Multicore Cable
Supplier of modest lengths
Neil Wyatt26/01/2016 15:17:40
19226 forum posts
749 photos
86 articles
I need some nice flexible 4 and 6 to 8 core wire for small stepper motors a remote handset. It needs to be able to carry an amp or two comfortably on any individual core so old computer serial leads etc. are too fine.
The web is swamped with burglar alarm/telephone cable (which is single-conductor per core).
CPC only seem to sell cable in 100m lengths and I only want a few metres.
Maplin's range continues to shrink.
Can anyone suggest somewhere that does short lengths (e.g. 10m) for a reasonable price?
John Haine26/01/2016 15:19:54
5563 forum posts
322 photos
Arc? I bought some 4 core stepper cable from them.
Nick_G26/01/2016 15:22:32
1808 forum posts
744 photos
Posted by Neil Wyatt on 26/01/2016 15:17:40:
Telephone cable is normally single conductor per core. But 'true' alarm cable has several cores but does not fall into the true flexible category.
Does the cable need to be a true flexible cable or just bendable.?
Nick
John Rudd26/01/2016 15:27:10
1479 forum posts
Neil,
Have you tried ESR Electronics/Rapid electronics or CPC Farnell?
Edited By John Rudd on 26/01/2016 15:32:40
peak426/01/2016 15:34:02
2207 forum posts
210 photos
Cheap nasty 7 or 13 core trailer cable maybe?
Martin Kyte26/01/2016 15:40:46
3445 forum posts
62 photos
Have a look at
may be a little big though.
regards Martin
Paul Relf-Davies26/01/2016 15:40:50
84 forum posts
Would something like this suit? Can be bought by the meter in various colours.
P.
Simon Williams 326/01/2016 15:40:56
728 forum posts
90 photos
Try your local electrical wholesaler. Most branches of City Electrical Factors or its local equivalent will sell CY control cable (copper/pvc multicore flex) in cut lengths. You might not get a lot of choice of what construction, but you'll probably find something that'll do. For an amp or two and say 5 - 10 metres you probably need a cable with 1.0 mm2 cores, though 0.75 mm2 will do. Even 0.5 mm2 will suffice just about if that's all you can get, but steppers like their current so more copper is better. That's the cross section area of each core. There are special end fittings (glands) for some of these cables, particularly the flex armoured (braided) kind known as SY cable.
Another possibility is to use 7 core trailer cable - it's not rated for 230 volts (CY cable will be) and might be a bit too chunky, but it's an easy thing to buy and will have plenty of copper in it. I think Maplin sell it, also B&Q. There will be a local auto electrician's wholesaler who will sell it, or buy a trailer board at the car boot sale and rob the cable off it.
Alternative 3 is to find an industrial control panel or switchgear builder (look under electrical motor control panel in your local yellow pages or google etc). They'll have all sorts of offcuts.
You can make a multicore cable from some suitably sized nylon tube (air line tube) and some pipe fittings (end fittings) to make a DIY plastic conduit. This can make a very robust assembly with some serious resistance to abuse, but it is a fiddle to find or make the bits to make a nice looking job of it. Threading the cores up the pipe can be fun, pinch the vacuum cleaner off SWMBO and suck them through, don't push as they will snaggle up and jam.
Have fun! Simon
JA26/01/2016 15:41:12
1605 forum posts
83 photos
I have bought 4 core (3 phase) cable from B&Q. For more cores use trailer cable.
JA
Muzzer26/01/2016 15:47:48
2904 forum posts
448 photos
As John says, try Rapid. Bizarrely(?) they keep pukka drag chain cable , so if you want to do the job properly, that would be the stuff. Very flexible, coolant proof and with a good life spec. And available by the metre. Of course, you should really buy some drag chain when you are at it....
Merry
Neil Wyatt26/01/2016 15:57:08
19226 forum posts
749 photos
86 articles
Ah. Finally refined my searches (multicore cable WITHOUT a number of cores + a bit of patience!) and found some
Blimey! Where did all those replies come from?
It's for the scope drive, so trailer cable is going to be a bit heavy and stiff.
I found some 0.75mm2 4 and 6 core, which should be OK, I won't be going past 1A per core - forgot that bipolar steppers don't use an earth return. blush
Edited By Neil Wyatt on 26/01/2016 16:05:07
Michael Briggs26/01/2016 16:06:00
221 forum posts
12 photos
Hello Neil,
CPC - CB17120 for the steppers, regards, Michael
John Rudd26/01/2016 16:08:13
1479 forum posts
Posted by Neil Wyatt on 26/01/2016 15:57:08:
So, where did you manage to find some then? For future reference of course.....
Bob Rodgerson26/01/2016 16:09:59
612 forum posts
174 photos
Bob Hi Neil,
I believe that Arc sell four core by the meter for stepper motors.
Martin Kyte26/01/2016 16:19:46
3445 forum posts
62 photos
There is nothing wrong with using ribbon cable if you want light weight.
Martin
JasonB26/01/2016 16:24:00
The 7 core 0.75mm2 flex used for things like central heating programers is easy enough to get by the meter. Also watch out for some of the heat resisting flex as that is not good if in contact with grease & oil. Multiflex would look the part
Flex would be a better search than cable
Edited By JasonB on 26/01/2016 16:40:50
kevin beevers26/01/2016 17:54:12
69 forum posts
43 photos
how about the cable from an telephone handset
Ian P26/01/2016 17:55:57
2747 forum posts
123 photos
In a former life I made (well assembled) umpteen multicore cable using individual cores inside expandable braided nylon sleeving.
If you dont need electrical screening for your stepper and handset I suggest using individual silicone cores in 'Rilgaine'. Constructing a cable say, 1m long is very easy. I have made up multicore looms with 40 or so conductors wires that were 35m long. Standard multicore cable would have been preferred but a custom multicore was not warranted and we needed to connect several thermocouples, PLC i/o, coaxial RF wires, and high current devices through one umbilical.
Silicone wire is usually very flexible as it easily available with very high strand counts, it is flexible at high and low temps and if you were concerned about cable strength you can include nylon coated braided stainless steel cable (fishing line), if its secured in the connectors at each end of the cable there are no worries about strain (but it wont snap if you trip over it!)
Ian P
Neil Wyatt27/01/2016 10:55:13
19226 forum posts
749 photos
86 articles
Cripes, some heavy-duty solutions being offered. if I want braided stainless outer I have some in the scrap bin, but I wanted something relatively light and supple.
Went for 0.22 mm2 cross section (about 0.5mm diameter), will take an amp and should still be very flexible - my main criteria.
Bazyle27/01/2016 12:43:41
6956 forum posts
229 photos
nobody mentioned Ethernet cable, RS232 cables. Both readily available with connectors to suit. Ah, for the telescope, I'd suggest the RS232 so you have decent connectors for fumbling in the dark.
