Ianmac | 05/07/2014 15:35:01 |
29 forum posts | Recently been bothered with unreliable injector operation which I eventually traced to the clack valve on the injector feed to the boiler (GWR 5" Pansy). Despite replacing this with a a self made and purchased unit, using both SS and Bronze balls I failed to get a perfect seal. My eventual cure was to use two clacks, one at the boiler and one fitted close to the injector. The injector now operates to my satisfaction. Looking further at this issue,I wondered if there was any mileage in using nitrile balls in these clacks. No one in my club has any enthusiasm for nitrile but cant say definitively why. Can anyone give me an opion on the use of nitrile ? |
mick H | 05/07/2014 19:21:18 |
795 forum posts 34 photos | They have always worked well for me with a perfect seal every time. I have seen it written that they might extrude into the hole that they are supposed to seal but it has not happened to me and if it did I should just replace it, possibly with a bigger ball. Mick |
mick H | 05/07/2014 21:05:16 |
795 forum posts 34 photos | Further to the above, when using a nitrile ball, I have found a note to myself to use the next size up. I think that I was advised this by the supplier. Mick |
John Baguley | 05/07/2014 21:46:21 |
![]() 517 forum posts 57 photos | I seem to recall that Nitrile balls should be used with a conical seat as the normal sharp edge seat used for metal balls can damage the soft rubber? John |
mick H | 06/07/2014 06:09:54 |
795 forum posts 34 photos | That seems like a very good idea John, and one that I shall use in the future. Mick |
Boiler Bri | 06/07/2014 07:54:42 |
![]() 856 forum posts 212 photos | I have not used nitrile, but I have used the stainless steel ball. I always give the ball a tap with a punch and hammer to seat it in the base of the valve. I put a nut on the thread and stand it on the surface plate. This works very reliably. In the BIG world of steam boilers I have neve known rubber be used anywhere? Brian
Ianmac | 06/07/2014 09:19:19 |
29 forum posts | John thanks for the hint on using a conical seat. I'll try one with a seat edge cut to as close as I can get to the angle of the ball circumference at point of contact with the clack seat. I note that there are also different hardnesses of rubber avaiable from the pro suppliers. I can only find any comment on the rubber parameters on the Reeves site but still looking Ian |
robert bailey | 07/04/2017 15:32:57 |
![]() 9 forum posts 1 photos | Re the big world of steam boilers.................Latex rubber was used extensively for the flap valves in air/steam pumps and also rhinoceros hide etc etc etc Willy Bailey
vintagengineer | 07/04/2017 17:10:16 |
![]() 469 forum posts 6 photos | Ball valves are used in hydraulic systems and if they didn't seat properly we used use a brass punch and give the ball a hefty whack! This usually sealed the valve. |
Neil Wyatt | 07/04/2017 18:37:43 |
![]() 19226 forum posts 749 photos 86 articles | Tip. Whack the ball to form the seat. Then replace the ball with on that hasn't been deformed by being whacked. |
Ian S C | 08/04/2017 11:50:38 |
![]() 7468 forum posts 230 photos | I may be wrong, but I think I read somewhere (prob ME) of someone using SS, or bronze balls, and an O-ring as the seat. Ian S C |
Brian Oldford | 08/04/2017 16:14:42 |
![]() 686 forum posts 18 photos | Posted by Neil Wyatt on 07/04/2017 18:37:43:
Tip. Whack the ball to form the seat. Then replace the ball with on that hasn't been deformed by being whacked. One of LBSC's tips from (I think) Shop, Shed and Road. It may also be in the Tich book too. |
John Baguley | 08/04/2017 16:32:32 |
![]() 517 forum posts 57 photos | I've used O ring seats for clack valves with success after seeing an article by Jim Ewins on his Loadstar locomotive. Just make sure that the O ring is retained so that it can't lift with the ball. They make good check valves for lubricator oil supplies. A commercial design of clack valve uses a poppet fitted with an O ring that seals on a flat seat. A possible alternative to stainless balls is silicon nitride (ceramic) balls. These are said to be harder than and have a better surface finish than steel. Not my idea but Roger Froud on the MECH forum is using them in his Speedy build. It will be interesting to see how they work out. John |
fizzy | 08/04/2017 17:49:06 |
![]() 1860 forum posts 121 photos | I used to use them till one got irretrievably pushed into the water pipe. I only use metal now! |
Clive India | 15/04/2017 11:06:21 |
![]() 277 forum posts | Posted by Brian Oldford on 08/04/2017 16:14:42:
Tip. Whack the ball to form the seat. Then replace the ball with on that hasn't been deformed by being whacked. One of LBSC's tips from (I think) Shop, Shed and Road. It may also be in the Tich book too. Come on folks, not a very good tip is it - and it mostly does not work well enough for me. O rings are the answer I think. Either O ring on a top hat with fluted shank or ball sitting on an O ring works best for me.
Manofkent | 15/04/2017 11:15:12 |
145 forum posts 29 photos | Can anyone recommend a Uk supplier of Viton rubber balls suitable for clack valves please? Thanks John |
Steamgeek | 15/04/2017 11:25:53 |
45 forum posts 4 photos | Nitrile balls have a habit of floating, problem becomes obvious with vertical clacks below the boiler water level when the boiler is not under pressure they will leak. Normally once pressure starts to build ( 3-4 psi ) they seal effectively. A solution to this is have a small screw in the top of the clack valve to force the ball down when not under pressure and stopping any leaks. Challenge here is to remember to unscrew it before running or you quickly start wondering why your injectors will not work. |
Steamgeek | 15/04/2017 11:28:07 |
45 forum posts 4 photos | Sorry too quick on the post button Maccs Models normally have a good supply at reasonable prices |
Clive India | 15/04/2017 11:29:21 |
![]() 277 forum posts | Polly Models stock 1/8, 5/32, 3/16 and 1/4 viton 7/32 is difficult to find in UK - try US. Edited By Clive India on 15/04/2017 11:30:03 |
Manofkent | 15/04/2017 17:24:24 |
145 forum posts 29 photos | Thanks both. Polly models has viton balls. Macc models looks like Nitrile only. Advice much appreciated. Nitrile balls are a bit cheaper. I will use them in the tender pump and axle pump. Viton have a higher temperature rating so I will use these for clacks, snifter valve and whistle valve and hope I can keep them separate from the Nitrile ones. John
