Gareth Jefferson | 30/10/2017 18:08:05 |
![]() 12 forum posts | Posted by mechman48 on 16/06/2015 09:09:59:
...'A packet of fags costs a tenner nowadays'... For our country cousins across the pond.... fags are cigarettes here... not ... George. ... not ... fags as in faggots. Engineers can be gay too, probably around 5%, as will be around 5% of readers of our fovorite magazine. Perhaps I should update my photo with a rainbow flag in the background. –– Gareth. Edited By Gareth Jefferson on 30/10/2017 18:10:14 Edited By Gareth Jefferson on 30/10/2017 18:10:55 |
Mick B1 | 30/10/2017 18:24:19 |
2444 forum posts 139 photos | Set of metric HSS drills, TiN coated, 1,5 - 10mm. Unusual grind, with a point angle around 140 degrees, facetted clearance angle and precise web-thinned point. I've drilled black mild and silver steels with the 4mm. size, and it worked well with low thrust required and even curls of swarf from both flutes. The lip looked the same after as before, and the plating was still there. As far as I can see, a decent small set of drills for £3.99. |
ChrisH | 03/11/2017 19:54:22 |
1023 forum posts 30 photos | Got another item for the "That'l Come in Handium" tool shelf today from Lidl - a cordless (once it's heated up on it's stand) Hot Glue Gun for £7.99 I think it was. Didn't have a glue gun, so thought 'this would come in handy...... ' Chris |
Neil Wyatt | 03/11/2017 20:17:01 |
![]() 19226 forum posts 749 photos 86 articles | A Japanese pull saw with two quick-release hardpoint blades of different TPI. Neil |
Bazyle | 03/11/2017 20:36:10 |
![]() 6956 forum posts 229 photos | mmmm I think traditional Japanese craftsmen would be turning in their graves at the suggestion of quick release blades .....Get a proper bench and make a bench hook then you can use a proper saw. |
IanT | 03/11/2017 21:03:49 |
2147 forum posts 222 photos | Posted by Neil Wyatt on 03/11/2017 20:17:01:
A Japanese pull saw with two quick-release hardpoint blades of different TPI. Neil Yes - I already had a set I got about a year ago but I purchased another one on Thursday (as a spare). So handy for things like cutting dowels off flush - very sharp, flexible and generally all round useful. Also affordable (at £7.99) for the handle and two blades - a recommended buy (especially when it's hidden in the Grocery bill!) Regards, IanT |
Neil Wyatt | 03/11/2017 21:17:21 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Bazyle on 03/11/2017 20:36:10:
mmmm I think traditional Japanese craftsmen would be turning in their graves at the suggestion of quick release blades .....Get a proper bench and make a bench hook then you can use a proper saw. Would they? The number of examples on Google seems to suggest otherwise, the Japanese are never shy of blending old and new technology. Neil |
not done it yet | 03/11/2017 21:28:32 |
7517 forum posts 20 photos | Aren't they a bit like ''Stephenson' s'' this and that - only these japanese pull saws likely came from china? |
Vic | 03/11/2017 21:37:43 |
3453 forum posts 23 photos | I bought a large set of screwdriver bits from Lidl a little while back for somewhere between £5 and £7 if memory serves. I saw what looked suspiciously like the same set with the Metabo brand on it for £29.99. I think I got a bargain. |
Ady1 | 14/01/2018 17:03:24 |
![]() 6137 forum posts 893 photos | The cordless drills and torque guns with separate batteries are in this week Grab 'em while you still can |
Bazyle | 14/01/2018 17:21:10 |
![]() 6956 forum posts 229 photos | Yesterday - set of 4 castors with 3" wheels for £5 and skate (those wheels plus mdf board and non slip mat (for tool box? see previous thread) for £10. A lot seems to depend on where you are and when you get there. |
daveb | 14/01/2018 17:21:59 |
631 forum posts 14 photos | Boys toys at Lidl. I bought a furniture mover at Lidl for £9.95, I think the castors would cost more on their own. My wife looked very disapproving and asked what I wanted a skateboard for. I explained what it was, she told me not to play with it with my friend as we'd both finish up with broken hips. I wondered which one of us she thinks is the bad influence, we're both over 70. |
Clive Foster | 08/02/2018 13:34:48 |
3630 forum posts 128 photos | Picked up the 5" \ 125 mm disk sander this morning for £ 30. Parkside PTSG 140 B2. Figured that it would make a nice basis for a Tiplap style tool grinder after up-gunning the tool rest and arranging a proper grinding wheel in place of the standard plain disk intended for self adhesive abrasives. Checking it out was pleased to find that it runs up nice & smooth. Even more pleased to see that the standard tool rest is decently robust for an all plastic device. Probably only needs some positive stops on the tilt adjustment and some fixed angle guides for the table to ensure same grinding angle every time. Comes with two each of 80, 150 and 240 grit self adhesive disks. Quick noodle on t'net shows that grits down to 400 are readily available so maybe it will do fine as is. A round-tu-it project right now but we shall see in due course. Clive |
Ady1 | 12/02/2018 09:29:06 |
![]() 6137 forum posts 893 photos | Got quite a lot of handy stuff in this week. Oscillating saws, offset ring spanners, mini pliers sets, washers nuts screws |
Clive Foster | 12/02/2018 12:07:20 |
3630 forum posts 128 photos | Some decent looking air tools and connector sets coming up on Sunday down my way. Could use some of the connector sets but they are PCS style rather than the PCL type I, and most other folk in the UK, use. Total bummer. But £4 ish is still good value for two swivel connectors even after binning the PCS connectors in t'box. If you do figure to change the connectors after buying the screw threads appear too be unusual. Not BSP as one would expect. The couple I did for a friend turned out to be Admiralty with 60° thread angle. Probably supposed to be something bit more rational but rather out of specification. Clive. |
Mark Rand | 12/02/2018 21:57:06 |
1505 forum posts 56 photos | Posted by Clive Foster on 12/02/2018 12:07:20:
Does that mean 1/2"x20tpi? If so, they won't fit any air tools in common use. Or is that just between the Series 25 connector and the swivel part?
Expiring minds want to know, having spent half the day recomissioning the compressor because I need to try out the plasma cutter, I've realised That I can either get a few more PCL fittings or get a few more-more Euro/series 25 fittings |
James Alford | 13/02/2018 07:07:00 |
501 forum posts 88 photos | Posted by Clive Foster on 12/02/2018 12:07:20:
Some decent looking air tools and connector sets coming up on Sunday down my way. . Clive. I bought a set of these a short while ago. I am not sure what thread they are, but they fitted with the rest of my connectors on my airline (both threads and fittings) which I bought from Screwfix, if I recall correctly. They seemed well made for the money and the swivel joint takes all strain out from the end of the hose when handling tools. James |
mick H | 13/02/2018 10:45:09 |
795 forum posts 34 photos | New Lidl just opened in Boston. Good all round shop especially fruit & vegetables for a healthy life in the workshop Mick |
Clive Foster | 13/02/2018 11:13:21 |
3630 forum posts 128 photos | Mark I think the male threads are probably supposed to be 12 mm x 1 mm. Certainly the one male thread fitting I found lying about the place is very close to that albeit a touch undersize. Given that Lidl are a German company that would be logical. That particular one probably came off one of the pressure gauge units which I promptly tapped out to 1/4 BSP to match one of my stash of PCL fittings. However I do recall making a male "Lidl" to 1/4 BSP female adapter for a friend. The thread in the air tool or accessory, dammed if I can remember what, went into a very thin wall casting so zilch chance of tapping out to BSP as requested. As I recall things the male thread was 11.5 mm or little less OD. Either intentionally undersize or poor QC. If it hadn't been nicely chromed I'd have said the undersize was plating allowance and it had missed the chrome bath. Not wishing to split the casting I had about 3 goes at it. 24 TPI A/F Dormer / SKF / Johanesson style chasers on generous 7/16 OD gave a nice fit. Firm and shake-free but no risk of splitting. I guess I'm not the only guy who tends to remember far too many of the gory details about simple jobs that turn into total nightmares with no chance of recompense for the time'n trouble. Clive |
Mark Rand | 13/02/2018 20:46:30 |
1505 forum posts 56 photos | Hmm. Have to take the thread gauges and micrometer with me when I go shopping this weekend. |
