Simple way to control nema stepper motor
CNC QUERY
ray jones 117/03/2015 02:14:24
54 forum posts
29 photos
I am new to this stepper motor and drives board.
I am trying to set up a simple power feed to a bench mill as shown on some of theses threads.
I have one NEMA 34 MOTOR ,, Mains power unit,, Mega Arduino board and
TB 6600 Stepping motor driving board.
fitting the motor to the mill is the easy bit..
I am not looking for full CNC. All I want is power feed, ,,variable speed and forward and reverse.
Is there such a thing as a simple method to program or wire the driver and board please .
regards
ray
Steamgeek17/03/2015 07:47:24
45 forum posts
4 photos
I used one of these **LINK** with a TB6560 board and a 24 volt power supply and it works a treat.
I used it to make a cross slide power feed for my ML7, have a look in my photo album
Clive Hartland17/03/2015 08:18:18
2929 forum posts
41 photos
That site has only 1 left in stock. I too am interested in a drive controller for a mill table. are there any more alternative controllers and any info on steppers ?
Steamgeek17/03/2015 08:25:16
45 forum posts
4 photos
I spent a couple of months researching this topic and eventually turned up that device, I did not find any alternatives. What started as a relatively simple idea turned out to be quite a chore, but I have to say I am very pleased with the result. I did think about powering a rotary table for the mill using the same solution.
MM5717/03/2015 08:30:11
110 forum posts
Depends how acquainted you are with Arduino programming and electronics - if you've never done anything, there will have to be an investment in time for learning and trying..otherwise a canned commercial/semi-commercial unit may be best.
A random "tb6600 arduino" Google comes up with **LINK** - it's attached pdf looks reasonable, and the basics of the code are there, but it only sends the motor one way then the other, You would have to modify it to interface to say a three way toggle switch (left/off/right) and a potentiometer (speed adjust). If you have no clue how to do that, then there may be other Arduino examples out there that do it, or the canned unit may be best
Steve F17/03/2015 09:40:14
101 forum posts
25 photos
Ray
I think you must be hiding in my house and watching what i am doing. wink
regards
Steve
John McNamara17/03/2015 14:17:29
1377 forum posts
133 photos
Hi Ray
This little devise can pulse two stepper motor drivers (drivers not provided with the device).
I used one for a small project a while back. It worked well, I have no connection to the company.
The small buttons on it can be used directly or larger more robust buttons can be wired to it.
There is a single speed control pot that controls both motors.
Roderick Jenkins17/03/2015 15:23:28
2376 forum posts
800 photos
Posted by Clive Hartland on 17/03/2015 08:18:18:
Still available direct from Hong Kong
Very interesting: HTH
Rod
Muzzer17/03/2015 15:57:59
2904 forum posts
448 photos
To answer the OP's question, arguably the SIMPLE way is just to drive the "step" input with a train of pulses and provide the "direction" pin with a switchable (high or low) signal. Cue febrile opinions on how best to make a simple signal generator (555, bistable, Arduino, Raspberry Pi).....
The simplest (first?) program that many people run in almost any microcontroller application is the "LED blink". If you are happy to play with software, that's the basis of what you need to generate a pulse train and you can play with the time variables or set it with a control voltage (from a pot). Or you can just buy one of the boxes from the internet.
Depends if "simple" means buying something, making a simple circuit yourself or writing some software. Choices, choices...
Neil Wyatt17/03/2015 17:55:31
19226 forum posts
749 photos
86 articles
The steampunk way to control your stepper motors is with one of these:
Vibroplex
Bazyle17/03/2015 18:16:29
6956 forum posts
229 photos
As Muzzer implies it is easy to over think this with fancy computer stuff. You can even make the pulser with a little electric motor, a switch, and the model train controller you've got in that box of useful things.
What would help though is for some people to simply list the stepper motor size/type/current/ torque/voltage, gear ratio, and size of mill they are using it on with report of whether it is under/over powered.
martin perman17/03/2015 18:35:52
2095 forum posts
75 photos
Neil,
May I ask what one of them is, not to sure what I'm looking at particularly at that angle.
Thanks,
Martin P
V8Eng17/03/2015 18:55:02
1826 forum posts
Do Stepper Motors understand Morse then?
Bob Brown 117/03/2015 19:32:29
1022 forum posts
127 photos
dah dit dah dah dah
KWIL17/03/2015 19:36:33
3681 forum posts
70 photos
Nice key Neil, can you use it? Or do you make a "fist" of it?
SillyOldDuffer17/03/2015 20:11:39
10668 forum posts
2415 photos
Neil's Vibroplex post is scary-spooky because I only decided this afternoon to make a bug key as my next project! I shall have to scale the dimensions from a photo because I don't have plans or a real bug to copy. Now Neil has provided just the picture I need. That's what I call service! The man must be a mind reader...
V8Eng17/03/2015 20:49:18
1826 forum posts
Posted by Bob Brown 1 on 17/03/2015 19:32:29:
dah dit dah dah dah
That's pretty much what I expected!
Edited By V8Eng on 17/03/2015 20:49:43
dcosta17/03/2015 21:11:48
496 forum posts
207 photos
Hello Ray,
You can find **HERE** a Stepper Motor Driver.
I use one of those to control the table in my BF20 Milling Machine. See **HERE** .
Dias Costa
Clive Hartland17/03/2015 21:29:37
2929 forum posts
41 photos
There is a picture of one I made in my album, very easy to make and set up. Not used by many DX.rs now as its mostly side band voice.
The Bug key is a little more difficult to make as you need thin Phosphor bronze sheet on the armature and setting up can be quite difficult depending on the users ability to not only read morse but send fast. The weighted armature allows repetitive dots and dashes as the armature oscillates.
Les Jones 118/03/2015 16:50:13
2292 forum posts
159 photos
Hi Ray,
           This is how to program your arduino board.
Is the code you have written (Or plan to write.) in "C" or assembler ? If it is in "C" then the aduino development package compiles the code and programs the microcontroller on the Arduino board in one step. If it is written in assembler then you would use Atmel studio to asemble the code into a HEX file. You could then use your arduino board running one of the programs (Written in "C" available on the web that would make the Arduino board behave as a programmer to program a spare microcontoller of the same type as the one on your arduino board. This method will only work if the Arduino that you have uses a plug in microcontroller.
Les.
Edited By Les Jones 1 on 18/03/2015 16:55:14
Edited By Les Jones 1 on 18/03/2015 16:55:31
