First bit of Tooling
Grant Nicholas15/01/2016 20:23:35
51 forum posts
Hi Gents
I got a set of ER32 collets with the WM18 mill and although it had a collet spanner it did not come with a 36mm spanner for holding the collet shaft whilst doing the collet nut up.
Nice little beginner opportunity to put the Mill to work! Knocked up some drawings in Fusion360 and proceeded with the project.
I used steel for the handle, but only had a piece of aluminium plate for the spanner head. Obviously my concern was the steel handle would simply break out of the aluminium under side load so made a interference fit collar to provide further strength and support.
I thoroughly enjoyed making this little item from design through to the final product on both lathe and new mill.
I know its only a spanner but when I used it for the first time it certainly brought a smile to my face! smiley
G
Edited By Grant Nicholas on 15/01/2016 20:25:03
Johnboy2515/01/2016 20:31:16
260 forum posts
Nice job 👍
SillyOldDuffer15/01/2016 20:57:49
10668 forum posts
2415 photos
Gosh thanks Grant! I was thinking about exactly this problem today and your solution is better than the "spanner" I was going to wastefully bodge from a bit of rusty 3/8" plate tomorrow.
Ta,
Peter Krogh15/01/2016 20:58:53
228 forum posts
20 photos
That's a much nicer bit of kit than the usual one punched out of plate. And, you did it!
Pete
Grant Nicholas15/01/2016 21:05:49
51 forum posts
Thanks John!
@Dave. My pleasure! If you like, I could send you the technical drawings for the entire spanner in PDF format?
G.
Harry Wilkes15/01/2016 21:07:36
1613 forum posts
72 photos
Happy new spanner wink
H
OldMetaller16/01/2016 08:24:33
208 forum posts
25 photos
Grant, how about a short article for Neil on this piece of tooling? I have exactly the same problem with my ER32 collet chuck used on my lathe.
John.
Michael Gilligan16/01/2016 08:53:01
23121 forum posts
1360 photos
Posted by OldMetaller on 16/01/2016 08:24:33:
+1
from 'requirement' through 'design & manufacture' to 'testing'
... it should make an excellent article.
Neil Wyatt16/01/2016 10:31:24
19226 forum posts
749 photos
86 articles
Drop me an email if you are interested, Grant.
[email protected]
Tractor man16/01/2016 11:20:56
426 forum posts
Nice level of work Grant. Simple tool but well executed. Mick
Nick_G16/01/2016 11:22:43
1808 forum posts
744 photos
I like it. yes
Nick
Grant Nicholas16/01/2016 11:27:03
51 forum posts
Thanks for all the kind words gentleman. I am extremely honoured you think it worthy of a article in the MEW magazine!
I have just realised how disappointed I am that I did not take any pictures of the steps in the project, I usually do this, but in this case got so absorbed in the build that I did not bother..... oh well nevermind, whats that saying about hindsight......
I shall get in contact with Neil to find out whats involved.
Cheers
Grant
mechman4816/01/2016 12:07:25
2947 forum posts
468 photos
Well done Grant, nice looking spanner.
George.
SillyOldDuffer16/01/2016 17:39:34
10668 forum posts
2415 photos
Hi Grant,
Many thanks for the offer of a pdf but I think I can make one using the info you've already published. My version will be much more utilitarian than your nicely finished prototype. I might publish a photo if it's not too horrible!
Cheers,
NJH16/01/2016 18:05:29
2314 forum posts
139 photos
Grant
The fact that you did not take pictures need not be a problem. Just make it again - taking pictures as you go. You can then either offer it as a prize or, if you are anything like me, keep it safely somewhere in case you lose the first one!
Norman
( ps - the problem with the second option is remembering where the "safe place" is ! - maybe I' m a bit older than you though)
Muzzer16/01/2016 18:33:24
2904 forum posts
448 photos
Nice work Grant! There's some interesting stuff in F360, especially when you consider it's free for the likes of us. Sounds as if it may be a bit premature to talk about the CAM elements that are waiting for you but there is some interesting content in the "simulation" tab too. Here you can do full Finite Element Analysis (FEA) to see how close to the bone the design is with the sorts of loads you might expect to see.
If you take your existing design and create some small features to denote where the spanner will contact the nut, you can apply some contact forces and simulate the stresses and strains that represent what the spanner will see in the worst case - will it be close to failure, is there a weak area where there is undue stress etc.
It's under Simulation > Study > Static stress. You place loads, constraints (fixed faces for instance) and set materials (aluminium jaws and steel handle here), then click Solve. You can display stress, strain, displacement etc.
I haven't taken long to model your tool very accurately (it's really not very close) but this gives an idea of how quick and easy it is to do some FE Analysis. My jaws were 25m wide and 15mm thick, so probably not as beefy as yours.
Spanner FEA in F360
The end of the handle is fixed and I assumed a torque of 5Nm (3.8lbft) and a nut dimension of 44mm A/F. With a hex head this results in equal and opposite forces of almost 1400N at the line contacts between the nut and the jaws (1400N x 36mm = 5Nm) - these are the blue arrows.
The yield stress of aluminium is around 15-20 MPa, so in my example where it predicts about 70MPa peak stress, the jaws would have turned to toffee. You can see where the highest stress is - and where it would be possible to beef up the section to improve it.
Hope you find this interesting!
Murray
Edited By Muzzer on 16/01/2016 18:35:41
