Tony Martyr | 06/10/2015 17:31:29 |
![]() 226 forum posts 45 photos | I have finally run out of my stock of hardwood and need a engine base around 12x8 by 2 inches thick. The stuff I have used in the past was a heavy dark Fijian wood which suffered from water staining but otherwise looked good and was oil resistant. I have done the usual web search but have rather lost my nerve (!) so seek recommendations for this forum Tony |
david homer | 06/10/2015 17:44:05 |
43 forum posts | Tony I bought some from British Hardwoods some years ago, not sure if they have minimum order quantities. They are in Keighly West Yorkshire, might be worth giving them a call, google British Hardwoods and you will find their website. David |
JasonB | 06/10/2015 17:44:19 |
![]() 25215 forum posts 3105 photos 1 articles | Assuming you want a block of solid wood then have a look at some of the wood turning suppliers they sell "bowl blanks" which would give you a 12x12x2 slab. (don't get a round blank! ) Good choice of hardwoods so should be able to find something thats suitable. I tend to run out a strip of something suitable and mitre the corners and fix around a piece of MR MDF, keeps the weight down and allows for any plumbing under the base, add a bit of a moulding with the router to tart it up a bit. Edited By JasonB on 06/10/2015 17:45:19 |
JA | 06/10/2015 17:44:46 |
![]() 1605 forum posts 83 photos | I have happily used Robbins in South Liberty Lane, Bristol. They are specialists in marine timbers and hard woods. I have found them very helpful and they are quite happy to talk to the 'small guy'. They have a good web site http://www.robbins.co.uk but they are not cheap. JA |
Bazyle | 06/10/2015 18:10:36 |
![]() 6956 forum posts 229 photos | You are in danger from warping from anything that large so I'd go for Jason's suggestion but using decent ply not MDF yuk spit. If you are anywhere near a boatyard perhaps they would have some offcuts of marine ply and teak trim. If you took a photo of your engine along they would be more sympathetic to a fellow craftsman. |
Speedy Builder5 | 06/10/2015 18:37:02 |
2878 forum posts 248 photos | Talk to kitchen fitters. Big lumps of wood and other materials get thrown away when they cut out for hobs, sinks etc. Apart from bread boards, they are mainly junked by the professional. |
Roderick Jenkins | 06/10/2015 18:57:06 |
![]() 2376 forum posts 800 photos | John**LINK** Boddy at Boroughbridge. Have a nice self selection store of planed planks. Not too far if you're visiting Bradford HTH Rod |
KWIL | 06/10/2015 19:22:52 |
3681 forum posts 70 photos | Try [email protected] local furniture maker in Bishops Castle, uses local hardwoods, should be good for an offcut. |
daveb | 06/10/2015 19:40:16 |
631 forum posts 14 photos | I noticed some bits of Ash in our local Tesco household section, about 10" dia X 2" thick. Dave |
Roger Provins 2 | 06/10/2015 19:53:17 |
344 forum posts | Posted by JasonB on 06/10/2015 17:44:19:
Assuming you want a block of solid wood then have a look at some of the wood turning suppliers they sell "bowl blanks" which would give you a 12x12x2 slab. (don't get a round blank! ) Good choice of hardwoods so should be able to find something thats suitable. I tend to run out a strip of something suitable and mitre the corners and fix around a piece of MR MDF, keeps the weight down and allows for any plumbing under the base, add a bit of a moulding with the router to tart it up a bit. Edited By JasonB on 06/10/2015 17:45:19 Wood for turners in 2" square lengths (and many other sizes) are known as spindle blanks rather than bowl blanks. |
JasonB | 06/10/2015 20:01:05 |
![]() 25215 forum posts 3105 photos 1 articles | Roger Tony wants a piece 12" x 8" x 2" thick to mount a model on. Its better than buying a whole plank and not too difficult to rip 4" off one edge of a 12" x 12"bowl blank to get the required 12x8 piece |
Jon Gibbs | 06/10/2015 20:14:02 |
750 forum posts | Ockenden Timber can't be far from you... **LINK** Their bowl blanks are round but they also list carving blanks which might fit the bill. HTH Jon |
Ian Welford | 06/10/2015 23:28:33 |
300 forum posts | Sadly John Boddy at boroughbridge sold up and then closed down. If you're in North Yorks then Duffields at melmerby are a good source. Also Scawton sawmills near Sutton-under-whitestonecliff. Further away there's Snaiton. Or at Doncaster there's Turners retreat. Styles and Bates, down south do mail order and come highly recommended. However ply and laminating as per Jason would be your best bet I think. If it can wait and you're local the Northern Woodworking expo at Harrogate is on 20-22 November and there's always a good choice there. |
Gordon W | 07/10/2015 09:44:00 |
2011 forum posts | Cheapest by far are local auctions- old brown furniture still does not sell. I get an old chair, sometimes as scrap, ideal for file handles etc. and one-use mandrels |
Ian S C | 08/10/2015 09:39:49 |
![]() 7468 forum posts 230 photos | The last one I did was made by taking a bundle of strips of heavy plywood (somewhere between 15 and 20 mm thick), and cut it in strips about 1 1/3" wide, then glued it together with the edges as the top surface, just needs sanding down, then varnished. The joinery factory that was just around the corner has moved away, so my supply of free timber has gone. Ian S C |
Tony Martyr | 12/10/2015 09:56:49 |
![]() 226 forum posts 45 photos | Thanks for the help - through these replies I found Ockenden Timber which is a treasure trove of kiln dried timbers and is only 20 minutes by car form home. I bought a slab of American black walnut - not cheap but exactly what I wanted and I resisted the temptation provided by their display of woodworking tools Tony |
