Tim Stevens | 30/08/2018 16:38:43 |
![]() 1779 forum posts 1 photos | If you have a rather complex marking-out task, it can help to buy a pack of six OHP pens. OverHead Projection, that is - for writing on clear film. They are better for some jobs than ordinary markers as the colour is stronger, and the marking 'point' is thinner. And of course, a pack of six gives you, well, six different colours so you can mark the stages in a job, etc, avoiding confusion. And being pen-size rather than Marker size you can carry them in an overall top pocket. Cheers, Tim |
Neil Wyatt | 30/08/2018 16:58:08 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Philip Rowe on 30/08/2018 16:09:40:
Posted by BDH on 30/08/2018 14:51:04:
Posted by Andrew Tinsley on 30/08/2018 14:21:17
I have no idea where the 'micrometer' comes into it! Brian I think it stems from a tin of engineer's blue that used to be available (might still be) called "Micrometer Brand" and the name stuck. I might even have a tin of it somewhere in the depths of my workshop. Phil 'Stuart's Micrometer Engineers Marking' I have an elderly tin and it's still available. Neil |
Trevor Crossman 1 | 30/08/2018 17:14:05 |
152 forum posts 18 photos | Yes, Peter, I use marking fluid the blue Dykem version, it isn't expensive Walters&Walters sell it at something like £15/litre. . I use an aeromodellers ''flattie'' doping brush to apply a nice even layer over each piece of bright steel as soon as it's sawn off of the oily stock length. I have never bought the spray cans which are relatively expensive nor the small bottles, it makes economic sense to by a larger size and perhaps share with someone else. For folks like me with less than perfect vision, and lacking machines with DRO, I find that it helps immensely especially in poor light conditions. It does have another very useful attribute for those of us that cannot run a fully heated workshop, in that it keeps rust at bay when working on long term projects where covering the project in oil might not be desirable. Trevor |
Andrew Tinsley | 30/08/2018 20:04:43 |
1817 forum posts 2 photos | Thanks gentlemen. So micrometer blue is just "scraping" blue. I have plenty of the stuff, having done a fair bit of scraping. I just didn't know it was referred to as micrometer blue. I thought it had something to do with micrometers which in a way I suppose it has. Andrew. |
Jon | 30/08/2018 21:21:07 |
1001 forum posts 49 photos | Used to have some White, Grey and Blue marking blue. |
Sam Stones | 30/08/2018 23:03:54 |
![]() 922 forum posts 332 photos | My two penn’orth goes like this … Up north t’other side of Manchester we called the greasy blue stuff ‘bedding blue’. (Nothing to do with nuptial discord.) On page 2 of this thread (about five years back) I related a story that went like this … When an apprentice was learning to read a Vernier [scale], bedding blue was often [discreetly] smeared inside a doll’s eye magnifier for the unsuspecting learner. Getting them to change eyes for a better look brought on more laughter. If you haven't seen a doll's eye magnifier (jeweller's loupe), they look like this. ‘Marking out blue’ is commonly used as a very quick reference by Chris of **LINK** especially when he is setting shoulder lengths on the lathe. However, as can often be seen, marking out blue will flake and rub off quite readily. For extremely fine, close up work, toolmakers in my apprenticeship era would apply copper sulphate to steel. It allowed a much sharper scribed line and, although less clear than marking out blue, the copper coating didn’t rub off easily. Sam |
NJH | 31/08/2018 16:10:04 |
![]() 2314 forum posts 139 photos | In the olden days ( back when Adam was a lad! ) I went to a new (then) secondary "Technical School". We had engineering lessons in a properly equipped mechanical workshop ( 6 lathes, two shapers, milling machine, drills, oxy/acetylene etc. For marking out there was a tank of copper sulphate solution to coat the work piece first. It was effective ( as long as the metal was cleaned first) and a very fine line was possible with a sharp scriber. Within reason, it survived the construction process! Having said that - now I use the "proper" marking out fluid or, as has been suggested, a broad tipped permanent marker pen - both work well for me though the marker is better for small bits. Norman
vernon stuttard | 01/09/2018 08:59:52 |
![]() 18 forum posts | Marker pen will leech through undercoat paints even when removed with thinners
Hopper | 01/09/2018 09:23:20 |
![]() 7881 forum posts 397 photos | Posted by vernon stuttard on 01/09/2018 08:59:52:
Yes, I've had that problem repeatedly. Amazing how persistent that stuff is. Just seems to keep coming up through the undercoat. Anyone found a cure for this? I also find that marker pen gets rubbed off by swarf and fingers during machining or drilling or whatever. Sometimes I just use a handy spray can of blue hammertone paint as marking out blue. Without undercoat or surface prep it seems to stick well for marking out purposes but is easily enough removed when its time for finish painting. Cheap as chips compared with "proper" marking blue spray too. |
Brian Wood | 01/09/2018 10:37:50 |
2742 forum posts 39 photos | Hello Hopper, A quick flash coating of emulsion paint will 'stop' the leaching through of things like rust and water staining which is another manifestation of the same effect. Brian |
Robin | 01/09/2018 11:44:36 |
![]() 678 forum posts | Layout fluid is button polish with a dash of gentian violet to make it colourful. If your bottle dries out, add metylated spirit. Gentian violet is on eBay at £20 for 10 grams, seems a bit pricy. Has a lot of Health and Safety warnings attached but people use a 1% solution to kill infections in baby's mouth. Can't both be right, can they? |
John Baron | 01/09/2018 14:24:07 |
![]() 520 forum posts 194 photos | Hi Guys, A small tube of Prussian Blue artists oil paint diluted with linseed oil and white spirit works well but it takes a long time to dry off. Though personally I prefer to use a permanent marker.
mechman48 | 01/09/2018 14:35:55 |
![]() 2947 forum posts 468 photos | I recall using Copper Sulphate when I was apprentice; then along came blue 'Layout fluid' which I used in the tool room. I also remember, when marking out on castings, using 'leaded' white wash, until the H & S gremlins came along. Didn't someone say on here that you can still get Cu sulphate solution from garden centres ? |
pgk pgk | 01/09/2018 15:04:02 |
2661 forum posts 294 photos | Posted by mechman48 on 01/09/2018 14:35:55:
.... Didn't someone say on here that you can still get Cu sulphate solution from garden centres ? I make my own bordeaux solution from copper culphate crystals and lime, both bought on ebay (to protect my citrus from fungal disease prior to their winter greenhouse quarters) Of late i've been using more layout blue despite DRO if only to help keep the gremlins away. |
larry phelan 1 | 01/09/2018 18:08:05 |
1346 forum posts 15 photos | Came across a tin of Stuarts Micometer blue,while looking for something else,so it,s still around. Bought it years ago,dont remember when I last used it. |
SillyOldDuffer | 01/09/2018 18:11:06 |
10668 forum posts 2415 photos | Quite a few disadvantages with Copper Sulphate:
Blue dye marking fluid is fast drying, safer, easily removed (apart from some plastics), and can be applied by brush to almost anything. It makes a fair fist of coating dirty metal. Much less fuss. Mind you, dropping the bottle with the cap off turns you into a smurf. I used to own a mini-lathe painted green and yellow plus many blue camouflage blotches. Got a recipe somewhere involving ground up chalk and Gum Arabic. I'll see if I can find it. Dave |
Nick Clarke 3 | 01/09/2018 18:51:28 |
![]() 1607 forum posts 69 photos | Posted by SillyOldDuffer on 01/09/2018 18:11:06:
Got a recipe somewhere involving ground up chalk and Gum Arabic. I'll see if I can find it. Some recipe! These TV cookery programmes are really getting a bit weird - bring back Delia I say! |
Pete Rimmer | 02/09/2018 14:47:45 |
1486 forum posts 105 photos | Posted by larry phelan 1 on 01/09/2018 18:08:05:
Came across a tin of Stuarts Micometer blue,while looking for something else,so it,s still around. Bought it years ago,dont remember when I last used it. Stuarts is still around but it's not layout blue, as I'm sure has already been pointed out. Layout blue dries out fully so it can be handled, engineer's blue is designed not to fully dry out, though if left on over several weeks can be a bit of a bind to remove. |
