exercise in either Popular Science of Practical Mechanics back in the late fifties or early sixties, but would assume it is much older than that. John |
John Reese | 31/01/2016 04:05:43 |
![]() 1071 forum posts | Clickspring has a video on YouTube showing how he made one. |
Sam Stones | 31/01/2016 04:21:27 |
![]() 922 forum posts 332 photos |
A bit like this. Cut by hand from huon pine. I only had a saw, a chisel, and a couple of files. Very laborious! Edited By Sam Stones on 31/01/2016 04:22:34 Edited By Sam Stones on 31/01/2016 04:22:56 |
Tractor man | 31/01/2016 07:16:40 |
426 forum posts 1 photos | Yes its shown as a woodworking puzzle in many cases. Quite a fun item to make and a conversation piece for engineers and less advanced beings lol. |
Tractor man | 31/01/2016 07:19:49 |
426 forum posts 1 photos | |
mark costello 1 | 31/01/2016 20:12:07 |
![]() 800 forum posts 16 photos | Ya know if a ball dedent was positioned to make the parts snap together and offer a little resistance to disassambly, and possibly make it harder to figure out.. |
Sam Stones | 01/02/2016 18:36:02 |
![]() 922 forum posts 332 photos | What it looks like now, but no spring-loaded detent. |
Muzzer | 01/02/2016 20:43:19 |
![]() 2904 forum posts 448 photos | Posted by Robert Dodds on 29/01/2016 22:32:30:
Think turning not milling. And taper turning at that!! Then twist to lock. Bob D Edited By Robert Dodds on 29/01/2016 22:34:28 Indeed. And tonight's Fusion 360 challenge turned(!) out to be relatively straightforward. The woodworkers like the sliding version which is easier for them. But if you avoid the Brown Stuff, you can make stuff like this: Murray |
Muzzer | 01/02/2016 21:09:34 |
![]() 2904 forum posts 448 photos | Fusion challenge part 2 - sliding version. Murray |
mark costello 1 | 03/02/2016 00:17:05 |
