Chris123 | 16/04/2014 03:05:25 |
123 forum posts | I've been asked to make some bearing bushes for inside a roller bearing race. Is silver steel suitable? I have no experience of this!
Thanks,
Ian P | 16/04/2014 07:17:23 |
![]() 2747 forum posts 123 photos | Too many unknowns to give a sensible answer. It might be OK. My only experience is mild steel running inside a needle roller race on a car steering column. Very slow speed and very little side load. Its worked OK for 40 years but I would not consider it would be suitable for a motor. Ian P |
colin hawes | 16/04/2014 10:15:47 |
570 forum posts 18 photos | A few years ago I made silver steel rollers for hard- to- find ~80cc motorbike crowded roller bigend for a young friend and the bearing was still going strong after a year of hard work. The rollers were hardened, quenching in water, and tempered to a pale straw colour. I have made several successful less stressed bearing rollers in the same way since then for various vintage machinery repairs. Colin |
Ady1 | 16/04/2014 10:20:37 |
![]() 6137 forum posts 893 photos | From me2576 Home made roller bearing from 40cc petrol engine crankpin Rollers Outer Sleeve Conclusion Edited By Ady1 on 16/04/2014 10:24:28 |
KWIL | 16/04/2014 10:32:09 |
3681 forum posts 70 photos | Dependant upon the size of the needle roller bearings you can buy hardened insert bushes to fit, |
Oompa Lumpa | 16/04/2014 11:03:56 |
888 forum posts 36 photos | I don't think the OP was actually asking how to make rollers, more the inner bush for roller beasrings, you know, like a polo but not minty If it is a big diameter bush you may find the cost of the material a bit salty. Might want to think of alternative materials or going the case hardening route. graham. |
Ian S C | 16/04/2014 13:28:01 |
![]() 7468 forum posts 230 photos | For light use, even a mild steel pin works ok for the crank on my Ross Yoke Stirling Engine. The bearing suppliers have a (?stainless) sleeve that is Loctited on the shaft. The silver steel should give quite good service. I think I'm off course with this, I think you have a roller bearing (not needle roller), with inner and outer races, and you wish to fit it to a reduced size of shaft, mild steel would be ok, or even 4140 unheat treated, depending on the use, an aluminium bush might be ok. Ian S C Edited By Ian S C on 16/04/2014 13:33:03 |
Chris123 | 16/04/2014 22:46:03 |
123 forum posts | Posted by Oompa Lumpa on 16/04/2014 11:03:56:
Yes, this is right! its for the a rear suspension on a mountain bike linkage. so needs to be hard enough to resist compression (indentation) from forces on the rear wheel. The chap has the roller bearing race already, so a bush is needed for inside the race with a hole for the linkage bolt to go through. So polo shape as you say!
Chris123 | 21/04/2014 10:47:44 |
123 forum posts | Any ideas?! |
jason udall | 21/04/2014 12:23:48 |
2032 forum posts 41 photos | Just in case I have missed something..The roller race does or doesn't have an inner? Because if it does then all you are doing is bushing it to suit the linkage bolt?...in which case almost any steel would suffice.. But if the rollers will act on your "bush" directly then that's a horse of a different colour.. If just a bush and not in effect the inner of a race then make a fit on inner of race ( even use bearing /bush lock glue ).. |
Neil Wyatt | 21/04/2014 13:16:25 |
![]() 19226 forum posts 749 photos 86 articles | Both PGMS and unhardened silver steel have been used in the past for loco axleboxes. Surface finish is, perhaps, more important than hardness in such a role. On mountain bike there will be serious shock loads, so Imaybe one of the manufacturer's sleeves for avoidance of doubt.. Neil |
Phnug | 27/04/2014 05:15:13 |
![]() 1 forum posts | Bicycle ... So I'm thinking small bush that needs to be light and corrosion resistant. Silver Steel would work for sure but would be an unnecessarily expensive option. I concur with Jason and Ian SC above in that most common steels could be used. I cycle (not too often ... only when I can't find the lathe chuck key) and if it were me I would try a brass, bronze or aluminium (light weight) bush first and see whether it stands up to the conditions. Alternatively, a bush made of some Acetyl or Delrin would be fitted. Alternatively, steel, or you could get real fancy and use a stainless steel such as 304. It has enough strength, it looks nice and does not corrode easily, but is heavier. It depends what I had lying on the rack ... Ian
