Here is a list of all the postings ray jones 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: THREAD IDENTIFICATION |
30/07/2021 11:25:50 |
Hi Everyone I am repairing a very early English made cast iron fuel tank , age approximately 1910. . The drain plug is is a brass/ bronze stopper. The problem is I cant identify the thread type/ size. The stopper plug is 0.424 inches diameter x 25 TPI. My thread gauge identifies it as 25G Can anyone identify this please many thank ray |
Thread: DRO TECH QUESTION |
09/10/2020 21:17:49 |
Hi martin thank you , can you direct me to that link please? ray
09/10/2020 18:38:42 |
HI i am contemplating buying another DRO for my mill. Short of buying a very expensive unit such as a Newlall or similar, there are currently numerous china made DRO units on Ebay for less than £75. I currently have a number of magnetic reader heads all with the standard 9 pin plug. Assuming I purchased a china made unit , or any other unit with a 9 pin fitting. , what are the chances of my magntic reader heads working with a strange main unit? do they all use a similar language to comminicate.?. This question is assuming the box I may buy has the same 9 pin plug as my readr heads. thank you
Thread: TOOL BOXES |
30/06/2020 22:53:53 |
HI, I am wondering what make of tool boxes you all use. I have Britool multi drawer boxes which are excellent and also a number Wolf multi drawer Boxes. The Wolf ones are very close to the Britool quality... Short of paying SNAP on prices, which make of boxes do you all use. For several months I have tried in vain to buy more WOLF boxes, but they have totally disappeared .!!! Appreciatte your thoughts on various makes and their quality of construction. thank you |
Thread: UNKNOWN INSERT |
17/05/2020 19:45:26 |
Edited By ray jones 1 on 17/05/2020 19:48:04 |
Thread: MYFORD 254 LATHE TECHNICAL QUESTION |
05/03/2020 19:52:01 |
Hi Duncan , thank you will check my manual again . Agree we are talking feed shaft only .kind regards ray |
05/03/2020 19:07:48 |
HI , Can anyone advise me please On the Myford 254 lathe (any variant) Feed shaft from the multi speed gearbox to the saddle / apron.. When using Power feed or cross feed, as a safety measure, is the drive protected by a shear pin or adjustable slip type clutch? On some Lathes such as the Myford 280, there is a user adjustable slip clutch built into the saddle. so it acts as a safety measure , or if you are using a bed stop will trip out when the saddle reaches the bed stop.. I have checked the manual and can't find a reference to it. Appreciate the advice , thank hyou
Thread: Vertex Rotary Table equal 13 sectors |
23/12/2018 21:49:22 |
Hi yes 90 to 1 ratio. IE 1 turn of crank equals 4 degrees. Thank you ray
23/12/2018 21:36:18 |
Hi , I Need to cut a gear with 13 teeth. I have available a Vertex H/V rotary table. 13 teeth work out at every 27.692 degrees. Any advice or suggestions on the best plate to use please , many thanks ray
Thread: MYFORD 254 RACK |
27/11/2018 21:11:11 |
Hi I am working on a project and need a rack and pinion. I have discovered that the bed rack on my Myford 254 appears to be 6 TPI and only a small cross section of approximately 0.3 inches wide and 0. 625 inches deep. This would be an ideal size for my project. Enclosed is a photo of a similar rack off a Myford super 7. Can anyone suggest a supplier for one of these racks please, or indeed one off a Myford 254, or anyone breaking a 254. Thank you Edited By ray jones 1 on 27/11/2018 21:20:54 |
Thread: 3 PHASE 9 WIRE MOTOR |
26/11/2018 18:34:43 |
I Have now added photos of the Motor spec plate and wire instructions. It appears the Motor was factory pre Edited By ray jones 1 on 26/11/2018 18:35:19 |
21/11/2018 19:59:09 |
HI I have acquired a new unused milling machine, it is USA origin, the motor is 3 phase 440v / 220v dual voltage, 2 horse power. The motor has 9 wires. ( see plan sketch ) Cables are named U1, U2, U5,, V1, V2 , V5 and W1, W2 , W5. I have a standard 3 phase , 3 cable / live supply I.E. No neutral. I am trying to wire it for standard 440 Volts. not 220 volts any suggestions on which wires should be joined and which should be connected to the live feed inputs please many thanks RAY
Edited By ray jones 1 on 21/11/2018 19:59:59 |
Thread: RF 31 BENCH MILL DRILL |
06/11/2018 17:18:48 |
HI Thank you everyone for the replies and kind advice offered. The photo I listed is a generic photo I am hoping to have my mill home in a few days I will post an actual photo at the first opportunity. My quill handle is missing. I have email the manufacturer direct , but as yet not received a reply Thank you again
06/11/2018 08:47:24 |
Hi in the short term I am looking for
1/ a 3 MT DRIVE SLEEVE, It is currently fitted with R 8, BUT MT 3 is optional in the parts catalogue 2/ QUILL clamp locking lever - this is missing
Thank you ray |
06/11/2018 05:10:56 |
HI I live in WALES, Thank you ray |
06/11/2018 04:43:57 |
HI I have just purchased a RF 31 BENCH MILL. It is made by RONG FU Taiwan. It is new, unused but "shop soiled" I need a few additional parts for it. It is well made, robust and heavy weight is 600lbs + I have contacted the original supplier in USA, - -his name plate is on the machine. He says he has no european contacts and cannot help.. Does anyone know of an agent or supplier in UK or Europe I appreciate all advice thank you RAY
Thread: DANFOSS INVERTER HELP PLEASE |
12/07/2018 21:20:45 |
HI Thank you for the information, exactly what i needed. I will report back ..many thanks kind regards ray |
12/07/2018 20:23:13 |
12/07/2018 20:13:59 |
HI I HAVE A DANFOSS VLT INVERTER , 240volt input 220 volt 3 phase variable frequency output I came off a Myford Vertical Mill and is installed in a large electrical housing box. It is TYPE DANFOSS VLT 2020 195H 3104 - Without a display. Unfortunately I do not have an Instruction Manual and cannot find one. Can anyone help locate a wiring instructions/ diagram please. I Need to change the rotation of the spindle, I know i can do it on the 3 phases, but i would like to add a switchable forward/ reverse unit to the inverter see photos below Thank you in advance
Edited By ray jones 1 on 12/07/2018 20:24:57 Edited By ray jones 1 on 12/07/2018 20:25:18 |
Thread: Magnetic or optical scales for DRO |
16/02/2018 00:16:27 |
HI CHAPS I have 2 sets of DRO with magnetic pickup from EMS which I fitted 5 years ago. One is 3 axis fitted to a mill and the other to a lathe. the magnetic strips are VERY easy to cut to length. I even fitted a bit of magnetic tape onto the down spindle sleeve on the mill. They are very resistant swarf and coolant . They have worked faultlessly on every occasion. I have just ordered a third unit for another lathe. Good product, good service, very helpful and extremely knowledgable. EMS Without doubt.
