Richard Rogalewski | 06/05/2015 09:39:52 |
72 forum posts 14 photos | Hi. I hope this post is kosher. If I cannot source any spacers that I need, then I'll have to try to get some made. I attach a picture of the spacer, with dimentions. Originals are porcelain and are used to hold the meter board to the wall. I thought nylon would be a good substitute. If anyone is interested in making a dozen for me, then please inbox me. I was thinking to pay £1 per spacer. So, you would get £12. I'm near Wakefield, West Yorkshire. Nice if a local would make them.
Edited By Richard Rogalewski on 06/05/2015 09:40:17 Edited By Richard Rogalewski on 06/05/2015 09:41:35 |
Jon Gibbs | 06/05/2015 11:10:52 |
750 forum posts | Hi Richard, Just a hint but I think you may need to consider the cost of 1" nylon rod... Even in God's Own County it's not that cheap. Jon |
Bob Brown 1 | 06/05/2015 11:40:35 |
![]() 1022 forum posts 127 photos | Do not try to do anything with the meter it is the responsibility of the supplier electricity network operator (the company you pay your bills to is responsible for the meter and the isolation device/s is down to the electricity network operator) , if the board is falling to bits or has come away from the wall then contact your supplier. If you want it moved, again it is a job for the supplier electricity network operator, I know this as I recently had my meter moved from what used to be the kitchen to an external box. Spacers are available from electrical wholesalers like CEF. Bob |
paul 1950 | 06/05/2015 13:10:52 |
143 forum posts 32 photos | why is it when you own a machine people always want you to make something for nothing, I am often reading on forums "ask a retired engineer or hang around outside a factory and ask someone to make something in there lunch break" and in return there is the offer of a drink. I have just put a note on my gate saying I no longer make or repair anything. is it just me that gets fed up with doing things for nothing, and when you ask a favour in return and offer good money they just say they do not have the time. also if you tell anyone that wants something made to go and buy the materials they come back and say that is more than what they want to pay for the finished job. |
Russ B | 06/05/2015 13:11:23 |
635 forum posts 34 photos | Nylon also has the ability to absorb moisture |
Ed Duffner | 06/05/2015 14:24:12 |
863 forum posts 104 photos | I've installed dozens of pieces of plywood and chipboard as backing for consumer units and meter positions just using screws and Rawl plugs. Never used any kind of insulator and never had an electric board query the fixings. I think the porcelain spacers were from the sixteenth century
I'm sure you'd be ok just mounting the boards with modern day fixings Richard. Ed. |
Nick_G | 06/05/2015 14:59:38 |
![]() 1808 forum posts 744 photos | Posted by Ed Duffner on 06/05/2015 14:24:12:
What purpose do they serve anyway?
. They gave an air gap between the wall for ventilation. This stopped the timber getting damp and eventually rotting away. Of course this is not such a problem now, but in years gone by it was in some locations. e.g. in cellars of Victorian dwellings which was always a popular location for such. Farm yards and barns also spring to mind. Nick |
John McNamara | 06/05/2015 15:41:44 |
![]() 1377 forum posts 133 photos | In the past some switchboards were mounted on marble sheet fairly safe if it is dry and pure white,,, Trouble is some marble has veins of colour. possibly metallic or other conductive material. I know this for a fact as in my childhood our house had one and yes it did give a nasty shock if you touched it. it was replaced. The fuses were different too; screw on ceramic caps over two screwed conductors, no pull out fuses then. These were the bad old days. Regards |
Vic | 06/05/2015 15:44:36 |
3453 forum posts 23 photos | I made a board for the Sparks to mount a new consumer unit in my shed. I made some plastic stand offs for it but they were much simpler than that. |
Jon Gibbs | 06/05/2015 16:01:46 |
750 forum posts | If it's just a spacer which won't absorb moisture then how about these... 10 for £1.20. Jon |
Gordon W | 06/05/2015 16:20:01 |
2011 forum posts | Yes, if the wall is damp you need spacers to stop the board getting wet. I used 4 rubber door stops, the round rubber things with a hole thru'. |
Neil Wyatt | 06/05/2015 16:42:29 |
![]() 19226 forum posts 749 photos 86 articles | > I was thinking to pay £1 per spacer. To include fitting, presumably Neil |
Michael Gilligan | 06/05/2015 16:57:59 |
![]() 23121 forum posts 1360 photos | Posted by Jon Gibbs on 06/05/2015 16:01:46:
... then how about these... 10 for £1.20. . That puts the ingenuity back into engineering. ... especially if you can persuade the customer to revise his spec a little. MichaelG. |
Oompa Lumpa | 06/05/2015 17:08:45 |
888 forum posts 36 photos | Posted by Jon Gibbs on 06/05/2015 11:10:52:
Hi Richard, Just a hint but I think you may need to consider the cost of 1" nylon rod... Even in God's Own County it's not that cheap. Jon You need to buy plastic from a plastics supplier: LINK Works out at three quid for half a metre. Buy £50 and it's free shipping or I just collect as I am going past. graham. |
Oompa Lumpa | 06/05/2015 17:22:02 |
888 forum posts 36 photos | Posted by paul 1950 on 06/05/2015 13:10:52:
why is it when you own a machine people always want you to make something for nothing I would suggest you go back and read the chap's post Paul. He is not asking for them to be done for nothing, he is offering to pay and frankly £12 (plus a bit - little bit- of postage) works out at about £23 an hour if you dither. Material cost is about a pound. Doesn't sound like nothing to me. (oh, and 6p for the jiffy bag). I don't work for nothing but little jobs like this put a bit of cash in the slush fund and I usually use it to buy tooling. Works out fine to be honest. "Nylon absorbing moisture" - Really? It is that Mission Critical we are even going to consider this? Give me a break. It isn't worth considering and if we are going to consider electrocution, again, really? We have an earth I take it? graham. Edited By Oompa Lumpa on 06/05/2015 17:22:42 |
Jon Gibbs | 06/05/2015 17:57:30 |
750 forum posts | Posted by Oompa Lumpa on 06/05/2015 17:08:45:
graham. Thanks Graham - I stand corrected. Stored away for the next time I need plastic for a job. Jon |
JasonB | 06/05/2015 18:18:03 |
![]() 25215 forum posts 3105 photos 1 articles | I suppose that not everyone can just pick it up when they are passing or don't really want another £47 worth of material sitting around collecting dust which would take it back upto £9 or10 worth of material with their £6 postage. So £2 left to pay labour and postage to customer. comes back down to a couple of quid for an hours work. Can't see whats wrong with cutting a few rings of the nearest bit of plastic pipe thats knocking around myself, makes an ideal standoff when slipped over a screw. |
paul 1950 | 06/05/2015 18:32:47 |
143 forum posts 32 photos | Posted by Oompa Lumpa on 06/05/2015 17:22:02:
why is it when you own a machine people always want you to make something for nothing I would suggest you go back and read the chap's post Paul. He is not asking for them to be done for nothing, he is offering to pay and frankly £12 (plus a bit - little bit- of postage) works out at about £23 an hour if you dither. Material cost is about a pound. Doesn't sound like nothing to me. (oh, and 6p for the jiffy bag). I don't work for nothing but little jobs like this put a bit of cash in the slush fund and I usually use it to buy tooling. Works out fine to be honest. "Nylon absorbing moisture" - Really? It is that Mission Critical we are even going to consider this? Give me a break. It isn't worth considering and if we are going to consider electrocution, again, really? We have an earth I take it? graham. Edited By Oompa Lumpa on 06/05/2015 17:22:42 well make them for him or shut up, simples |
Vic | 06/05/2015 18:47:00 |
3453 forum posts 23 photos | Nice one! |
Clive Hartland | 06/05/2015 19:09:14 |
![]() 2929 forum posts 41 photos | Make items from Nylon and then boil them and they will not absorb moisture or swell! Clive |
