Beaver mill
Out in the open to rust away
OuBallie18/03/2014 11:53:50
1181 forum posts
669 photos
Saw this whilst out enjoying the weather on Sunday.
Photos say it all. Album added.
Beaver turret mill
Is this what manufacturing has come to in this country and the West in general?
Geoff - makes one weep seeing this.
GarryC18/03/2014 13:32:27
740 forum posts
1043 photos
Hi Geoff
I'm afraid the answer is yes to that, very very sad indeed. I dread to think what many of the skilled generation who used such equipment and are still at work are doing for employment today, they were completely betrayed by this country - to put it politely.
Many many many of todays jobs require no skill or knowledge about anything at all - my opinion anyway. Having a skill when I grew up was respected and valued and contributed to self respect - on many different levels.
Just my two pennies worth..
Cheers.
Allan.
John Stevenson18/03/2014 13:49:06
5068 forum posts
To be honest here and this mill is a very close model to my Beaver CNC mill, in fact this one was a step up from mine being on servo's and has a tool changer they are old hat now.
It's not a question of " Is this what manufacturing has come to in this country" is more a question of things have moved on and this thing is a total dinosaur. No one who is into manufacturing with CNC could make one of these things pay today.
Not powerful enough for modern carbide tooling, too slow in spindle speeds and feeds and no enclosure to allow flood cooling.
Geoff, tiptoe past it - let it rust in piece.
S.D.L.18/03/2014 14:01:45
236 forum posts
37 photos
Best hope is it was replaced with a more up to date and capable machine.
There is still lots of machining in this country, but to compete its got to be good metal removal rates unless used on repair work.
Steve
GarryC18/03/2014 14:17:15
740 forum posts
1043 photos
I won't disagree with whats being posted so far other than to make two points.
1. In comparison to the levels of manufacturing that we used to do in this country we are barely on the same scale now. That has enormous ramifications still for many families today, my own included.
2. Yes things have moved on, nobody can stop progress of course - but we could have moved on and treated the workforce that helped to build this country with much more respect and dignity. We treat 'newcomers' to this country now far better than we have treated our own... and thats an understatement - but a fact that cannot be disputed.
I dont see many newcomers asking for the right to work being charged down by police swinging batons and fists..
I used to be proud to be british - not any more and not for a long time.
Cheers.
Allan.
Edited By Allan. on 18/03/2014 14:25:45
Tony Pratt 118/03/2014 21:01:00
2319 forum posts
13 photos
Posted by Allan. on 18/03/2014 14:17:15:
Cheers.
Allan.
Very sad indeed that you are not proud of your own country but their are many of us who are. Don't let the moronic politicians[of all parties] grind you down!
Tony
mgnbuk19/03/2014 07:47:43
1394 forum posts
103 photos
Beaver NC5 IIRC. Late '70s - early '80s most likely. I retrofitted 4 or 5 at my last employment & don't recal them being anything special - no better or worse than the Bridgeport Interacts, Matchmakers (Shizuoka carcass) Acton PowerMills (Anayak carcass) or other similar machines that were popular back then.
Most likely scenarios are that it either wore mechanically to the point that it would no longer reliably produce the desired standard of work, or (more likely) that an electronic fault occurred that would cost more to fix than the machine was worth. In the mid-'80s I retrofitted new Heidenhain controls onto all of the above named turret mills. By the mid-'90s it was no longer cost effective to do so, as the cost of new vertical machining centres had dropped substantially & the cost of a retrofit had risen substantially to the point that the retrofit was not viable. If you were to fully rebuild and retrofit that machine, it would cost more than a new vertical machining centre & the "as new" Beaver would still be short on capacity and capability compred to a new machine.
It had it's day & is now "retired" - nothing to get upset about.
Nigel B.
GarryC19/03/2014 08:15:53
740 forum posts
1043 photos
Hi Tony
Completely agree with the sentiment, but very much easier said than done when you have seen the results the politicians have caused up close. The country would have been better keeping the factories and manufacturing industry, developing it sensibly with some intelligence and getting rid of the politicians - skillless useless parasites in my view the lot of them and I won't mention the bankers less I'll likely get banned from here with the language needed... There are many scars here in the South Wales Valleys that still run very deep and will for a long time yet to come I think..
Allan.
John Jepson17/04/2014 01:07:36
2 forum posts
I have to disagree with John Stevenson..the engineering company around the corner from my workshop has one of these..it runs every day making money..they use carbide tools no problem and sits near a Hurco VMX 64 machine centre!..This would have had the Heidenhain TNC151 controller..still very usable in a job shop..the spindle motor is a Bull 7.5HP DC motor and the servos are siemens 8nm DC motors so quite powerful.
Ady117/04/2014 10:25:43
6137 forum posts
893 photos
I reckon Britain is a country plagued by incredibly bad management and a quick buck mentality
Companies like Cadbury get flogged off, companies like Mini and Land Rover get taken over by foreign managers who CAN make money. Companies like Nissan come here and use the UK workforce successfully.
The latest casualty was Manganese Bronze who make the totally unique Black Cab, (they couldn't even get that one right!)
We get rid of these management muppets if there's a war, but otherwise we're stuck with them
Now they've trashed our huge private sector industries they've been forced to move on to run things like our Education service and the Health service which are going in one direction, the only direction these people have even known, doon the pan
Edinburgh has just "bought a tram", which no-one except the ruling class morons wanted. A billion quid!
The entire city (only 350,000 people) could have had free buses for 30 years with that money
Throw your car away and use the bus for nowt... or have a tram no-one needs...
edit: And most of that money went to foreign/outside companies, the local economy received almost zero benefit and had to endure 7 years of chaos which wrecked the city centre
Edited By Ady1 on 17/04/2014 10:30:48
Ady117/04/2014 10:27:04
6137 forum posts
893 photos
Meanwhile countries with smart managers like Germany romp forwards into the future
john kennedy 117/04/2014 10:46:05
214 forum posts
24 photos
Stand for election and I'll vote for you.
Ady117/04/2014 10:50:23
6137 forum posts
893 photos
That West Coast main line contract was so rigged the ruling class morons couldn't even put their big toe into a courtroom when a judicial review was announced
(A judicial review is the nearest thing to proper open public scrutiny the government ever has to deal with)
West coast main line deal scrapped
Ady117/04/2014 10:57:55
6137 forum posts
893 photos
lol, they'd put a bullet in me
My cornerstone policy would be to demolish the entire private school system, do a dissolution of the monasteries job on them and get rid of the tribalism in the system, and have all our kids on a level playing field at comprehensives
No-one who has ever been to a private school can ever be a government minister or an MP
Then we can let the best flow out of the system to run our country, not the richest
The day after this law comes into effect I would have to resign btw
Edited By Ady1 on 17/04/2014 11:04:10
Roger Williams 217/04/2014 11:29:17
368 forum posts
7 photos
Allan, my sentiments indeed sir !. You forgot to mention the other type of parasite that seem to b***ering things up generally for the nation, Health and Safety . Dont get me going. To the OP, not a very dignified end for a machine is it.
Ady117/04/2014 12:32:28
6137 forum posts
893 photos
Britain, like India, has a caste system, social stratification, which is why both countries will always be in the slow lane of the global economy
These antiquated systems have been demolished in countries like Germany and China, countries who inhabit the fast lane
Watch China forge ahead over the coming decades, while India treads water
Stovepipe17/04/2014 13:35:17
196 forum posts
Posted by John Stevenson on 18/03/2014 13:49:06:
Quite right, John. Better move on before the dinosaurs posting on here decide they want to reactivate steam engines and horse buses.
Dwnnis
Tony Pratt 117/04/2014 18:02:10
2319 forum posts
13 photos
Posted by Ady1 on 17/04/2014 12:32:28:
Oh I wish I lived in China, I would so like to inhabit the 'fast' lane. LOL
Tony
NJH17/04/2014 20:47:23
2314 forum posts
139 photos
Great idea
Let's forget all about Health and Safety and go and live in a China like THIS
- or indeed return to the Victorian era when Britain really was Great and benevolent mill owners and their like provided full employment for all ages without the nuisance of extensive, meddling, interference from the do-gooders .
Just think too of all the dough we could save without the NHS .
N
fizzy17/04/2014 21:26:10
1860 forum posts
121 photos
they put a mega million pound tram system in a part of outer manchester I visit. Twice the cost of the bus, only one station every quarter of a mile and no one ever uses it - who could have worked that one out! The entire ruling class are soooo out of touch with reality.
