Todays update from Bodgers Lodge
OuBallie23/11/2014 09:57:36
1181 forum posts
669 photos
Neil, Gordon,
You two have obviously never been to the Stevenson Emporium, because it would be impossible to tidy it up.
If, however, it was, JS would be totally lost and never find anything.
Reminds me of the state of my dear Dad's garage and workbench, he knew where everything was, and the marital grief that ensued after Mom dared to tidy up
Geoff - Hence my 'obsession' with organising I think.
Bob Unitt 123/11/2014 11:39:00
323 forum posts
35 photos
I went there once, best part of 20 years ago - I'll swear that bench looked exactly the same then ! wink
Although I do recall a post of John's on one of the old forums (or possibly a newsgroup) in which he claimed to have discovered something untoward underneath his feet - which was later identified as the very rare object known as a 'workshop floor'...
Gordon W23/11/2014 11:54:53
2011 forum posts
I have the answer- many years ago I went to Leicester, they had a one way system into town, but it was impossible to get out. So some sort of cosmic black-hole is building up there.
John Stevenson23/11/2014 12:51:29
5068 forum posts
3 photos
Posted by Neil Wyatt on 22/11/2014 12:57:23:
Now tidy up the bench
Cheeky bugger.
That's your cup just dumped there next to the grinder. Why should I take all the flack for your slovenly attitude ?
Answers on the back of a Chester £30 please.
Neil Wyatt23/11/2014 13:28:21
19226 forum posts
749 photos
86 articles
Fortunately my Dad never used a tea strainer, so I always leave a bit in the bottom to avoid the grouts - works with swarf too
John Stevenson09/02/2015 23:21:39
5068 forum posts
3 photos
So been a while since the last post. Still been bodging at the old lodge but all of a mutchness, one bent shaft is much like another.
However today i though this looked interesting.
Drive motor out of an older direct drive fork lift truck, these motors which drive a gearbox tend to be quite large units and this motor is around the 40 HP mark. The splines wear bad on these as they are always rocking from forward to reverse. Was toying with the idea of JB weld but not sure if it would hold up ??
Anyway chop it off and bore it out to 1" for 4 and bit inches deep, plus or minus a few microns.
Then grab a lump of EN hardaswitchestits and go hob a new spline on the end. The gear hobber is thinly disguised as a Victorian U2 universal mill with an electronic hobbing attachment that was featured in Issue 108 of MEW by Brian Thompson.
Offered up but not pressed in as a few minutes after this picture was taken it went across the road to the hardening shop, should get this back tomorrow about 10ish and it just needs pressing in with 5 gallon of loctite and drilling for a taper pin.
Whilst the hobber was setup I di two more spare shafts as these are a part that often goes.
If I remember I'll post a finished pic tomorrow.
Michael Gilligan10/02/2015 00:15:24
23121 forum posts
1360 photos
Nice job, John
It's like a watchmaker's 'pivoting' repair ... on a somewhat larger scale !!
Muzzer10/02/2015 10:38:18
2904 forum posts
448 photos
How does the taper pin work? Is the hole straight or tapered, is the pin hardened? Do you fit it with a Birmingham/Sheffield (Leicester?) Screwdriver or a press? Never fitted one of these myself.
Cornish Jack10/02/2015 11:33:57
1228 forum posts
172 photos
Absolutely gobsmacked at :-
1. The skill
2. The confidence
3. The 'design' process
4. The result
Any of that extraordinary expertise going spare, please mister?embarrassed
Rgds
Bill
Mark C10/02/2015 11:44:20
707 forum posts
1 photos
Although it is not mentioned, I suspect there is a through hole somewhere to allow the glue out when it is pressed in (you can squash the air but locktite is not as accommodating!). You also have to work fast when pressing things like this together otherwise the glue sets up before you get it in - or perhaps my glue is a bit past it's shelf life?
Mark
Neil Wyatt10/02/2015 12:01:57
19226 forum posts
749 photos
86 articles
Hi Mark,
Only John can reveal how he avoids an airlock, but I've been using Truloc high-temperature retainer for a while and it gives you a minute or three to get things aligned, then grips like a limpet.
Johnboy2510/02/2015 14:46:46
260 forum posts
3 photos
Talking about Loctite and the like - I know the manufactures say there is a shelf life attached to this stuff but I've literally had loctite donkeys year that still perform as what is says on the label but am I fooling myself? Has anyone else had this experience of the product?
P.S. John - nice job as usual!
Edited By Johnboy25 on 10/02/2015 14:48:03
Edited By Johnboy25 on 10/02/2015 14:48:43
Johnboy2510/02/2015 14:51:16
260 forum posts
3 photos
Murry... The taper pin fits into a tapered hole - usually knocked in with a Dockyard Screwdriver!
Gordon W10/02/2015 16:25:00
2011 forum posts
I have loctite structural and threadlock. I borrowed this from work about 25 years ago. As far as I can tell it still works as intended, certainly the threadlock does.
Michael Gilligan10/02/2015 16:33:02
23121 forum posts
1360 photos
Posted by Johnboy25 on 10/02/2015 14:46:46:
John,
I mentioned this on another thread, ages ago, but it's worth repeating:
More than 25 years ago, I phoned Loctite at Hemel Hempstead ... because we needed to use some "out of shelf life" 638 on a job. [Shelf life was my employer's, not theirs.]
The conversation was basically:
  • Is it still liquid?
  • Yes
  • Then it's O.K ...
I still have the remnants of that bottle, and it still does what it should.
MichaelG
Clive Hartland10/02/2015 16:37:34
2929 forum posts
41 photos
We were advised to keep it in a Fridge if it was only used occasionally. Then again I too have Loctite in the garge where it gets hot and cold and works fine.
mick7010/02/2015 16:42:37
524 forum posts
38 photos
i have some loctite that's years old and still works fine.
wish my bench was that clean.
spent last day off with my youngest 2 in shop making things.
mark costello 110/02/2015 16:46:54
800 forum posts
16 photos
We were told at a meeting that some Government (USA) agency had to have a shelf life date per regulations. So they started putting it on all products.
Mark C10/02/2015 17:03:48
707 forum posts
1 photos
Most of mine gets used reasonably quickly but some (bearing retainer and such) sits for a long time - this locks up as you might expect (although I don't know if it is a strong a bond as intended) but the "open" time that you have to position stuff seems to get shorter with age. that has been my perceived experience, I don't know about anyone else or other products. I have some "blue" coloured adhesive but I can't think what the number is without looking. This sets up almost instantly after the exclusion of air (which is what it is meant to do) but you have to be quick to get the parts together - if you are too slow it is almost impossible to dismantle again, especially if you can't heat it up!
Mark
PS. The blue glue seems to be much "thicker" these days as well which makes me think it is very slowly curing in the bottle!
Edited By Mark C on 10/02/2015 17:05:50
Maurice10/02/2015 19:16:52
469 forum posts
50 photos
I have a couple of ancient bottles of "Loctite". The older it gets, the more rapidly it seems to go off. The strength does not seem to be impaired, although I have no real way to test this. Many years ago, when "Loctite" was fairly new, our model club had a talk from a "Loctite" representative. He was quite definite that it had a shelf life, and he said that prospective stockists had to have a way to rotate their stock.
Maurice
