How critical is the angle?
Stub Mandrel | 17/07/2012 20:44:02 |
![]() 4318 forum posts 291 photos 1 articles |
Posted by John Haine on 16/07/2012 21:25:31:
No one mentioned tangential tools.... I did! Neil |
chris stephens | 17/07/2012 23:17:34 |
1049 forum posts 1 photos | Hi Guys,
Just for once i am keeping out of this topic and leaving it to the other tangential disciples. chriStephens |
Peter Wood 5 | 18/07/2012 11:15:05 |
94 forum posts 11 photos | All Like Wolfie, I have struggled when making my own HSS tools. I built the HH toolrest and fitted it to work on the rim of the finer wheel of a cheap two wheel grinder. The results have been very variable and as a result I usually resort to indexable tools. This thread has contained some excellent advice and I am tempted to try again but I really need clarification on grindstones. Some have recommended cup wheels and others diamond wheels but I am far from clear on which and how to use them. 1. What grade of cup stone do I use. There is usually a confusing choice on the stands at exhibitions though they all seem to be white. 2. Where or how is the tool presented to the cup wheel. 3. Similar question for diamond wheels - ie is the cutting done on the side of the wheel in which case does it have to be mounted at the opposite end of the grinder. 4. Finally, and most importantly , what about safety ie can I simply replace one or other of the existing wheels. Peter |
Wolfie | 18/07/2012 12:12:58 |
![]() 502 forum posts | Good questions... |
David Littlewood | 18/07/2012 12:59:31 |
533 forum posts | Peter, 1 White is normal for aluminium oxide (alumina) wheels; these are perfectly normal for grinding HS tool steel - it's what I use on my grinder. Size depends on your grinder, not sure what grade is recommended, you'll have to do some research (or ask the seller, they should know). 2 Again, depends on your grinder; I use a cup wheel and this automatically gives me a flat face to use. This is far and away the most recommended way; if you use a disc wheel you shouold only grind on the periphery, which gives you a concave tool face which is weaker than it needs to be. You can in practice get away with some light finishing cuts on the side, don't tell anyone I told you. 3 Ditto (except for the bit about the side - they don't have one, you have to use cup for flat face). 4 Fitting abrasive wheels to grinders is something to be done with care; there is an HSE guide on this, probably rather paranoid, or the instructions which came with your grinder may help. Basically you need to be sure you have an arbour of the right size for the hole, and use thick paper washers to avoid cracking the wheel (VERY dangerous). With the diamond wheels referred to above there is no real problem, as they are a thin layer of diamond compound on an alloy disc or cup, no cracking problem. 5 Get hold of the Workshop Practice series book on tool and cutter grinding - it's only a few £ and will give you a good grounding (if not grinding). 6 A used Clarkson Mk1 tool and cutter grinder can be had for less than the price of the kits to make ones like a Worden, and will be far superior. David Edited By David Littlewood on 18/07/2012 13:00:49 |
gerry madden | 18/07/2012 15:10:12 |
331 forum posts 156 photos | Thanks all for your interesting input to this thread. I am 90% of the way through making an HH rest and soon to be thinking about wheels and motors. Just one point I have not seen mentioned.... what does one use to dress a diamond wheel ? Does the fact that they have metal location bores mean that runout is less and therefore dressing not necessary ? Gerry |
Robert Dodds | 18/07/2012 16:12:02 |
324 forum posts 63 photos | Peter, In addition to David Littlewood's notes on mounting wheels be sure to keep the clamping washers as matched pairs. The clamping faces will often be in the form of two annuli and the O/D and I/D of each half should match so that nothing but plain compression is applied through these faces and the thick paper washers onto the grinding wheel. Any mismatch in dimensions will potentially lead to cracking the wheel. Bob D |
colin hawes | 18/07/2012 16:13:08 |
570 forum posts 18 photos | You don't need a cup wheel to sharpen general HSS turning tools. They can be done very satisfactorily on any offhand grinder using a 60 -grit wheel even without using a toolrest. In fact it is easier to get suitable angles without the rest . Colin |
David Littlewood | 18/07/2012 19:57:27 |
533 forum posts |
Posted by colin hawes on 18/07/2012 16:13:08:
You don't need a cup wheel to sharpen general HSS turning tools. They can be done very satisfactorily on any offhand grinder using a 60 -grit wheel even without using a toolrest. In fact it is easier to get suitable angles without the rest . Colin Expect to get very hot fingers though! And Gerry, you would not (normally) need to dress a diamond wheel, in fact the abrasive layer is pretty thin and there would not be much to take off anyway. If you did, it wouldn't be difficult as the diamond dust is embedded in some fairly soft matrix material. It does perhaps mean you have to take even more care over mounting it true, as you can't true it up by dressing afterwards. David |
Peter Wood 5 | 20/07/2012 09:58:56 |
94 forum posts 11 photos | Thanks for all the advice. However I still have a question about grinding tools. I have an HH toolrest mounted in front of the grinder. I use the HH work holders to present the tool to the grindstone, partly for accuracy, and partly to keep my fingers out of harms way. However this means that the side and top rakes have to be ground on the side of the wheel!! This goes against all the safety advice. In my defence, all the photos in HH's book, Tool and Cutter Sharpening, show the side of the wheel being used. Mounting the toolrest at the side of the wheel might solve the problem but I would still have to grind the front clearance on the side of the wheel. What is the correct techniquer? Peter
David Littlewood | 20/07/2012 11:38:07 |
533 forum posts | Petr, Is there any reason why you can't fit a cup wheel? That is the "correct technique". I suspect we have all used the side of a disc wheel - I know I used to do it before I got a proper T&C grinder - but it does not do the wheel a lot of good; it is very difficult to dress it effectively to get a good surface, and places stress on it in ways it wasn't designed to take, so increasing the risk of a dangerous fracture. David Edited By David Littlewood on 20/07/2012 11:39:14 |
David Clark 1 | 20/07/2012 12:17:32 |
![]() 3357 forum posts 112 photos 10 articles | Hi Peter I have worked in many factories. I would say that in every one the side of the wheel was used to grind tools and I have never seen an exploded wheel. I have seen some that were worn to half their original thickness. I am not recomending grinding on the side of the wheel but the operator must weigh up the risks and decide for himself whether to do this. Also, bear in mind that if you grind on the side of the wheel, you don't want any end float in the spindle. When people write books and articles on engineering do they say "don't grind on the side of the wheel" because they don't do this or is it because they feel they must point out the correct and safe way? regards David
Russell Eberhardt | 20/07/2012 12:48:54 |
![]() 2785 forum posts 87 photos | Peter, The normal technique is setting the rest to a degree or two from the side of the wheel so the tool being ground is normally only in contact with the corner of the wheel as it's advanced. Sometimes however, such as for drill grinding you do use the side of the wheel but carefully - don't apply too much pressure. As everyone says though a cup wheel is better. I keep a white 60 grit cup wheel on one end and a diamond wheel on the other. Russell. |
Peter Wood 5 | 20/07/2012 12:49:58 |
94 forum posts 11 photos | David L and David C. Your two responses illustrate my dilemma. Excuse my paraphrasing but David L says don't use the side of the wheel, with a very good argument about the difficulty of dressing, as well as perceived safety. David C argues that in practice everyone does use the side of the wheel and that the risk is small. In my working career I was, for a while, in charge of H&S at a dozen large bakeries making a well known brand of bread. I soon learnt that most accidents were down to operatives doing the wrong things for the right reasons. That is they wanted to keep the job going so they took short cuts. I guess the same pressure is on people in engineering factories. Now I am not a 'jobsworth' about H&S but the best way of assessing risk or danger is by multiplying likelihood of an event against the consequences. That is when I come unstuck on this issue, because I cannot gauge the likelihood of a wheel shattering. However, end of rant. David C - how about an article in MEW on the different approaches to tool grinding ie disc wheel techniques, use of cup wheels, choice of wheels etc. Regards Peter
David Clark 1 | 20/07/2012 13:43:12 |
![]() 3357 forum posts 112 photos 10 articles | Hi Peter Yes, if someone would like to write a definitive article on tool grinding I would be pleased to publish it. I can't because all my knowledge on this subject is going into my new book. However, I will be able to add bits into Ed's Bench etc. I did a few words about the Axminster supplied grinding rest and recessed wheel recently. regards David
jason udall | 20/07/2012 14:02:07 |
2032 forum posts 41 photos | Have to add. Bench grinders and wheels..terrify me.have seen a wheel come apart .nevver want to see it again. Ok as to use of side of wheel. 1 speed not constant ..effects result 2 thining through dressing or use weaken the wheel at a point of max stress. A deep grove in middle of rim has a simular risk to the groving the side of the wheel.. 3 work piece can snatch and fly ...very much more so on the edge..( workrest) But finishing cuts on the side of the wheel are normally very light and not the risk people think.. In truth TOOL SHARPENING might be ok but roughing out and bulk removal never. Judge for your self but if wheel starts to need dressing on side then you need a new wheel BTW you do "ring " your wheels don't you ? |
Harold Hall 1 | 20/07/2012 15:07:02 |
418 forum posts 4 photos | Thanks Peter for making my grinding rest and purchasing my book Tool and Cutter Sharpening, unfortunately though you seem to have bypassed page 31. This explains, and shows in Sk 1 E, that when the tool passes down the side of the wheel it has to move at a slight angle to the wheel and actually only contacts the wheel on its corner. Similarly, if passing the outer diameter, then it also moves at a slight angle and again contacting just the corner. In theory therefore, when the tool passes down the side it cuts on the outer diameter of the wheel and moving across the front of the wheel it cuts on the side. This is clearly indicated, much exaggerated, by Sk1 C and F. In practice though, with the depth of cut only being in the order 0.01mm, and the wheel having a minute radius on its corner, it is neither. Because of this the pressure on the wheel, which is minute for T and C grinding, will no doubt be at an angle of 45 degrees, nominally. When sharpening tools they should not, ideally, slide along the face of the wheel, side or front, as this causes more heat to be generated and requires a greater force to make the wheel cut. For viewers who do not have my book, see my website on the subject of tool and cutter sharpening, especially SK1. The link to this can be found page two. I have though used different references to those in the book, SK1A is the correct method, SK1B is the wrong method. As to using the side of the wheel, the rule that this is a no no seems to be to me a rule that has been passed on from generation to generation without qualification as a result becoming absolute. Even some hand books provided by those manufacturing grinding wheels imply that it is OK for light duty tasks. For me, this means that if you have welded up an assembly and need to dress some poorly made welds, one is likely to apply substantial pressure to speed up the task and is obviously a task NOT to be undertaken on the side of a wheel. On the other hand, sharpening a drill using a drill grinding accessory will present very little pressure and is without doubt perfectly acceptable. This provided that the wheel has not been dressed on the side to a point where it is becoming dangerous anyway, say 3/4 its thickness. In the home workshop, with the limited use a grinder will get this is unlikely. I have been composing this away on my word processor before adding it here, since which I see Jason has added his contribution, to which I totally agree. Harold
David Clark 1 | 20/07/2012 15:18:28 |
![]() 3357 forum posts 112 photos 10 articles | Hi Harold Well said, common sense. I have never personally dressed the side of the wheel, they invariably run true. regards david
Edited By David Clark 1 on 20/07/2012 15:36:43 |
Peter Wood 5 | 23/07/2012 09:17:15 |
94 forum posts 11 photos | Harold Thanks so much for your posting. At last I have a clear understanding of the correct way to use the grinding wheel. I really should have gone back to your book and studied it more closely. Furthermore the photos on your web site have now clarified how a cup wheel should be used. Thanks again. Peter |
Terryd | 23/07/2012 10:37:04 |
![]() 1946 forum posts 179 photos | Hi, In defence of grinding wheels, I would say that you shouldn't be terrified of them, just read and understand their use and dangers then treat them with great respect. As for advice about grinding on the side of the wheel, that really is to prevent heavy usage such as dressing welds as Harold says, or for rapid metal removal. I have seen some really well worn wheels in industry which have been misused by some of the gorillas that use them. Personally I use a hand held grinder for that type of work with the job held firmly in a heavy vice if needed (I do it outside as I have a vice on a movable bench with normal grinders and vice) and keep my bench grinder for tool grinding. It is modified as per Harold Halls book and it works very well. Previously I used the bench grinder in it's unmodified form. Initial shaping of the tool was done on the front of the wheel as normal but I must admit to using the side of the wheel for very light final touching up of the tools cutting edges, followed by honing. Once you have a set of HSS tools ground up they should only need roccasional touching up with a fine hone and rarely need grinding except for mishaps. It is interesting (but not essential) to understand how a single point cutting tool actually removes metal - I include milling cutters in that classification as they are merely a series of single point tools. Best regards Terry Edited By Terryd on 23/07/2012 10:39:35 |
