Here is a list of all the postings Versaboss has made in our forums. Click on a thread name to jump to the thread.
Thread: NALON VIPER 2.5 CC DIESEL |
19/09/2023 14:40:48 |
All sorted now, thanks to Roy I have now the Viper plans. As I expected, studying these brought up a couple of questions. Certainly there will be more when the work really starts! In sheet 1, crankcase: what does the expression 0.005" witness mean in practical machining terms? In sheet 2, crankshaft: how can the counterweight be machined (in the form as drawn) when the crank pin is in the way? Or is the pin pressed in, but not shown as such? In sheet 4, cylinder: how is it possible to drill a #33 hole (2.9 mm ) at an angle of 25 °? Might be possible with a 3 mm slot mill, but that would be too large then? Or using 2.5 mm and then opening out a bit? I started to read through the couple of Viper threads, including the long one from 2019 (what the Google search brings up). I saw a building report from someone, but that ended just when the cylinder machining would becoming interesting. I can't find that thread atm, lost again a couple of hours in searching. Kind regards,
15/09/2023 22:26:26 |
Ramon, thanks for your offer. It seems Roy can help me, and I think "the others from the Motor Boys e book" would be too much for me to digest. I'm lucky if I manage to finish that Viper, I think I'm in the same age range as you! Kind regards |
15/09/2023 22:14:46 |
Roy - I went to adriansmodelaeroengines.com, a very interesting place but no downloads to find there. The links give error messages, 403 forbidden. Unfortunately also no email address. I have a candidate here for the wotizit page. I will send you a pm, with many thanks |
14/09/2023 23:04:14 |
I hope it's ok to continue this thread, albeit it is not (yet) about building a Viper. But my problem is that I could not find out how to get the plans. I somewhere saw that they are available at modelenginenews.org, and emailed [email protected]. But I think now that's a dead site, as I did not get a response. Directly on that site, there is only stuff from 2002 to 2013. Now I' at a loss. Can someone here tell me where these plans can be bought? Regards, |
Thread: Is a hammer on a surface plate worse than leaving a chuck key in? |
19/08/2023 11:18:42 |
At least I think it is not a scraped surface plate. Maybe more suited for tinplate bashing. Regards. |
Thread: What did you do today? 2023 |
18/07/2023 23:17:14 |
Hmm, almost a bit concerned about disturbing Nigel's efforts, but here is something not really from today, but from the last couple of weeks. I built a scraping machine. You know, perhaps, that it is possible to buy one, But the prices, even for used ones, are way over my budget. Some years ago I tried to make such a machine from an old sabre saw, but it was much too wobbly and finally I gave up. Then I saw a short report from someone who built a scraper from an old angle grinder, and even with using some 3D printed parts. So I bought the cheapest (used) angle grinder I could find, and went to work.What I didn't see in the seller's picture was that the head of that grinder was not a casting, but a plastic part. But this was the smallest problem. My first difficulty was to remove the axle from the bevel gear. With much ddifficulties I finally managed that, and could then modify and shorten the axle. A new housing was turned from an aluminium bar, and a steel round with a slot served as holder and guide for a variable eccentric. A scotch yoke moves the scraping tool, and the whole apparatus has room in a piece of square alu tube. Well, that's it, in a nutshell Oh, I almost forgot to mention that the machine does not run on grid power (that would be MUCH TOO fast!), Kind regards, Edited By Versaboss on 18/07/2023 23:20:27 |
Thread: A Leeuwenhoek microscope project |
30/05/2023 10:41:08 |
SK, would it be possible to take a photo through your microscope? I would very much like to see what you see, iykwIm! Regards, |
Thread: Grit value for honing carbide tools |
01/05/2023 22:51:24 |
I think it is important to know here that the coarseness of diamond wheels is not given in the same numbers as other grinding wheels. The usual system goes from small numbers = coarse to big numbers = fine. So grit 100 is (much) coarser than grit 1000. In diamond (and CBN) it is the other way round. Usually the grit is preceded with a D (or B for CBN). The numbers are in steps, which I can't write down out of my head, but: But as with most things, there are exceptions. I have a couple of Chinese grinding discs (galvanic bound on 1 mm steel, 120 mm dia.), which use the grit system. Mine go from 800 to 3000. They are wonderful to hone carbide scraping blades, and naturally turning tools also. Used on a very slow grinder, driven from a windscreen wiper motor. Regards, Postscript: polishing lathe tools with a felt disc and polishing compound is nonsense... Sorry for being so blunt. Edited By Versaboss on 01/05/2023 22:53:30 And one more: found a list of the grit sizes here: Edited By Versaboss on 01/05/2023 23:01:25 |
Thread: TurboCAD Query: Maintaining Rendering Acrss File-types? |
14/04/2023 23:05:39 |
It was quite entertaining to read (again) the almost unbelievable mental topsyturvifications (*) of Mr. Graham. But, as it seems, only a human tutor can eventually lead him out of his misery, why not doing that 'over the 'net'? There is a small program called Teamviewer. Maybe there are others, but that's what I used in my professional life. With its help, a tutor can log in into the pupil's computer and guide him as if they were in the same room. I'm sure colleague Andy could do that. But I fear that Mr. Graham would immediately dismiss such dangerous things. Not in his lifetime would he allow a stranger having access to his computer. (*) A nice word I found in the Leo translator program, I hope it's appropriate. I take my coat... Hans |
Thread: Simple case hardening recipe |
30/03/2023 18:10:55 |
Posted by SillyOldDuffer on 30/03/2023 11:38:47:
... carbon to diffuse into an Iron surface by heating the two in contact at about 2000°C for quite a long time.
Well, that's very interesting. I always thought Iron at 2000°C would have the viscosity of running water. So they had a method to keep the original form after the case hardening? Regards, |
Thread: Help, please, selecting some Electronic Components |
16/03/2023 22:33:51 |
Hallo Michael, I cannot see from the text above who the “corresponding author” is, but I know with high probabilityy who Susan Parker is. She is a (not very active) member of the model engineering mailing list, and also the constructor of a very high end audio amplifier. If you need to know more, I might be able to find an email address. Kind regards, |
Thread: Removing masking tape |
01/03/2023 12:07:06 |
Then there is Limonene, aka Orange oil. I use it (among others) for removing address and other labels on cardboard boxes, which I keep for reuse. Just let it dry for a couple of hours, before going to the post office... Oh, and I use it also for cleaning the build platform of my 3D Printer. Regards,
Thread: Sandvik corona c45 tool steel~ anyone have a good memory? |
17/02/2023 12:16:56 |
C45 is not an HSS steel. I have some rectangular bars in my workshop. It's a steel for building jigs and such things. Copied and translated from the net: The material 1.0503 is also known as steel C45 and complies with DIN EN 10083-2 as well as the American standard AISI 1045. It is a non-alloyed quenched and tempered or structural steel that is characterised by a very uniform material structure. Regards, |
Thread: Electrolysis of water |
16/02/2023 22:32:53 |
A couple of days, I hit upon a YouTube film where someone explained that it is possible to electrolyse water with a much smaller energy input than what science taught up to now. I for myself, thought that the energy is a fixed value for a certain amount of water. The method as described worked with something like agitating the water with a piezoelectric element. The claim was, iirc, about 15 times higher efficiency. Be it as it is, I don't really believe that. But I wanted to see what chatGPT knows, and here are the answers: First question The amount of energy required to electrolyze 1 kg of water depends on several factors, such as the voltage and current used, the efficiency of the electrolysis process, and the temperature and pressure of the system. However, we can make an estimate based on the standard enthalpy change of electrolysis of water at standard conditions (25°C and 1 atm pressure), which is 286 kJ/mol. The molar mass of water is approximately 18 g/mol, so 1 kg of water contains approximately 55.6 moles of water. Therefore, the energy required to electrolyze 1 kg of water at standard conditions can be estimated as: 286 kJ/mol x 55.6 mol = 15,933.6 kJ To convert kJ to kWh, we can divide by the number of joules in one kilowatt-hour (3,600,000): 15,933.6 kJ / 3,600,000 = 4.43 kWh So, it would require approximately 4.43 kWh of energy to electrolyze 1 kg of water at standard conditions. Note that in practical applications, the actual energy required may be higher due to various inefficiencies in the process.
My second question; Yes, there are several ways to reduce the amount of energy required to electrolyze water. Here are a few examples:
In summary, by optimizing the various factors involved in the electrolysis process, using renewable energy sources, using alternative electrolytes, and using advanced materials, it is possible to significantly reduce the amount of energy required to electrolyze water. What do our scientists say? Regards, Edited By Versaboss on 16/02/2023 22:35:10 |
Thread: And again a mystery item! |
25/01/2023 22:23:36 |
Nick, you are right, a part of the left foot is broken away. But it does not hamper the usage of the item. As I wrote, it is VERY difficult to arrange a point or cross exactly between the lines. For my picture, I tried certainly more than 5 minutes until I was halfway satisfied. When it is an optical centre punch, then I would call it 'not fit for purpose' ! Thanks, and regards |
25/01/2023 12:01:47 |
In the course of a much-needed clean-up, I came across the following device. I no longer have any idea how and when it came into my possession; perhaps the optics interested me. As you can see, the device consists of an optical system, which, unlike a magnifying glass, reverses the image. With the pin on the side, you can pull up and fix a movable hammer. Pressing the trigger releases the hammer and the small conical tip punches a dot into the base. There is no scale in the optics, so it is probably not a hardness tester. As an optical centre punch it is too inaccurate, as the example in the last picture shows. Also, it is very difficult to place a cross line exactly between the lines in the optics. ..... ..... ..... .... ..... Any ideas what it could be? I was a bit lazy and used Deepl translator; I think it (he?) makes a good job. Regards, |
Thread: Temperature sensor DS 18B20 |
04/01/2023 11:28:38 |
As I have a project with the Dallas DS18B20 on a (very slow) back burner, I would very much like to know how Mr. AnOther connected the (3-wire) chip to the (4-wire) telephone cable. Was it just as simple as leaving one wire unconnected? Inquiring minds... Hans |
Thread: Cad software for dummies. |
16/12/2022 14:49:17 |
Thanks, Pete, I can fully agree. But it is a shame that many people don't even try Onshape, because it is 'in the cloud'. It would cost them only a few clicks, and if they don't like it, just forget it (no deinstall necessary). Season's greetings. Hans |
Thread: Surface plate |
23/11/2022 22:56:19 |
Maybe a bit late in this discussion, but there are some things which I find hard to believe. Mr. Souza wrote in his first post that he has porcelain tiles"...from my bathroom remodeling and they are 80 cm x 80 cm..." In another post, he wrote that his tiles have the same thickness as a granite kitchen top. In short, I can't believe that until I can see it, and I wonder why not one of our usual sharp eyes took notice of that. Regards, Edited By Versaboss on 23/11/2022 22:57:23 |
Thread: What do our publishers think we are about ... ? |
26/10/2022 15:10:32 |
Want some more strange stuff? In issue 317, bottom left of the first page ("On the Editor's Bench" ) you can read:
These two lines are repeated in every issue since then. So they did the whole bunch in June? Regards, edit: deleted that dreaded smiley Edited By Versaboss on 26/10/2022 15:11:28 |
