andrew winks | 09/03/2015 14:03:47 |
![]() 117 forum posts 1 photos | Hi All A topic discussed in the past but worth a revisit, I need to bend 1/8" copper for lubricator plumbing to a steam inlet tee and 3/16" for feedwater supply for a 5" gauge locomotive. i have read about filling the pipe with salt, melted solder, sand, etc but what is the most practical? Advice greatly and experience greatly appreciated. Andrew |
Michael Gilligan | 09/03/2015 14:09:12 |
![]() 23121 forum posts 1360 photos | Posted by andrew winks on 09/03/2015 14:03:47:
Hi All A topic discussed in the past but worth a revisit, I need to bend 1/8" copper for lubricator plumbing to a steam inlet tee and 3/16" for feedwater supply for a 5" gauge locomotive. i have read about filling the pipe with salt, melted solder, sand, etc but what is the most practical? Advice greatly and experience greatly appreciated. Andrew . Don't use Solder! ... You will never get it out. The proper material: 'Cerrobend' or 'Wood's Metal' melts at about 70 deg. C. MichaelG. |
Capstan Speaking | 09/03/2015 15:07:52 |
![]() 177 forum posts 14 photos | Small pipe benders are pretty cheap anyway. If the pipe isn't really new then it would benefit from being annealed first. |
Nick Grant | 09/03/2015 15:18:42 |
32 forum posts | I have used salt before but that was for an espresso machine with huge tolerances for accuracy and not what id call engineering. It works but i doubt the wall thickness in the bend was consistent or anything |
Robert Knox 1 | 09/03/2015 19:22:19 |
6 forum posts | If you have access to back numbers of Model Engineers Workshop , the August 2010 edition, Mick Knights wrote an article about a Mini Pipe Bender which works well for 1/8" and 3/16" copper pipe, I made one and it does all that he claimed. |
Muzzer | 09/03/2015 19:32:01 |
![]() 2904 forum posts 448 photos | Yes, 'Cerrobend' or 'Wood's Metal' aka "bend alloy" is pretty neat. You can embed a plastic object in it as it solidifies (how's that for a puzzle!) or just about a finger print but be aware that it contains cadmium, lead and bismuth if people are going to handle it. Being more of a fool than a plumber, I've never actually used it for bending pipes but it sounds better than the other ideas. |
Trevor Drabble | 09/03/2015 20:39:45 |
![]() 339 forum posts 7 photos | My prefered method of bending small pipes is my twin handled mini pipe bender . It does 3 -4-6 mm o.d. pipes and I find it is much more repeatable than using my mini springs . Got mine from Cromwell Tools , part number KEN 5886080K. |
Mike Hulme | 09/03/2015 21:16:07 |
13 forum posts | I use "Resin W 8" from John Neale. It is a resin and melts at 70 deg C., and contains no Cadmium. It melts out of the bent tube with boiling water, and the tube walls don't collapse on 180 deg turns. (I make Irish bagpipes, and there are a lot of bends involved!)
Mike |
andrew winks | 09/03/2015 21:36:35 |
![]() 117 forum posts 1 photos | Great advice, all! I had guessed the salt and solder methods were a bit dodgy. Some of the 1/8" bends are very tight so I think the resin idea will probably suit that better than the pipe bender. I still would like a bender for the 3/16" pipe, however. Would there be a copy of the MEW, August 2010 article available in the forum somewhere? Cheers, Andrew |
Emgee | 09/03/2015 22:46:32 |
2610 forum posts 312 photos | Hi Mike Hulme, do yo have a link to John Neale so I can get some resin W8 ? Emgee |
Kenneth Lindeman | 10/03/2015 07:20:49 |
![]() 37 forum posts 5 photos | Give this company a try They have a product called Polybend which is healthy to use http://www.bendalloy.co.uk/ and are will the sell small quantities. |
Muzzer | 10/03/2015 08:52:30 |
![]() 2904 forum posts 448 photos | £15 for 500g inc P&P. Doesn't sound too bad. |
Emgee | 10/03/2015 09:04:28 |
2610 forum posts 312 photos | Has anyone tried freezing soapy water in the pipe before making the bend ? This was on 'How do they Do it' when bending tubes for musical instruments and showed no distortion from the round when bent. Emgee |
Robbo | 10/03/2015 09:25:25 |
1504 forum posts 142 photos | Andrew, check your messages re mick knights article |
DMB | 10/03/2015 09:42:20 |
1585 forum posts 1 photos | Emgee, Why soapy water? |
Emgee | 12/03/2015 21:46:52 |
2610 forum posts 312 photos | Hi DMB When bending the ice moves in the pipe so the soap acts as a lubricant to prevent galling the surface of the copper or brass tube. |
julian atkins | 12/03/2015 21:57:34 |
![]() 1285 forum posts 353 photos |
i bend the annealed tube between my knuckle joints. as soon as it gets 'tight' i re-anneal. here's a pic of me doing same to much larger tube for the radiant superheaters for my 5"g current project cheers, julian Edited By julian atkins on 12/03/2015 21:58:15 |
DMB | 13/03/2015 11:06:58 |
1585 forum posts 1 photos | Hi Emgee, Thanks for that, its a new one on me I'll give it a try. Regards, John. |
Neil Wyatt | 13/03/2015 11:16:11 |
![]() 19226 forum posts 749 photos 86 articles | If you lot read your last MEW properly, you might have come across Field's Metal which is a safer version of Wood's Metal. www.stop4stuff.com/fields-metal/ I tend to use finger bends like Julian. It can help to use a toolmakers clamp or vice jaws gently fixed over the bend (yes it is awkward) as if the pipe is stopped from spreading sideways it is very unlikely to kink. Neil |
Circlip | 13/03/2015 11:45:07 |
1723 forum posts | Don't matter what you fill the tube with if you're trying to bend it tighter than the minimum CLR permissible for a given pipe diameter/wall thickness for a given material, especially in toy sizes.
Regards Ian. |
