Here is a list of all the postings fastjohnrs has made in our forums. Click on a thread name to jump to the thread.
Thread: One for the thinkers? |
27/12/2014 19:27:31 |
If they have the same amount of play I'd imagine they'd knock the same, unless the difference in weight of components has a part to play, be interesting to see what other people think Edited By JasonB on 28/12/2014 07:25:54 |
Thread: Model engineering clubs in Ayrshire South west Scotland |
27/12/2014 19:18:00 |
Hi thanks for your replies, seems the closest one to me is Kilmarnock or as mentioned possibly Stranraer both about 30miles from me north and south, I will enquire thanks John. |
27/12/2014 16:13:52 |
Hi is there any ME clubs local to me in south Ayrshire? Thanks John. |
Thread: Myford ml7 lathe problems |
27/12/2014 15:39:48 |
Hi guys thanks for all the advice and suggestions given, I have tightenend the spindle bearings as there was a bit of movement in the spindle due to this, also I removed the chuck and clocked the spindle it's seems to be spot on, maybe I need to true it up a bit better in the 4 jaw chuck to 0.000 thou, also I could be doing with ensuring it is level on the bench, also maybe I'm expecting to much |
26/12/2014 11:54:00 |
Hi I've been having problems with my lathe since I recently got it, it seems to be cutting material in an eccentric, I put this down to a faulty 3 jaw chuck not running true, so put my 4 jaw chuck on got some 10mm silver steel which I assume will be reasonably true/parallel, using a dti I got the material true to within 1-2 thou, I turned the chuck via the drive pulley, touched the silver steel with my cutting tool, when turning the chuck the tool was marking the material and when turned 180 it was missing the material, I'm pretty baffled by this, I hope that someone can point me in the right direction to the solution to this problem and its just me being an amateur |
