What method do you use to find center height for your lathe bit?
John Haine27/06/2019 09:40:54
5563 forum posts
322 photos
The reason for setting to accurate centre height for me is that if, for example, the tool is slightly low and is calibrated ("touched off" to a test bar of a given diameter, then it will give an error in the cut diameter of the work at different diameters. For manual machining this doesn't matter much as you tend to measure and cut as you go, but for CNC it does. My aim is to put a tool (in its holder) on the toolpost, tell Mach 3 the tool number, and then, having referenced the lathe, be able to tell the tool what diameter to cut and it just works.
Trevorh27/06/2019 09:48:51
316 forum posts
89 photos
I use one of these and it works for me - nice and simple
regards
Trevor
Ian S C27/06/2019 12:12:56
7468 forum posts
230 photos
I have a line scribed on the blade of my 6" engineer's square, done with the point of the centre in the headstock spindle when I first got my lathe.
Ian S C
Perko727/06/2019 12:34:56
452 forum posts
35 photos
I faced off a piece of bar and measured the center height from the top of the cross-slide. I then wrote this value on the top of the cross-slide in indelible ink. I usually have a vernier caliper sitting in the tool tray so I just rest the end on the tip of the tool and drop the depth gauge to the top of the cross-slide and adjust with shims (no QCTP) until it matches the written value. This makes up for differences in grinding of the cutting edge and using tools of different size. Where possible I try to keep the right number and size of shims with each tool or tool-holder but they invariably get separated and I have to run through the whole routine again. I have a couple of tool-post blanks which I intend to machine to size and pre-mount cutting tools into, and set to the right height, so all I need to do then is swap tool-posts when I want to change tools.
Vic27/06/2019 13:00:53
3453 forum posts
23 photos
I made a simple tool.
Clive Foster27/06/2019 13:40:03
3630 forum posts
128 photos
I'm a great fan of the optical type. Simply made by fitting a suitably thick peice of perspex on a base and scribing a line at centre height on both sides.
If space is tight you can look through it rather than at it. Lines on both sides of the perspex allows you to compensate for any parallax issues. When the line looks thinnest you are looking straight on. So you can observe from a distance if need be.
Made a mirror for mine so I can look down rather than across. Also put extra lines on it so I can use it off the cross slide as well as the bed. Along with other lines for non lathe jobs.
Would have been better with 10 mm or 12 mm perspex than the 6 mm I used. But it was what I had and is good enough.
Article in one of the early MEW magazines describes one that I used as a basis. Darned if I recall the authors name tho'.
Nigel Graham 227/06/2019 16:31:57
3293 forum posts
112 photos
I'm not sure if the back-cloth is for the same purpose, but putting a sheet of white card or similar behind the lathe helps setting anything optically, too.
ChrisH27/06/2019 18:33:23
1023 forum posts
30 photos
I use an otherwise redundant vernier height gauge set at centre height. Keep it right by the lathe. Centreing tools is all it's used for. For me it's quick and easy and, due to being kept in a "specially for it" place by the lathe, always on hand.
Phil Whitley27/06/2019 18:34:55
1533 forum posts
147 photos
I eyeball it to a centre in the tailstock, but I also use the 6" rulle method. First job you do turning is to face off, so you will know if you got it right or not, or you could face off a bit of scrap bar...............but what counts as scrap in the home workshop? surely it's all metal you haven't decided a use for yet?
Former Member27/06/2019 18:48:09
1329 forum posts
Hollowpoint27/06/2019 19:14:59
550 forum posts
77 photos
I usually chuck up something with a point and then eyeball the cutter up to it then I chuck up a piece of stock and face it making fine adjusments with th QCTP.
I've always found a badly centred tool gives poor finish.
Edited By Hollowpoint on 27/06/2019 19:15:52
Bill Pudney28/06/2019 03:46:12
622 forum posts
24 photos
I have an optical centering scope, it's primary use is to locate centers on the mill, but another major use is to stick it in the tailstock and adjust tool height as indicated. Guaranteed within a small range. Very quick and easy, and having a second use for a bit of kit is always a good thing!!
cheers
Bill
thaiguzzi28/06/2019 05:55:59
704 forum posts
131 photos
All Heavyweight Stainless Steel.
Edited By thaiguzzi on 28/06/2019 05:57:00
Neil Lickfold28/06/2019 07:25:11
1025 forum posts
204 photos
I now use a piece of plastic strip. Can be made from plastic shim, or cut from a lid of an ice cream container.
I changed to plastic, as it wont damage a pcd or cbn insert. It works quite accurately for both internal or external tools or stock in a drill press or mill.
John Rutzen28/06/2019 07:58:22
411 forum posts
22 photos
I made a double ended centre height gauge, one end faces up and the other down. The refinement I have in mine is a powerful magnet fitted in the base. I got the magnet out of an old microwave oven.
Peter Spink28/06/2019 08:59:11
126 forum posts
48 photos
Posted by Vic on 27/06/2019 13:00:53:
Vic, nice toolholder - what is it?
Emgee28/06/2019 09:15:02
2610 forum posts
312 photos
Posted by Neil Lickfold on 28/06/2019 07:25:11:
Neil, is the method as others where the strip is between the tool and workpiece, a set on centre tool gives a vertical strip ?
Can't imagine how you use it for an internal tool unless at the back of the workpiece ?
Emgee
Ian McVickers28/06/2019 11:48:31
261 forum posts
117 photos
I use the scribed line on my tailstock.
Howard Lewis28/06/2019 22:04:29
7227 forum posts
21 photos
Pedant Alert!
My method is:
Place a bar of known diameter in the chuck ( I use silver steel )
Measure the eccentricty with a DTI or Finger clock (depending on how confident you are in your chuck ) I use a Vernier Height Gauge., but an adjustable pillar with ends faced square is quite acceptable, to measure off the Bed or the surface of the Cross Slide.
Note the reading.
Deduct (Half the eccentricity + half the bar diameter ) from the reading. Here "eccentricity" means the MAXIMUM .
THIS figure is your Centre Height from the Bed or Cross Slide. By whatever means you choose, Slips / Height Gauge and Clock / Adjustable pillar, (Adjusted with Micrometer, Calliper ) set your Centre Height Gauge to this dimension.
For tools mounted in the Front Toolpost, the underside of the blade should be set to this dimension.
For tools mounted in the Rear Toolpost, the tip of the tool should be set to the upper surface of a blade.
The Upper surface of a Lower blade sets the tools in a Rear Toolpost. The Lower surface of the Upper blade sets tools in the Front Toolpost. .
The time spent on this procedure, saves a lot of setting up time, and unless something moves, no pips when facing!
WHY do I only spot the errors AFTER hitting "POST"?
Edited By Howard Lewis on 28/06/2019 22:06:12
Neil Lickfold28/06/2019 22:04:29
1025 forum posts
204 photos
Posted by Emgee on 28/06/2019 09:15:02:
Emgee
Yes when vertical is on centre. And for internal is at the back of the work piece. If you have lots of holders and don't have to change tools during the making of a part it becomes not needed as they can be set from skimming the end face of some solid stock.
