Member postings for alan-lloyd
Here is a list of all the postings alan-lloyd has made in our forums. Click on a thread name to jump to the thread.
Thread: tap and die co
23/08/2023 19:42:11
Does anybody know if the Tap and Die Company in London has ceased trading, no e-mails being returned and when i phoned to place an order got a very curt no cant help
Thread: Gramophone Needles, British Made Too!
20/08/2023 19:22:11
Lots of things you thought would not be available still are, i recently bought some paraffin blow lamp prickers
Thread: cowells
24/06/2023 17:00:18
Thankyou gents, happy its not me pressed the wrong button
24/06/2023 12:52:53
Can't access cowells web site, anybody else having problems?
Thread: Myford 254 cross slide multistop
29/05/2023 18:54:23
Are there any fellow 254 owners out there that have an original Myford cross slide multistop? would someone please let me know the dimensions of the stop block, the part that locates into the cross slide T-slot? thanks
Thread: Dead-Blow Hammer Recommendations Please
06/03/2023 20:45:45
Check out Hemingways Machinists Hammer, easy to make and nicely balanced
Thread: 1960 Bullet Albion gearbox obscure item
22/01/2023 20:42:06
Is it to lubricate the clutch push rod
Thread: Cowells 90ME 14x1.5 backplate question
05/02/2022 20:47:02
Going back to the various colours, does anybody know the correct paint colour or code for the current lathes, cowells would not tell me or send any paint, most helpful!!
Thread: 7BA Grub Screws with socket (rather than slot)
09/11/2021 18:17:22
Try ba-bolts.co.uk
Thread: New Old Kerry Lathe
05/09/2021 19:28:32
We had one where I worked I made many stuart model engines on it, brilliant old lathe.Youre very lucky to pick that up
Thread: Seized stopcock
13/02/2021 19:39:13
We had the same trouble with our stop cock, the plumber recommended leaving it alone and installing a Surestop valve just after it with the switch conveniently located under the sink unit at a height we could reach easily
Thread: Surface/ Marking out plates
20/01/2021 20:05:01
Lapping plate, used to use one to lap knives for envelope machines
Thread: Cheap Ultrasonic Cleaners
18/12/2020 19:12:26
There was a thread on here about them, if I remember correctly you need one that's over 400 watts to be anygood
Thread: Tender locos for a beginner?
07/11/2020 19:21:16
You could consider the southern Q1, available parts from Polly
Thread: Stuart No 10 cylinder ports
31/10/2020 19:05:12
I'm sure back in the 70s when I made a 10v the ports were not cast in the cylinder as they are nowadays
Thread: Stuart S-50 build problem
02/10/2020 19:20:54
Phone Tracy Tools and order a long series drill
Thread: Loc Tite
15/09/2020 19:11:19
Try nail varnish remover, or print head cleaner - acitone
Thread: Claude Reeves 4 Legged Gravity Escapement Regulator
14/09/2020 19:32:31
Now that is nice, well done
Thread: Can anyone tell me what this might be?
24/07/2020 19:37:10
I believe there is a strong collectors market for vintage garage equipment
Thread: How to join?
16/07/2020 19:39:14
what make of mower is it, please?
