What is the most useful workshop tool that you have made?
Danny M2Z14/11/2015 10:29:32
963 forum posts
G'day.
I was grinding some lathe tools today and looked around the workshop and got thinking about what was the most useful tool that I had made?
My immediate attention turned to the Harold Hall rest that I was using at the time. Brilliant design, used as required but not on a daily basis.
Then I spotted the carriage stop on my mini-lathe. Never had a head crash but turning or boring to a shoulder is repeatable. I use this daily.
So what have the rest of you been up-too?
*Danny m *
Gordon W14/11/2015 11:05:20
2011 forum posts
Most used- a simple length of bright bar at exact length for setting the tool hight, made two, one for setting off the cross-slide and one ( not used so much ) for the top slide. A crude fixed steady, made from bent and welded steel bar, to hold a length of 100mm s/steel tube but since used for all sorts.
Peter G. Shaw14/11/2015 11:09:36
1531 forum posts
44 photos
Probably my mandrel handle which I tend to use every time a try some screwcutting in the lathe. Otherwise it's George McLatchie's extractor on the milling machine.
Another very important idea, ok it's not a tool as such, is the addition of small heaters to both the lathe and milling machine which work by keeping the hardware slightly warm all the time. Ok, there is a running cost, but in terms of preventing rusting, they are priceless. It also means that the equipment never has that bone-chilling coldness at this time of the year.
Maybe I'll think of some more later.
Peter G. Shaw
Neil Wyatt14/11/2015 11:23:00
19226 forum posts
749 photos
86 articles
Like Peter, my mandrel handle. With the addition of a short level on the securing nut I can attach and remove it single handed in a couple of seconds, so it gets plenty of use. Great for short and internal; threads.
Hopper14/11/2015 11:34:56
7881 forum posts
397 photos
Four-way toolpost for my old Drummond lathe. It does away with the original "Norman patent" toolholder that holds only one tool and needs the centre height resetting every time the tool is changed or even moved slightly. This is the biggest time-saver I have ever made.
It bolts directly to the cross slide table so eliminates the flimsy top slide and leaves more clearance around the tailstock. And I made it so it can be remounted as a rear toolpost if required and used for parting, chamfering etc while the regular cross slide is used.
Next step is a similar four-way toolpost for the top slide.
mechman4814/11/2015 12:14:09
2947 forum posts
468 photos
Two that I have used the most lately... mandrel handle for threading when I've used the tailstock die holder, & saddle stop.
Graham Titman14/11/2015 12:33:12
158 forum posts
28 photos
The threading attachment by Jacques Maurel which is quick and simple to set up on my metric emco lathe and saves changing the quadrant when i cut imperial threads and a version of the tangential tool holder for finishing small diameters.both of which are getting a lot of use building a 3" traction engine,a 5"railmotor, tooling as above, bits for a motorbikes,odd bits for the house and car and jobs for my son.
BERT ASHTON14/11/2015 13:40:30
78 forum posts
59 photos
Although I have made most of George Thomas's designs I think the most useful is the
Universal Pillar Tool, from drilling, tapping, riveting and indexing. In all a perfectly designed
piece of workshop equipment.GHT Uni Pillar Tool
Neil Wyatt14/11/2015 14:33:59
19226 forum posts
749 photos
86 articles
Good point, Hopper. I should have name-checked my 4-way toolpost as well - it has transformed my use of the lathe.
paul 195014/11/2015 14:48:59
143 forum posts
32 photos
John Rudd14/11/2015 15:51:51
1479 forum posts
I think the most useful item I have in the shop has to be the spring centre I made as featured in one of the mags some time back, closely followed by a carriage stop for my Chester 9x20 and one for my super C3 lathe, other useful items I've made, Harold Hall's grinding rest, his indexing unit both featured in one of his books and finally a ball/radius turning tool.
Sorryno pictures to show but everyone knows what they look like....and it saves server space 😃
alan frost14/11/2015 16:37:13
137 forum posts
I would love to have more details of the Jaques Maurel threading attachment. Obviously I will be googling it etc. but just in case I come up with nothing thought I'd ask.
Howi14/11/2015 16:58:22
442 forum posts
19 photos
Agree with Peter and Neil, on mandrel handle, only just made mine, can't think why it took so long. I was actually bored, with nothing to do, well not quite true, just didn't feel like doing anything build wise, but felt I had to do something.
Bazyle14/11/2015 17:16:40
6956 forum posts
229 photos
Posted by alan frost on 14/11/2015 16:37:13:
JM has done two threading devices, both I think featured in another magazine but do have threads on here. One is a self retracting tool that unfortunately was criticised on here but not put off he introduced the other which was a thread compensator adjusting one thread pitch to another (eg metric to imperial) using levers which was an update of an ME article from the fifties.
ega14/11/2015 17:16:48
2805 forum posts
219 photos
Rather like other posters, most-used has to be the GHT indexing four-way toolpost on the Myford.
BERT ASHTON:
Is the toolpost in your repertoire and are you by any chance the man who displayed a comprehensive collection of GHT designs at an ME exhibition some years ago?
BERT ASHTON14/11/2015 19:25:10
78 forum posts
59 photos
ega, No I never made the GHT toolpost, I used a Myford four-way toolpost that came with
the Super 7.
Again no, I have never displayed anything at ME exhibitions, I did a lecture, many years
ago. at Rochdale ME.
The photograph shows the GHT Headstock Dividing Attachment, Retracting Topside
and the Graduating Tool.
MICROMETER DIALS
Clive Farrar14/11/2015 20:54:27
125 forum posts
41 photos
I do not wish to seem trite but my best mod was to add a loop of 6mm to the up and over garage door. I can now pull it down so easy and not put my back out.
That locks me and the heat inside and everyone else outside.
Anti social Moi Pahh.
It also makes a great hanging point for the hose pipe in the summer.
Regards Clive
Jens Eirik Skogstad14/11/2015 21:10:15
400 forum posts
22 photos
My useful tool is millingmachine who is made of old drillpress with ownmade equipment .
alan frost14/11/2015 21:33:00
137 forum posts
Bazyle many thanks. If I did n't know better I would think you were a young whippersnapper of a member with the consequent infallible memory.
I did do some research myself and came up with two issues of another magazine with articles by Jacques Maurel, one of which apparently described the retracting tool holder,which thanks to your kind link I was able to watch a quite impressive video of. The other in December 2014 apparently describes a saw blade alignment tool.
The video you referenced lead me to quite a bit of information on the thread compensating tool including a utube video but regretfully I was unable to find another article by Jacques Maurel , or the threads on this website referring to his articles (no surprise there then).
Anyway your help.believe me was much appreciated. It now appears I will need the help of someone with the legendary memory power for articles on any sort of work with metal of a John Stevenson although I will continue with my own researches. It is said,but I can not confirm that JS remembers the date of the original article in "Temple Building for Beginners" by the original Tubal Cain. He must have been fairly young then.
Alan
Michael Gilligan14/11/2015 22:26:51
23121 forum posts
1360 photos
Alan,
A quick look through these results might help.
