Recommendations for rust prevention?
Martin Cottrell25/08/2018 22:32:18
297 forum posts
18 photos
Posted by Cyril Bonnett on 25/08/2018 21:10:07:
Large wooden shed, no insulation, 5 litres of wd40, no rust, no mess. Giant spiders though.
Nothing wrong with giant spiders, very effective at keeping women away from the man-cave!!
Martin.
Mick B126/08/2018 09:42:00
2444 forum posts
139 photos
Posted by Martin Cottrell on 25/08/2018 22:32:18:
Martin.
Yeah, but they're untidy eaters, and you have to clear their insect debris away from time to time... frown
The spiders, that is... blush
Edited By Mick B1 on 26/08/2018 09:42:59
Steve Neighbour05/11/2021 16:08:34
135 forum posts
1 photos
I have used Loctite SF7803 surface treatment for some time, it is very effective at preventing corrosion, easily applied to any ferrous metal and leaves a surface film of less that a few microns.
Steve
Tim Stevens05/11/2021 18:39:59
1779 forum posts
1 photos
The fact that lanolin is good for avoiding rust is not in any way linked to the fact that you never see a rusty sheep.
Tim
David George 106/11/2021 07:47:00
2110 forum posts
565 photos
Hi Tom if you use a slideway oil preferably 60 grade on a rag and just give everything a wipe you will prevent most corrosion and you will lubricate as well. The slideway oil is sticky and stays in place but you should use an oil can of same oil on all slides and parts as well.
David
File Handle06/11/2021 08:10:43
250 forum posts
Tim
During the tupping season some do develop a rusty colour,
Peter G. Shaw06/11/2021 10:39:19
1531 forum posts
44 photos
My cure for rusting metalworking equipment is a small electric heater underneath the lathe or whatever. This works by keeping the equipment slightly warmer than ambient, hence no condensation. I use some 10W cabinet heaters from RS, but others have used self-heating tape and/or small incandescent lamp/s. There is, of course, a downside in that there is a cost, but what the heck, it saves all the messing about with WD40, slideway oil, waxes etc.
Also, especially in winter, I keep a cloth cover over the lathe (and the milling machine) and on top of that, a large piece of plastic (ditto for the milling machine). Don't know what the material is - it came from my parents many years ago. Anyway, it works for me.
Peter G. Shaw
not done it yet06/11/2021 10:55:38
7517 forum posts
20 photos
Heating, without any other precautions is not particularly environmentally sustainable. Seal all draughts, insulate and use much less heat energy (preferably operating a desiccant type dehumidifier) to avoid condensation.
Grindstone Cowboy06/11/2021 11:13:37
1160 forum posts
73 photos
Speaking of environmentally sustainable, I think I'd rather heat my machinery than what seems to be a growing trend in the USA - the electrically heated driveway!
Rob
Peter G. Shaw06/11/2021 12:16:19
1531 forum posts
44 photos
NDIY,
I do agree with you as regards the cost of heating the equipment. However, you do not know me, or indeed I suspect the OP. In my case, the costs of insulating what is actually a garage would far outweigh the costs of heating the equipment during what's left of my life (I'm 78 & have lung cancer).
I actually have three nominally 10W heaters, two on the lathe bed and fastened to it, whilst the third is fastened to a large lump of aluminium plate which in turn is wedged into the base of the milling machine. Now I have measured the current draw on the lathe, but not on the mill, so I'm assuming a similar current draw. Given that, I am taking about 57W. I admit to being shocked when I discovered just what the lathe heaters were taking, yet according to the specification, this within the parameters, their full title (at that time) being Self Regulating Cabinet Heaters. (It would seem that RS has changed their name.)
But, in fairness, I have had no more problems with rusting; no more gentle cleaning with WD40 & a bit of dead wet&dry, so all in all I think they are worthwhile. Also, looking back at my records, I first fitted them in 2005.
Cheers,
Peter G. Shaw
Michael Gilligan06/11/2021 12:33:56
23121 forum posts
1360 photos
Just out of interest … Are these the heaters that you are using, Peter ?
https://docs.rs-online.com/72dd/A700000008031247.pdf
Ref. https://uk.rs-online.com/web/p/enclosure-heaters/2257029
Edited By Michael Gilligan on 06/11/2021 12:36:06
Peter G. Shaw06/11/2021 12:43:35
1531 forum posts
44 photos
Michael,
No, the ones I have are Part No. 360-4059 and still available, but note that their name appears to have been changed since I bought mine.
Peter G. Shaw
Michael Gilligan06/11/2021 12:47:27
23121 forum posts
1360 photos
Thanks … found it yes
not done it yet06/11/2021 14:26:55
7517 forum posts
20 photos
Peter,
You are correct - we do not know each other. Neither do either of us know Tom S. My post had nothing to do with yours - there were other posts mentioning heaters prior to yours. I just try to be factual. The larger part of the UK housing stock could, I suspect, be improved with insulation - but draught-proofing still comes first. Heating costs money and energy on a continuing basis, while both the others are one-off expenditures.
Of course, draught-proofing and insulation are not, in themselves, sufficient to prevent condensation in winter - but Tom S. was also making reference to the humid summer. Draught-proofing, insulation and use of a desiccator has combined to keep my workshop rust-free at low cost. It is certainly not warm enough in the winter, without heat, but it has been cool enough for comfortable working all the summer as well (with a little dehumidifying at times).
My summer dehumidification unfortunately comes with unwanted heating, but that has not bothered me. The power has been derived from solar energy, so cost was effectively zero. During the winter months the dehumidifying/heating is from E7 and any extra heating during the day costs me at grid prices most of the time (although I am currently installing 1.8kW of PV panels at the present time).
I’m only 73 but had a difficult bypass op about ten years ago, so not in the best of health, myself. But that does not alter the facts re rust prevention.
Peter G. Shaw06/11/2021 20:48:08
1531 forum posts
44 photos
NDIY,
Sorry, I obviously came to a wrong conclusion.
Peter G. Shaw
Howard Lewis07/11/2021 19:10:15
7227 forum posts
21 photos
FWIW
East Anglia, UK
During times of frost I switch on an old 60 watt tubular heater under the "Fitting Bench" (If you can see it! )
The shop is only 10'9" x 6' 9" externally, but insulated by 50 mm glass fibre on all walls and ceiling., behind 12 mm cladding.
After a day or so, the steel bench is no longer cold to the touch, and risking being proved wrong, rust is a VERY rare event.
So, my conclusion?
Insulate really well, draught proof and low power heating will keep the temperature above the dew point, in a temperate climate.
Bazyle08/11/2021 18:26:54
6956 forum posts
229 photos
Now that we have all replaced our incandescent light bulbs with LEDs we can use them as heaters. Pity the traditional biscuit tin enclosures all went plastic however they might move back when we run out of oil.
DMB08/11/2021 20:43:39
1585 forum posts
1 photos
I glued together scrap pieces of 3-ply to make a protective wooden box to house 4 incandescent 60W bulbs in brass baton holders, wired in series, since I didn't want light, just gentle heat. In mill drip tray. Back of Myford drip tray is a 3ft tubular heater on thermostat and timer. 'Stat set as low as possible and timer currently on 6pm off 8am but adjusted around the year and time of full sun on shed. Fitting bench covered with long sheet thin plastic and all machinery covered in old (and thicker than currently used by the building materials industry) plastic sand/ballast bags. Shed roof, polystyrene sheets, walls covered in recycled 3ply and space stuffed with roof insulation wool. It was the wrapping plastic sheet for that now used to cover bench and Myford since original Myford plastic cover tore and fell apart eventually. It all works OK, no rust and I don't shiver in there!
