1959 Nsu quickly
decals
Former Member01/05/2019 08:27:51
Robin01/05/2019 10:00:36
678 forum posts
Help, wish I hadn't started, everythings going wrong.
Edited By Robin on 01/05/2019 10:02:34
Robin01/05/2019 10:01:15
678 forum posts
Posted by Robin on 01/05/2019 10:00:36:
I found one of those NSU Quickly's in our garden shed when I was a nipper. Pedal backwards for the brake, pull the clutch lever and twist for the gears. I took it all apart, reassembled then pushed it to the track by Port Meadow leading to Oxford city dump and discovered the joys of off road powered cycling. Nearly got arrested pushing it home, if the copper hadn't been on a bicycle he might have tried harder. How times have changed.
not done it yet01/05/2019 11:40:00
7517 forum posts
20 photos
Posted by colin wilkinson on 01/05/2019 07:04:02:
Quickly, Capitanos, Capri, Norman Nippy, Raleigh Runabout, Phillips Panda, etc etc, worked on all of them in the 1960s. If you struggle for parts try the Buzzin Club. Lot of specialist suppliers in their magazine, but if you've restored it I suspect you may be a member already.
I used to dash around the fields on a Mercury Mercette moped (along with the Franny Barnett and Ariel 500) back in the early 1960s, or very late 50s. That was a good little tool for its size. The OHV four stroke engine was a super little unit apart from the push rods, which were like fine sock knitting needles. Sadly thrown in a skip about twenty years ago - not by me.
Chris_C01/05/2019 19:54:10
23 forum posts
I'd also get in touch with the NACC (their magazine is Buzzin' as mentioned above). They stock transfers, and list 3 different NSU ones at £3, £3.50 and £7 (no idea what or which a quickly would need, I'm a Cyclemaster person!)
JimmieS01/05/2019 21:45:34
310 forum posts
1 photos
Dave, why not replicate a 'Very Quickly'. Transfer style not important.
Sam Stones01/05/2019 22:44:01
922 forum posts
332 photos
Apologies Dave, I can add nothing about NSU.
Chris’s mention of Cyclemaster however, brought back a flood of memories. I clocked up many miles on my 32cc version. The main setback was those messy coupling quadrants. Made from a certain grade of rubber, if oil got to them they turned into a squishy, sticky mess.
Just before I sold it in ’56 to make way for the (no longer avoidable) OHMS invitation, I fitted the bike with a ‘long-range’ BSA Winged Wheel pannier-style petrol tank. With a pocket full of rubber quadrants and two tanks, Lands End to John O'Groats was a distinct possibility.
Sam cheeky
Edited By Sam Stones on 01/05/2019 22:45:36
Howard Lewis02/05/2019 13:29:55
7227 forum posts
21 photos
You could try The Vintage Scooter Club, in UK. They may be able to suggest a source.
Ignore the Naysayers. This Forum is here to help and advise members with a problem, (That way, we all learn something! ) not to pour cold water on them or their ideas!
Nick Clarke 302/05/2019 13:43:02
1607 forum posts
69 photos
Posted by Sam Stones on 01/05/2019 22:44:01:
Sam cheeky
Forty plus years ago I was labouring in a backstreet garage to help pay my way through university. Half buried on the scrap heap was clearly a bike fitted with a BSA Winged Wheel. Does it go? 'Too well' said the owner - 'get it out' and I saw it had a Winged Wheel fitted to each wheel - and it was apparently un-rideable to the point where the garage owner there and then took both the wheels off and dumped them as he reckoned you could not turn any corner without falling off - and he wasn't going to be held responsible!
The good news was that in the same heap was a BSA Bantam which he let me have and I did up as my first bike!
Jeff Dayman02/05/2019 17:46:13
2356 forum posts
47 photos
All kinds of good ideas and comments - but no response so far from the OP. Is he still here?
Mike Poole02/05/2019 17:52:58
3676 forum posts
82 photos
Posted by Jeff Dayman on 02/05/2019 17:46:13:
Perhaps he read the second post and hasn’t bothered to come back
Pete White03/05/2019 08:44:13
223 forum posts
16 photos
Posted by Mike Poole on 02/05/2019 17:52:58:
He did get a baptism of fire wouldn't blame him if he has gone, did you get up grumpy that day Brian? I do sometimes. lol
A great thread lots of information, I have a 1940 Rudge moped with the very popular 98 cc Villiers engine, lots of companies used them, James, Francis Barnet, will restore it one day and come back to this thread for information
Edited By Pete White on 03/05/2019 08:46:06
Baz03/05/2019 09:06:49
1033 forum posts
2 photos
Late sixties to early seventies I had a Berini M22 along with a BSA winged wheel and a couple of cyclemaster, when I got married and left home the old man, who knew the price of everything and the value of nothing took them all up the tip.
Neil Wyatt03/05/2019 11:07:06
19226 forum posts
749 photos
86 articles
Posted by Barrie Lever on 01/05/2019 08:27:51:
I use Ink jet printable water slide transfers which I buy on Ebay (Mr Decal Paper).
There are limitations with these, they really work best with a very light background (white is best), they don't have great adhesive strength.
Aftre printing I spray the whole sheet with a clear laquer, once applied I spray over them with clear laquer, this is OK for me as the models I am using them on benifit from an overall laquer finish.
Next time that I print some decals I will key the top face of the decal paper with 600-800 abrasive paper as I have had some issues with the first coat of laquer bonding to the clear carrier of the decal.
Barrie
Ink jet water slide decals
I use an initial coat of Windsor and Netown gloss spray laquer, then a few more layers of that or polyurethane spray varnish to seal and strengthen the decal before I cut it out. The W&N lacquer gives a stronger, more consistent and smooth coat than most sprays, but it is designed to be removable with solvent so it need further sealing. I've managed up to about 6" across this way.
Once applied I use whatever finish I had planned for the model.
Don't forget you can get white decal paper - but you need to cut it to the required shape.
Glyn Davies03/05/2019 11:49:35
146 forum posts
56 photos
Me and my sister on dad's NSU (photo dated 12th June 1960)
Edited By Glyn Davies on 03/05/2019 11:51:49
Enough!03/05/2019 18:27:04
1719 forum posts
1 photos
Ahead of its time with that satellite antenna on the back! wink
alan-lloyd03/05/2019 19:10:18
183 forum posts
I seem to remember they had something to do with Vincent motor cycles, probably assembled by them in Stevenage
Boiler Bri03/05/2019 19:46:47
856 forum posts
212 photos
I have just put transfers on my 5” tender. Made myself with auto-cad and a lazer printer. I am happy with them and there cheaper than Fox transfers. 🤗🤗🤗
I dont know anything about NSU. I did have a Greaves  with a Villiers 197 in it.
Bri
Edited By Boiler Bri on 03/05/2019 19:47:59
Meunier03/05/2019 20:25:11
448 forum posts
8 photos
Posted by Pete White on 03/05/2019 08:44:13:
snip I have a 1940 Rudge moped with the very popular 98 cc Villiers engine, lots of companies used them, James, Francis Barnet /snip
Triggered the memories there, Pete - my Dad's James Comet was my introduction to motor-cycling as a 14yo on quiet backroads nr Stone, Essex, on family hols.
DaveD
Edited By Meunier on 03/05/2019 20:25:50
Former Member03/05/2019 22:13:34
