What to use
Skel | 24/10/2015 23:17:22 |
12 forum posts 4 photos | Hi Everyone. I'm new on here and this is my first post so greetings to everyone. I'm about to paint my Harrison M300 lathe and I'm wondering what the best stuff to use is ? I'm planning on brush painting it. Its the model with the white top and battleship grey base. It needs to be a satin finish and be oil and coolant proof. Any ideas ? Cheers. Skel |
clogs | 25/10/2015 07:20:04 |
630 forum posts 12 photos | Hi Jon, welcome on board.....u'll have load's of fun.....clever lot these members....funny as well.... I always used a good quality brushing machine enamel, loads'a colors and finishes but they are not generally available.... look 4 a paint manufacturer like Michel-Guest...(I think, been around 4 years), they'll tell u where to get it...... but they still post........I think...... I've not used any for a while, suppose they will not b as good due 2 the Elf n safti mob removing all the good stuff.... But u never know...... wish u luck.... |
Gray62 | 25/10/2015 07:30:35 |
1058 forum posts 16 photos | Hi Jon, Try Stationaryengineparts, they do a good range of paint and some specific machinery colours. I bought some Warco Green from them and its a good match. They can also match to a RAL paint code |
Neil Wyatt | 25/10/2015 08:55:58 |
![]() 19226 forum posts 749 photos 86 articles | Welcome Jon, Take/post a paint chip to a place that mixes coach pant for a perfect match and excellent finish. This place appears to be £37 + £9.95 to match it for 2 litres of two pack, but I'm sure they will do brushing enamel (and if they won't someone else will). |
Phil Whitley | 25/10/2015 09:44:17 |
![]() 1533 forum posts 147 photos | I use Tractol machinery enamel, available at all agricultural engineers and country stores, here is my Harrison mill in a delightfull shade of John Deere green, which is the colour it was when i go it, much cheaper than the special lathe paint (lols) being flogged to purists by some internet "enterprenuers". brushes or sprays really well, but needs to be sprayed in a warm atmosphere or it may run. There is also a huge range of colours in commercial transport paint which is a polyurethane synthetic enamel which is virtuall oil proof when fully cured, and is very hard wearing. find a local spray shop suppliers (paint wholesalers), and pop in for a chat! Phil |
Robbo | 25/10/2015 09:50:48 |
1504 forum posts 142 photos | Tractol single pack machinery enamel from Smith & Allan in Darlington Co. Durham. Brushes out to a smooth finish. Edited By Robbo on 25/10/2015 09:52:17 Edited By Robbo on 25/10/2015 09:53:23 |
frank brown | 25/10/2015 14:49:09 |
436 forum posts 5 photos | Hi Robbo, your link is labelled correctly " smithandallan.com", the HTML behind it says "smithand allan. co.uk" . Just a warning to others, what going on? I looked at the site cos' I am thinking of painting my lathe. Tractol is £9.99 /l unfortunately the colours are numeric without a colour chart. Shall i just order a number 6 and see what appears? Frank |
JA | 25/10/2015 15:27:49 |
![]() 1605 forum posts 83 photos | When I rebuilt my first lathe, a pre-war Myford, I brush painted it with jappening enamel bought from B&Q. A number of bright colours were used. The finished survived seven or so years of good used well. I then sold it to a friend and bought a factory reconditioned Super 7. Its paint finish was no better, or one could say was as good as mine on the old Myford. JA |
KWIL | 25/10/2015 16:16:58 |
3681 forum posts 70 photos | Original Harrison paints were I believe Alkyd Resin based and RAL colours. This link is for RAL 1013 Oyster White, you can move about the whites from there. |
John Baguley | 25/10/2015 16:33:38 |
![]() 517 forum posts 57 photos | Another vote for Tractol. I got mine off Ebay as Smith and Allan have a shop on there. May be cheaper direct. Take care if you use the industrial etch primer as it's quite nasty stuff. You need to wear a mask and have plenty of ventillation. I got a very good finish just using a brush. John |
Steve Pavey | 25/10/2015 18:25:53 |
369 forum posts 41 photos | Lifted from the Yahoo Harrison site: "As I was unable to get anyone here (or on uk.rec.models.engineering) to come up with a BS/RAL number for the M300 colours, I contacted the "The paint references at this time were RAL 26049/Q55/9 for the grey and I assume the olive brown colour is what is used on the M series, and the grey on the earlier models. |
KWIL | 25/10/2015 19:19:56 |
3681 forum posts 70 photos | The clue here is the Q55 part of the code, TRIMITE Paints coding. HTH |
Skel | 25/10/2015 19:56:11 |
12 forum posts 4 photos | Wow.. Choices choices. After much deliberation I think I'm going to go for this one in semi gloss. http://www.stationaryengineparts.com/BS4800-22-B-15-Pearl-grey-Swansdown.html Its a later M300 than the vomit beige ones. In fact, if I had a vomit beige one, I would strip it and paint it this colour. Hopefully it will turn out ok, the original paint was textured but I'm not going for that as I think it makes it harder to keep clean. I will post a photo when its done. Thanks for all your help. Skelly. |
Kiwi Bloke | 01/11/2015 10:33:08 |
912 forum posts 3 photos | When I went round the Myford factory over a decade ago, they used Trimite 2-pack polyurethane, using all appropriate precautions for spraying nasty stuff like that. I got the impression that amateurs weren't considered capable of using such stuff safely, so couldn't easily get it. However, the purpose of this post is to ask if anyone knows what type of paint, filler, primer, undercoat, etc. would have been used by English machine tool manufacturers in the 1950s-70s. I'd like to use a period finish on a couple of machines I must get around to restoring one of these days. Of course, getting stuff can be a bit of a challenge in this distant colony (no Tractol, as far as I know) - any Kiwis got any ideas about paint suppliers? |
mark smith 20 | 01/11/2015 11:43:50 |
682 forum posts 337 photos |
Its quite nice if you can get it to brush out easily.. I found its highly dependent on the humidity and temp.etc.. when applying it. I was going to spray but my gun was broke. If the conditions are good it flattens well without brush marks. I expected it to be a bit more forgiving though as its meant for brushing. The colour was a lot bluer than it looked on their website. Rustoleum combicolour is easier to apply and is popular on American forums. Edited By mark smith 20 on 01/11/2015 11:57:40 |
Skel | 15/12/2015 21:15:07 |
12 forum posts 4 photos | Hi everyone. After some thought and reading all your comments I decided to paint my lathe with tractol white primer and then a top coat of some satin white called containerguard. It all went quite well untill I decided that the satin white was crap so I sanded it off slightly and put two coats of slightly thinned tractol gloss white/grey on top of that. I'm quite pleased with the result, it seems very durable, impervious to oil and suds and wipes clean. Hopefully I have done the photo link properly so you can see my efforts. Cheers. Skel. Edited By Skel on 15/12/2015 21:36:57 |
Mark Prickett 2 | 15/12/2015 21:53:21 |
75 forum posts 10 photos | Posted by John Baguley on 25/10/2015 16:33:38:
Another vote for Tractol. I got mine off Ebay as Smith and Allan have a shop on there. May be cheaper direct. Take care if you use the industrial etch primer as it's quite nasty stuff. You need to wear a mask and have plenty of ventillation. I got a very good finish just using a brush. John Hi john , what colour is this , im liking it very much , thanks Mark. |
John Baguley | 16/12/2015 00:42:28 |
![]() 517 forum posts 57 photos | Hi Mark, Smith and Alan list it as Dark Grey BS632. John
Mark Prickett 2 | 16/12/2015 06:11:18 |
75 forum posts 10 photos | Thankyou John. |
john carruthers | 16/12/2015 08:04:56 |
![]() 617 forum posts 180 photos | Parsons still make their enamels, very tough and hard wearing, easy to apply with brush or spray. |
