Indexable lathe tools
osrix28/02/2015 00:07:01
13 forum posts
I'm looking for my first set of lathe tools
So Ive been looking at these sets:
Glanze turning parting Threading Boring & Knurling Set 5/8 Size (Ref: 977720)
Soba Turning - Parting - Threading Boring & Knurling Set 3/8 Size (Ref:977701)
And this 9 piece from rdg
http://www.rdgtools.co.uk/acatalog/9PC-Turning---Boring---Parting-and-Grooving-Tool-Set-10mm-Shank-34554332.html#SID=535
I want to be able to do some threading, a knurling tool would be useful and I intend to progress to Stainless steel in the coming months
Does anyone have any good advice on the makes and sets above, is there something else I should be looking for?
Is thicker better? I can use up to 12mm on my tool post should I be going as big as I can or is there advantage to smaller tools
The set from RDG looks good but no info on the insert size.
Any and all advice very welcome!
cheers
Ben
Jim Nolan28/02/2015 07:55:45
77 forum posts
Make sure the tips are readily available I looked at something similar recently and you could only get replacement tips from one source.
J&L, Cromwell and Cutwell all do similar offers, more expensive but the tips are industry standard.
Do you need all the tools at once perhaps consider going down the free tool if you buy X tips which most of the tool companies also offer.
Jim
Douglas Johnston28/02/2015 09:25:24
814 forum posts
36 photos
The holders are quite easy to make yourself and that way you can start by finding a source of decent inserts then make a suitable set of holders. When I started using carbide inserts a good few years ago the holders were very expensive (a lot cheaper now ) and I bought one to try it, then realised that they were not difficult to make and I have been making them ever since.
Ebay is a good place to find tips but you must be careful regarding size, tip radius and quality.
Doug
Vic28/02/2015 10:43:12
3453 forum posts
23 photos
Bigger is better for tool holders up to a point so yes, use 12mm if you can.
Vic28/02/2015 10:57:09
3453 forum posts
23 photos
http://www.jbcuttingtools.com
Is another source of supply.
Andrew Johnston28/02/2015 11:00:17
7061 forum posts
719 photos
Personally I wouldn't have anything to do with the boxed sets. You are unlikely to need all the tools; far better to buy individually. I looked into a Chronos set some years ago, but the inserts were not an industrial standard, equals unobtanium. Far better to go with standard CCMT or CCGT inserts which are widely available from multiple sources.
I have several Glanze boring bars; they seem fine to me. However the inserts that came with them were useless, so I binned them and bought brand name CCMT inserts.
Everything else is secondary to what happens at the interface between work and tool, so I have two rules regarding cutting tools:
Rule 1: Never buy cheap cutting tools; they are false economy
Rule 2: See rule 1
You'll need some HSS blanks as well. I still use quite a lot of HSS for specials.
Ian S C28/02/2015 11:19:58
7468 forum posts
230 photos
If you must use carbide tips, get good quality named tips, I use Sandvic, but there are plenty of others. HSS is probably the most economic way to go, and is suitable for most work, works ok on stainless for me.
Ian S C
osrix28/02/2015 12:40:04
13 forum posts
Thanks you all for the replies, some great information there, its a minefield for the beginner with so many types and grades of tool, but not clearly standardised by some manufacturers.
HSS should be ideal, after all I use HSS for drilling and tapping of Stainless steel, but there is a such a good press of indexable carbide tooling that Its difficult to make the right choice
I'll take a look at jbcutting tools Vic thank you.
What about cutting angle ive seen LH and RH turning tools at 93 degrees as well as 75 degrees, what does that mean to the end user, is that rate of removal and therefore more required torque and added heat to the workpiece?
Still confused but getting there! Thanks for the help so far.
Cabeng28/02/2015 12:49:54
86 forum posts
59 photos
I'm 100% with the comments from Andrew & Ian, but if these are to be your very first lathe tools, i.e. you're new to metal cutting, then I would add don't go for inserted tips, but learn with HSS first. Go straight to carbides and you run the risk of seriously damaging your bank account. Asking how I know this would be to ask a silly question!
I only ever buy tips in a SEALED box, with the manufacturer's name & tip reference on it, and preferably with the cutting data on the label. The cutting data tells you what material the tip is intended for, the range of depths of cut and feeds it is suitable for, and the cutting speeds. Without that information you are working blind when it comes to cutting metal. If the label or the seller can't provide that information, don't buy the insert(s).
Here are two I can thoroughly recommend for model engineering applications, I've used these for umpty-one years:
Turning: Sumitomo CCGT060202N-SC-T1200A
Boring: Sumitomo TPGT080202L-W-T1200A & for a larger boring bar TPGT110302L-W-T1200A
Vic28/02/2015 12:52:28
3453 forum posts
23 photos
Many of the industrial type inserts don't work well on small Lathes which is a shame as they are a similar price and often being double sided offer 6-8 cutting tips before needing to be replaced. The smaller Rhomboid style inserts which work well on small Lathes are normally only single sided so you only get two cutting tips. As said HSS is going to come in handy at some point, Cromwell have a special offer on 8% Cobalt HSS blanks at the moment.
speelwerk28/02/2015 13:22:28
464 forum posts
I use these **LINK** from Komet now for a long time, they have 3 tips with a very small radius, ideal for the small work I do. Niko.
Tony Ray28/02/2015 15:21:26
238 forum posts
47 photos
APT is another supplier that sells quality items at fair prices
osrix28/02/2015 15:54:23
13 forum posts
So what about this eccentric tool, seems like it can do it all. except internal threading?
Vic28/02/2015 19:25:11
3453 forum posts
23 photos
Posted by osrix on 28/02/2015 15:54:23:
It's a tool well worth having whether you buy one or make it yourself. Several threads on here, search for Tangential tool.
mechman4828/02/2015 20:17:36
2947 forum posts
468 photos
Posted by Vic on 28/02/2015 19:25:11:
Have one too, does most of the work I have done / do ( 90% ) easy to grind & keep sharp.
George.
MM5728/02/2015 22:28:23
110 forum posts
Posted by Cabeng on 28/02/2015 12:49:54:
Is there a UK supplier for these please?
Vic01/03/2015 10:29:44
3453 forum posts
23 photos
These are my Tangential tools. Bought one is second from the right.
Cabeng01/03/2015 11:28:45
86 forum posts
59 photos
I get my Sumitomo & Iscar inserts from H. B. Tools:
http://www.hbtools.co.uk/
KWIL01/03/2015 12:08:45
3681 forum posts
70 photos
Whilst I have used Sumitomo inserts, they are in my opinion very good, but not to the extent that you should pay any premium over Korloy, Sandvik etc.
Muzzer01/03/2015 13:09:15
2904 forum posts
448 photos
It's a little confusing to start with but the part numbering system for tool holders and inserts is fairly simple once you see how it works. The ANSI (American) and ISO (rest of the world) systems are similar but use different units of measurement naturally.
Here are examples of Tool holder nomenclature and Insert nomenclature
The different manufacturers have different grades that don't exactly equate but there are various Grade cross references
If you buy from any of the main manufacturers through reputable suppliers, you shouldn't have a problem. But there are many different grades and options, so it pays to make sure you aren't buying an oddball insert. Again, if you buy from a reputable supplier, they are most likely going to be offering fairly standard parts and grades.
The polished inserts (CCGT etc) are often recommended for light alloys but may be a good choice for turning steel in small machines.
Never used them myself but this is another UK supplier of carbide tooling.
Murray
Actually, I lie. Seems I bought some KGT inserts from them last year. Good price and fast service.
Edited By Muzzer on 01/03/2015 13:14:51
