So where am I going wrong
Oompa Lumpa09/12/2013 19:17:37
888 forum posts
36 photos
I am trying to replicate a small - 22mm long 3mm diameter - adjusting screw.
Left Hand Thread. Split Die bought from RDG - Not UK Made
I have made it twice now, both times they made it to the scrap bin!
I am turning it from a piece of EN3B, down to 2.9mm the first time 3.1mm the second time. and both times I ended up with something that vaguely resembled a thread, about 2.5-2.6 mm in diameter and it fell through the threaded hole both times.
Any pointers gratefully received. I was thinking maybe the steel was too soft?
graham.
JasonB09/12/2013 19:32:51
Posted by Oompa Lumpa on 09/12/2013 19:17:37:
graham.
Is that the steel teh die is made of or the EN3Bsmile p
I did have similar problems with a 5/8x40 die from RDG a couple of months back and ended up screwcutting it on the lathe
J
blowlamp09/12/2013 19:45:15
1885 forum posts
111 photos
A problem I've experienced is that either one or more of the securing-screw holes in the die-holder, or the 'dimples' around the die are not aligned, so when they're tightened down they tend to distort the die and make it cut a horrible thread. It might be worth your while to check it out.
Martin.
Oompa Lumpa09/12/2013 19:47:02
888 forum posts
36 photos
Posted by JasonB on 09/12/2013 19:32:51:
graham.
J
I did think it just might be the Die Jason
Snag is that it is 3mm AND left hand thread.
Bugger.
graham.
Oompa Lumpa09/12/2013 19:54:35
888 forum posts
36 photos
Posted by blowlamp on 09/12/2013 19:45:15:
Martin.
This is why I love this place. Great thinking Martin and certainly a possibility.
I was just thinking myself there - always a danger - could it be that the die is also faced? What I mean is, there is no lead in on one side?
graham.
Ady109/12/2013 19:55:00
6137 forum posts
893 photos
I got my best results by roughing most of it out on the lathe, then finishing with a die
If I wanted a nice tight thread, I never used a die, the ones I have always overcut a bit too much
No doubt they cut "within acceptable tolerances", but still too much for the more precise scenarios
Edited By Ady1 on 09/12/2013 19:55:47
old Al09/12/2013 19:59:04
187 forum posts
EN3B will tear a bit, but you should get better than you have done.
Are you using any tapping fluids.
Are you using a tailstock dieholder, if not are you using something behind the die to keep it square.
EN3B allows you to have a second stab at it, so you can open up the die, take a cut and then close down the die for a second cut. Don't try this in stainless.
Is the die, carbon steel or HSS
Oompa Lumpa09/12/2013 20:37:50
888 forum posts
36 photos
It's not cutting within any tolerance Ady, it's turning the screw down from 3.1mm to 2.5 mm and unable to function as a screw..
Al, yes I use cutting fluid and a Die stock holder. Rather, I hold the Die in a Die stock and then against the tailstock, it works well and I have always done it this way with 100% success. I suspect the die is carbon steel. Also tried the light cut/heavier cut scenario you describe.
Doyou think it's worth buying another die? Left hand - 3mm?
graham.
jason udall09/12/2013 20:48:00
2032 forum posts
41 photos
Split die. Are you spreading the die.?
Left hand tread. Just possible you forgot and turned wrong way ? Also does your chuck unscrew..
Edited By jason udall on 09/12/2013 20:50:29
Tony Pratt 109/12/2013 21:37:26
2319 forum posts
13 photos
From my own experience these budget dies do have 'issues', they do a job but not always very well. If you turned the job the wrong way as suggested the left hand die wouldn't go on. Try turning to 2.9 mm and have a nice 45 deg. chamfer on the end, open up the die for the first pass, hold it in a tail stock die holder if possible, use cutting oil and not too fast on the spindle speed.
Tony
Versaboss09/12/2013 22:13:30
512 forum posts
77 photos
Posted by Oompa Lumpa on 09/12/2013 20:37:50:
Hmm, Graham, did you forget to let the lathe running backwards for the left hand thread??? devil
Hansrudolf
old Al09/12/2013 22:14:22
187 forum posts
I had something from Tracy Tools do something odd once. They exchanged it straight away. Good customer service. See what RDG say before shelling out on another.
Gordon W10/12/2013 10:53:49
2011 forum posts
With a small dia. thread there is a lot of metal to bend when opening the split. It may be that cutting grooves, with a thin cutting disc, will allow the die to open a bit more. I've done this with some success, but not if the die is going to be returned!
Oompa Lumpa10/12/2013 15:30:27
888 forum posts
36 photos
This:
"turning to 2.9 mm and have a nice 45 deg. chamfer on the end, open up the die for the first pass"
and This:
"and shouldn't be overtightened. In fact, I only ever use one screw, not all three"
worked for me.
Opening the die - quite a bit actually - has stopped it 'overcutting' the small rod i turned. I now have a workable thread. Bit of a result really as I really didn't want to be shelling out for a new HSS die and hoped the steel one would work. It can now go into the drawer for the next millenia to come along when I might need it again.
This is the problem when you are spoiled with first class kit and you buy something "on the cheap" just to get you away on a job. I really should know better. Not to worry, something else I have learned. Bit of a result really.
graham.
Andrew Johnston10/12/2013 16:07:40
7061 forum posts
719 photos
Posted by Oompa Lumpa on 10/12/2013 15:30:27:
graham.
If it was mine it'd be going straight into the bin. thumbs down
Rik Shaw10/12/2013 16:28:12
1494 forum posts
403 photos
In a perfect world do this:
Put a "good" split die in the holder and use the centre screw to slightly spread the die. Cut the thread. Use a die nut to remove the last little bit down to size. Works for me every time (Where I have a die nut the correct size that is).
Rik
