Blackening mild steel
Rainbows07/09/2015 20:54:54
658 forum posts
236 photos
So all quick change toolposts tend to have this sort of blackened finish to them and I was wondering if there was a hobbyist friendly way of doing it. I think I remember a video of putting hot steel into dirty motor oil in order to blacken it but I can't think where I saw it now.
Neil Wyatt07/09/2015 21:23:05
19226 forum posts
749 photos
86 articles
The oil doesn't need to be dirty (contaminated motor oil causes several nasties, notably testicular cancer), I use rapeseed oil. Heat to a good black heat and drop in. Cover to prevent flames. Repeat.
Bazyle07/09/2015 21:37:15
6956 forum posts
229 photos
There have been some cold blackening treatments on sale from ME suppliers in the past. Not sure about now.
Michael Topping07/09/2015 22:26:26
74 forum posts
5 photos
Blackgates do a cold chemical blacking kit that works quite well, but I think when I have used up the chemicals I have I will go back to heating to black heat and oil quench. To me it seems to be longer lasting.
Michael
Chris Denton07/09/2015 23:30:14
275 forum posts
The Caswell kit seems to work ok, I've done hundreds of parts with it.
jaCK Hobson08/09/2015 08:24:48
383 forum posts
101 photos
Posted by Neil Wyatt on 07/09/2015 21:23:05:
One advantage of getting old is that you reduce the chance of this disease (probably because of the increasing chances of developing something else).
It's a good idea to do it outside and be prepared for significant flames. It is also then much easier to avoid inhaling most of the nasties.
I was taught to use old engine oil at school
Edited By jaCK Hobson on 08/09/2015 08:26:24
donkey08/09/2015 08:25:30
85 forum posts
5 photos
I blacked a number of items with the motor oil method, heat and dip (about 20 items) 30 years ago although in a box they have been stored in a very damp garage and only one item shows signs of rust.
brian
Mike08/09/2015 08:51:56
713 forum posts
6 photos
I seem to recall reading somewhere that most modern motor oils contain additives which supress blacking. I've had good results with cheap supermarket own-brand margarine, but it does make the workshop smell like a fire in a chip shop...
Douglas Johnston08/09/2015 09:21:32
814 forum posts
36 photos
I've tried a number of different oils in the past for blacking and all work pretty well. Like Neil I now use rapeseed oil (just the cheapest type from the supermarket ) and get consistently good results.
I tend to heat to dull red which may be a higher temperature than is needed, I must experiment at lower temperatures to see if it works just as well.
Doug
Gordon W08/09/2015 09:22:02
2011 forum posts
I use old engine oil, diesel is better as more black in it. Just keep all your working bits well away. Also does help with rust prevention.
KWIL08/09/2015 09:29:14
3681 forum posts
70 photos
"Black-it" from Pixel Plus also works well.
Ajohnw08/09/2015 09:38:54
3631 forum posts
160 photos
I've never done it but saw a demo of oil blackening to prevent rusting at school when I was around 12 years old.
The item was heated with a torch and oil squirted on with an oil can - oil ? what ever was in the oil can. The result was a pretty thick coating.
Ian Hewson08/09/2015 10:36:52
354 forum posts
33 photos
As I remember, testicular cancer was caused not by inhalation, but by oily hands when going for a pee, or rags in overalls pockets.
jason udall08/09/2015 10:49:36
2032 forum posts
41 photos
Used engine oil...
Apart from the witches brew poured into the engin..you get to share any unburnt fuel residue and burnt fuel residue. ..
A) an inconsistent start point.
B) all sorts of nasties. .not least from synthetic oils breakdown products..
Best spring for some fresh oil...either a culinary type ( got to be harmless right?) Or a known mineral oil.
Just a hint...a bigger bucket( of oil) will take more hot metal to elevate temperature to flash point...ideal bucket..deep and narrow..part becomes 100% immersed "instantly"..coaxing the metal in is the best way to light the oil.
Gordon A08/09/2015 11:23:34
157 forum posts
4 photos
I use linseed oil; heat item to be blackened to dull red and plunge into oil...outdoors of course. Very good results so far.
Ajohnw08/09/2015 12:08:29
3631 forum posts
160 photos
Posted by Ian Hewson on 08/09/2015 10:36:52:
Mostly due to mist and splash onto overalls as I understand it, possible wiping hands on overalls too, oily rags in pocket etc.
Gordon W08/09/2015 16:04:16
2011 forum posts
Many of the health risks in the past were down to poor hygiene. Not surprising really when you think about, not many even had a proper bath, washing machines very rare. The same clothes worn all week, etc.
Rainbows08/09/2015 18:59:50
658 forum posts
236 photos
Would it be best doing this before tapping? Wondering how it would affect the tapped holes of the toolpost
Fowlers Fury08/09/2015 19:01:21
446 forum posts
88 photos
Rapeseed or sunflower oil from the supermarket is cheap enough not to bother with old engine oil.
Once done, rub the item all over with black shoe polish - allow to dry & polish off. It will help to delay any subsequent rusting and looks good.
You can also get a pretty good black appearance on an item you might not want to heat by purchasing some "Gun Blue". Follow the instructions carefully with regard to degreasing and certainly use the shoe polish afterwards as the black is only a "few molecules" thick.
KWIL08/09/2015 19:05:08
3681 forum posts
70 photos
If you use Black-It and similar selenium based products, which include commercial gun barrel blacking products, it changes the surface and does not merely add a layer of burnt oil (aka oily carbon) to the surface. This oily layer can be quite thick. This way threads are largely unaffected.
