ER25 collets to hold square material
ian j | 23/01/2015 22:37:44 |
![]() 337 forum posts 371 photos | Are ER25 collets to hold square material (say 1/4" or 3/8" Thank you. Ian |
Flying Fifer | 24/01/2015 00:03:51 |
180 forum posts | Not as far as I know. However Harold Hall did an article in MEW sometime ago about making square collets to fit normal ER collets. I made some & they certainly work. Have a look on his site I`m sure there is a reference to them on it. Alan |
Michael Gilligan | 24/01/2015 00:14:07 |
![]() 23121 forum posts 1360 photos |
Here is the page on Harold's site. MichaelG. |
Neil Wyatt | 24/01/2015 09:46:25 |
![]() 19226 forum posts 749 photos 86 articles | It's not beyond the realms of possibility that you could get someone to electrostatically machine a square hole in a standard collet. Neil |
Michael Gilligan | 24/01/2015 11:33:35 |
![]() 23121 forum posts 1360 photos | Slightly off-topic, because they wouldn't suit holding square bar-stock; but I was interested to see these ER "tapping collets" MichaelG. |
John Shepherd | 24/01/2015 11:50:43 |
222 forum posts 7 photos | Still off topic but seeing Michaels post, I did a search and found these floating tapping collets. John
Gordon W | 24/01/2015 12:06:09 |
2011 forum posts | This will be regarded with horror- I have held square stock , 6 &7mm, in the nearest round collet. May have to just knock the corners off. Not really accurate but made some small model gun axles like that. |
ian j | 24/01/2015 13:27:53 |
![]() 337 forum posts 371 photos | Thanks to all for your replies. I spotted the tapping collets some where else & very nearly brought one. but now I've seen the drawing of the ones you found Michael I can now see it would not be suitable. I will go down the Howard Hall method ( Thanks Alan) nice little project for a Winters afternoon ! Just to explain what I need them for. I have just finished (nearly) building a Bonelle T & C grinder I Have used an ER25 collet chuck with a straight shank in the work head & needed a method to hold square HHS to grind as lathe tools. Thanks again
Ian |
mick H | 24/01/2015 14:41:27 |
795 forum posts 34 photos | As has Gordon, I have no problem holding square stock in ER32 collets for machining. Accuracy is pretty good in my estimation. Obviously the 4 jaw has to come out for exact stuff. Mick |
Steve Withnell | 24/01/2015 14:53:48 |
![]() 858 forum posts 215 photos | My 4-jaw self centering chuck works very well for this application.
Steve |
jason udall | 24/01/2015 18:13:27 |
2032 forum posts 41 photos | ..er work ok on square...if four segment type..or 12 ( etc) |
Flying Fifer | 24/01/2015 21:10:47 |
180 forum posts | Ian, You`re very welcome. At the time when Harold did the original article in MEW I didn`t have any ER collets though I was seriously contemplating getting them but didn`t know which size to purchase. Studying the article & the prices of 5C square collets convinced me to go for ER32 collets mainly because they were larger than ER25 so I could make shall we say bigger square collets ( & also by the way Rectangular collets) than would be possible in the smaller sizes of ER collets. I used 12mm Sq steel bar for my collets, cutting 4 x 90mm lengths cleaning the inside 2 faces before stacking & loading in the four jaw & turning the OD to 23.5mm. I then faced off the end & turned a length of 40mm down to 19.5mm dia. I then turned a groove to accept a circlip at the shoulder. Removed 4 jaw, fitted ER chuck with 20mm collet, fitted first embryo collet into said chuck & repeated above. I then parted off in the centre of the 23.5mm dia & cleaned up the faces of the 2 embryo collets. I then stamped each jaw 1,2,3 & 4 so that I could keep the jaws in the same position in relation to each other. I repeated the above a few times so I`d have ready made blanks if I required different sizes. Must admit they have come in very handy Alan |
Harold Hall 1 | 24/01/2015 21:23:15 |
418 forum posts 4 photos | Pleased Alan that you are making good use of the idea. I like your suggestion that they can also be made to take rectangular material. I will add that idea to my web pages if thats OK, that is of course if I can find time! Harold |
Flying Fifer | 24/01/2015 21:51:12 |
180 forum posts | No objection whatsoever Harold, by all means go ahead. Hope you are enjoying your retirement !! I know I am. Alan |
Jens Eirik Skogstad | 24/01/2015 23:35:06 |
![]() 400 forum posts 22 photos | I has used both square and hexagonal bar in ER32 collet without problem. Do not use big force on ER collet to hold the square/hexagonal bar and take light cut each time to required size. |
Chris Trice | 25/01/2015 01:29:28 |
![]() 1376 forum posts 10 photos | There's a simple emergency solution with is to turn up a collar that is bored to be a good fit on the corners of the stock you're using and then slit it with a hacksaw. The collar can be held in a chuck or a collet. |
Gordon W | 25/01/2015 10:40:53 |
2011 forum posts | Just for information- my ER collets are all 8 segments, first time I've counted them. So OK for square , not good for hex.Whilst counting them I noticed one or two rags and burrs so cleaned them up. Also checked the axles I had made from square- 6mm square to 5mm dia.at each end. There is no noticable problem, no doubt a dial gauge or similar would show some. Edited By Gordon W on 25/01/2015 10:44:11 |
Graham Green 3 | 31/01/2015 11:04:56 |
18 forum posts | Gordon W has it sussed out, if the square stock can be squeezed into whatever collet, then just tighten it up and go for it. You can buy collets for square bits of material, but they are a bit on the spendy side, best just use what you have, lot's cheaper and they work on either round or square stock.
Michael Gilligan | 31/01/2015 12:56:21 |
![]() 23121 forum posts 1360 photos | Posted by Graham Green 3 on 31/01/2015 11:04:56:
... You can buy collets for square bits of material, but they are a bit on the spendy side ... . Graham, Given that the original question was specific to ER collets ... Can you please let us know where these are available ? Thanks MichaelG. |
thomas oliver 2 | 31/01/2015 13:56:46 |
110 forum posts | It is not too difficult to mathematically determine how much packing would be needed under one jaw of a 3 jaw chuck to hold square stock centrally, based on square root of 2. I have done this on occasions. |
