fizzy | 27/12/2014 19:23:17 |
![]() 1860 forum posts 121 photos | Just musing through my bath time and asked myself this question - if all things are equal would a 1/4" diameter big end (crank pin) which was 10 thou under size knock more, less or the same as a 1 inch dia crank pin, worn to the same amount? |
fastjohnrs | 27/12/2014 19:27:31 |
![]() 5 forum posts | If they have the same amount of play I'd imagine they'd knock the same, unless the difference in weight of components has a part to play, be interesting to see what other people think Edited By JasonB on 28/12/2014 07:25:54 |
S.D.L. | 27/12/2014 19:38:01 |
236 forum posts 37 photos | Posted by fastjohnrs on 27/12/2014 19:27:31: If they have the same amount of play I'd imagine they'd knock the same, unless the difference in weight of components has a part to play, be interesting to see what other people think
For any class of fit the amount of clearance or interference increases with diameter so what may be sloppy on a small shaft would be proportionally tighter on a bigger shaft. Steve.
Edited By JasonB on 28/12/2014 07:25:30 |
KWIL | 27/12/2014 19:49:16 |
3681 forum posts 70 photos | How are you defining "knock"? Loudness or frequency of the knock? Size of the component parts will change everything. Edited By JasonB on 28/12/2014 07:25:07 |
Nobby | 27/12/2014 20:27:44 |
![]() 587 forum posts 113 photos | No
Michael Gilligan | 27/12/2014 21:00:28 |
![]() 23121 forum posts 1360 photos | Posted by fizzy on 27/12/2014 19:23:17:
Just musing through my bath time and asked myself this question - . So good you asked it twice ? MichaelG.
Gary Wooding | 27/12/2014 21:31:27 |
1074 forum posts 290 photos | Well, how about a 1/10" crank pin vs a 10" crank pin? I reckon the 1/10" would knock a lot more than the 10". |
Bazyle | 27/12/2014 21:37:56 |
![]() 6956 forum posts 229 photos | Is "the same amount" 10 thou or the same as in % ? |
FMES | 27/12/2014 21:43:41 |
608 forum posts 2 photos | Could it be considered that the smaller crank pin would be fitted to an engine that ran at a much higher speed, the knock rate (frequency) would possibly be above the hearing range of the human ear, and therefore inaudible or masked by the equally annoying exhaust note
Ian P | 27/12/2014 21:53:55 |
![]() 2747 forum posts 123 photos | Which of the 'All Things' you had in mind, are equal? Maybe, radial clearance, 10 thou on both sizes or maybe the same percentage diameter reduction, (or increase if the bore is worn) I am sure you have touched on a very interesting subject but the problem needs to be better defined so that we don't wait until 1/4/2014 before replying. I think showers are better than baths, thinking time is not as long so there is less time for the ideas to be generated Ian P |
fizzy | 28/12/2014 09:43:12 |
![]() 1860 forum posts 121 photos | Like I said, all things equal, same speed, 10 thou under size on each pin.
I used to shower but 18 month olds don't like them as the duck doesn't float. |
Michael Gilligan | 28/12/2014 10:02:22 |
![]() 23121 forum posts 1360 photos | Posted by fizzy on 28/12/2014 09:43:12:
Like I said, all things equal, same speed, 10 thou under size on each pin. . Simple geometry; the smaller version will 'rattle' more. For demonstration [rather than proof] extrapolate to even larger/smaller versions. At very small sizes the fit will look "like a sausage up the Mersey Tunnel". MichaelG. |
Chris Trice | 28/12/2014 10:33:17 |
![]() 1376 forum posts 10 photos | The smaller would knock more because the angle the crankshaft will have travelled through at the top and bottom of each stroke would be greater and there would be a higher contrast of speed in the up and down direction betweent the the point the two components stopped touching each other and the moment the clearance was taken up again. |
Chris Trice | 28/12/2014 10:39:36 |
![]() 1376 forum posts 10 photos | That's assuming that the stroke and proportions of the engine were proportionally matched to the crankpin diameter but the clearance was the same in both cases. Edited By Chris Trice on 28/12/2014 11:09:23 |
Speedy Builder5 | 28/12/2014 13:52:02 |
2878 forum posts 248 photos |
Depends upon the temperature and thickness of oil and probably Reynolds number. The larger would have more anular area to squeeze out the lubricant. - Probably
Ian P | 28/12/2014 14:01:28 |
![]() 2747 forum posts 123 photos | Posted by Speedy Builder5 on 28/12/2014 13:52:02:
But Fizzy said all things were equal. To get equal conditions maybe the 1" diameter journal would be correspondingly narrower than the 1/4" one so that lubricant trapped in the annular area would be the same. Simplest would be to assume no lubricant at all. Ian P |
V8Eng | 28/12/2014 19:38:59 |
1826 forum posts 1 photos | I must say that I'm not sure exactly how relevant this is, but here goes anyway: I have always understood that a worn big end on an engine makes a deep rumbling noise, whilst a worn little end makes a lighter rattling type noise. Edited By V8Eng on 28/12/2014 19:39:28 |
John Stevenson | 28/12/2014 21:52:53 |
![]() 5068 forum posts 3 photos | Posted by fizzy on 27/12/2014 19:23:17:
Just musing through my bath time and asked myself this question .
Did you remove the coal first ? |
V8Eng | 29/12/2014 09:01:09 |
1826 forum posts 1 photos | Erratum. My last post should have read 'deep knocking noise' rather than 'rumbling' . |
Hopper | 29/12/2014 09:34:51 |
![]() 7881 forum posts 397 photos | LOL. I can tell you from experience that a Harley Davidson with its 1" crankpin worn just three thou undersize will make a knock to wake the devil. NO little model engine with a 1/4" crankpin could even come close to making the same noise. A ten thou undersize crankpin on a Harley engine would be deafening. Why? Because each Harley con rod is hammering about 35 horsepower to the crankpin, compared with 3/5 of 5/8 of a gnat's whiskerpower being delivered to said 1/4" model crankpin. Apart from that, try this: Bang together two large lumps of steel weighing several pounds each and listen to the clang. Now bang together two 5/16" nuts and compare the volume of the collision.
