Machine construction
Gray62 | 25/06/2015 13:49:13 |
1058 forum posts 16 photos | My Son has asked me for help in designing/constructing a machine for turning large wooden spheres. Currently he does these by hand with an arbortech carver and pattern jigs. These are on a fairly small scale, the ones he wants to produce could be up to 2 metres in diameter. For an insight into what we are wanting to achieve, take a look at the video on this site The machine we are proposing would not be truck mounted as that one is but still be able to be dismantled to move to site as needed on a trailer. Options for driving the main spindle would be 3 phase motor when located at the workshop and a diesel engine when off site. With a blank weighing in between 1 - 2 tonnes, it needs to have a substantial spindle / bearings and will turn at very low speed, <100 rpm The design of the cutting spindle has already been done, We are now contemplating the design of the main frame and spindle. Any ideas / suggestions welcomed. |
jason udall | 25/06/2015 14:02:33 |
2032 forum posts 41 photos | Truck wheel/bearing. As spindle.// face plate. Gear box motor to rotate. Router on radius arm..cam to sweep.. Built one years ago for a chap to finish some sort of musical drum" bongo"..4 foot tall |
Muzzer | 25/06/2015 14:09:18 |
![]() 2904 forum posts 448 photos | You need one of these. Murray Edited By Muzzer on 25/06/2015 14:10:28 |
richardandtracy | 25/06/2015 14:16:45 |
![]() 943 forum posts 10 photos | Err. Begs the question 'Why?!!?' OK, I realise it's because people will buy it. Suggestions:
Would love to see it when finished. Regards, Richard |
Gray62 | 25/06/2015 14:16:53 |
1058 forum posts 16 photos | Jason, yep, that's the thought train we had, do you have any more details/pictures of the machine you built? Graeme |
JasonB | 25/06/2015 15:08:56 |
![]() 25215 forum posts 3105 photos 1 articles | Something along the lines of this lathe ball turner but a lot larger box or girder section frame with the router inplace of the cutting tool, have the work pivot on a turntable as it wil take less support than a horizontal spindle with the frame at right angles to the axis I'll stick with making small ones
Edited By JasonB on 25/06/2015 15:21:56 |
jason udall | 25/06/2015 15:44:43 |
2032 forum posts 41 photos | Sorry no details remain. One observation..routing as apposed ti turning was chuffing slow. The turn table was "ratchet" steped not driven..increment table take sweep..index ..repeat.. A lathe solution would have much higher potential removal rate. But in ball turning the surface speed would vari a lot. I mean a lot. It was ok in the barrel/ drum case since we never worked to zero radius. But speed / efficiency was not a concern..."art" "..craft"..it seems that these are devalued if too efficient solution.. Funnily the chap had to " rough" up the finished thing to make it more authentic. .face palm.. |
Neil Wyatt | 25/06/2015 16:10:01 |
![]() 19226 forum posts 749 photos 86 articles | Reminds me of when I helped organise a David Nash exhibition in an 'earlier life'. I had a fun day visiting nature reserves and choosing trees with the man himself, even got to write a bit for the programme alongside the great Oliver Rackham! Neil |
Vic | 25/06/2015 18:30:42 |
3453 forum posts 23 photos | Aren't you going to have trouble finding 2 metre + diameter trees? |
Muzzer | 25/06/2015 18:51:03 |
![]() 2904 forum posts 448 photos | Have a word with that mad Canadian. They have big trees over there, although 2m is certainly pushing it these days. They chopped down all the big ones.... |
Gray62 | 25/06/2015 22:10:19 |
1058 forum posts 16 photos | Posted by Vic on 25/06/2015 18:30:42:
Aren't you going to have trouble finding 2 metre + diameter trees? In short, No. We've got several Oaks already felled and stored on the farm, and there are more to come in the next few months. Other species are admittedly hard to come by in this size. We decided on 2 metres as the largest size we could reasonably handle. Smaller sizes will also be accommodated on the machine. |
John McNamara | 26/06/2015 09:31:26 |
![]() 1377 forum posts 133 photos | Hi Graeme I think I would be inclined to go a different route Consider moving a high speed rotating tool head say a heavy duty industrial quality router through an arc as you very slowly rotate the work piece. That does away with the rather serious safety issues of a large mass rotating at 100rpm. or even 25rpm. Also bits of tree trunk are hard to mount securely. There are several ways to describe an arc mechanically the easy way is a cranked arm and pivot. You will need an accurate pivot not that hard to do using self centring bearings like this one you will need two spaced apart **LINK** The arm can have both bearings at one end (harder to make stiff and accurate enough) however easier to position on large work For finishing off replace the router with a custom made 3 pulley belt sander using the slack side to conform with the radius of the work not the pulley ends the centre pulley is the driver. This is the way many tube polishing machines work. obviously you will need light tension and the right abrasive or it will dig in. There are some rather nasty looking "Hogging" cutters available for angle grinders. Maybe for the initial cuts one of these might be a bit faster if speed Is an issue, it would be another attachment for the arm in place of the router Oh and if you really want a good finish look through this video You will see a method that will work for you if you make a polishing cup, The video unfortunately has a lot of chatter Hmm But the meaty bits are there. and they use the rotating arm I am talking about. They do make a rather special ball. Using this setup the power and drive requirements are somewhat less demanding. Oh yes you will need a custom trailer kitted out with a jib crane. Regards Edited By John McNamara on 26/06/2015 09:33:44 |
Ian P | 26/06/2015 10:54:57 |
![]() 2747 forum posts 123 photos | John I am not sure if their claim that this silicon sphere (in your link below) is the roundest object on the planet. A few years ago NASA launched their 'Gravity B' satelite experiment to prove or disprove one of Einstein's theories. The sphere (spheres?) on that were about 50mm diameter and had an Earth related roundness of about 6 feet. That is about 7 times better than the Ikg standard. NASA have a web page describing the whole construction but I have mislaid my link. (I'm sure Michael G will come up with it!) Ian P https://www.youtube.com/watch?v=ZMByI4s-D-Y PS maybe the 1Kg is now the roundest ON the planet because the better ones are in orbit! |
Jon Gibbs | 26/06/2015 10:56:36 |
750 forum posts | +1 for John's suggestion including the idea of an angle grinder with an Arbortech cutter end-on initally followed up by a turboplane blade face-on for finishing cuts. |
Gray62 | 26/06/2015 13:18:00 |
1058 forum posts 16 photos | Posted by John McNamara on 26/06/2015 09:31:26:
Hi Graeme I think I would be inclined to go a different route John, not a different route at all, if you watch the video I linked to you will see that what you suggest is exactly what we are proposing to do, the machining spindle has already been prototyped and tested in a smaller scale it is just the main frame for supporting and rotating the blank that I was looking for inspiration on, As I said the rotational speed will be <100 rpm. 10 - 20 being a more realistic figure. I envisage initial mounting of the blank being between a bolted faceplate arrangement similar to that portrayed in the video and a live centre fixed to the outer end of the blank whilst the initial roughing out is done |
Clive Hartland | 26/06/2015 14:58:47 |
![]() 2929 forum posts 41 photos | Look up wood turning in Honolulu, I remember seeing a video of someone making massive wooden tubs from there. Clive |
Michael Gilligan | 26/06/2015 15:17:06 |
![]() 23121 forum posts 1360 photos | Posted by Ian Phillips on 26/06/2015 10:54:57:
NASA have a web page describing the whole construction but I have mislaid my link. (I'm sure Michael G will come up with it!) . Ian, [ Nothing personal ... you just represent a 'tipping point' ] I regret that you will be disappointed. ... I'm getting rather fed-up of that 'back-handed compliment'. MichaelG.
John McNamara | 27/06/2015 06:23:49 |
![]() 1377 forum posts 133 photos | Hi Graeme I did not watch the video, When brainstorming a design It is best to start with a clean sheet of paper. I just watched it and noted how the work was attached to the mounting plate/chuck using Angle brackets and screws. In industry when large squat pieces have to be machined the vertical lathe is often used. Have you considered this arrangement? there is a lot less counter levered weight, the work is sitting on the table. You could make a table from plasma cut say 20mm plate 1000 diameter, Under that you could place a spacer say 8mm plate 850 diameter Then a sprocket made from 12mm plate 900mm diameter. All liberally Bolted together. The 900mm sprocket has a circumference of about 2827mm If you used a 75mm sprocket you would get about 12:1 reduction that will be well on the way to providing you with a decent reduction drive. The accuracy will be fine for this type of work laser cutting is accurate to about (point) .1 mm Drawing a large sprocket in cad is not difficult. The table could have a centre ball bearing pair for location axially with support around the periphery to take the load on radially disposed ball bearings. Ideally crowned for the same reason a car back axle needs a differential, the inner and outer edge are traveling on two different diameters therefore at a different speeds. the crown having a narrow contact area greatly reduces the drag and friction. In the past I have used the inserts used in plumber blocks as a cheap source of crowned bearings. A means of preloading the table against the outer support bearings via the centre axle would be needed. Tot that hard. In the end you would have a very stiff work support. Something the arrangement in the video appears to be lacking made evident by the irregular tooling marks on the work. The drive power will be much reduced. If the spindle is truly vertical the drive will not have to lift an off centre load as it rotates. several tons of wood. Because the tool mounted on its arm is describing an arc vertically in this case it will need to be counterbalanced, not a big issue but it will need to be done. In the video the operator appears to be directly controlling the tool. Maybe a geared arrangement with automatic feed would be better? Regards Edited By John McNamara on 27/06/2015 06:33:39 |
