Decent vernier height gauges ?
ronan walsh14/11/2013 18:18:45
546 forum posts
32 photos
I want to buy a decent quality vernier height gauge for general marking out. Having a look on fleabay etc i see there are a lot of chesterman and shardlow height gauges on there for reasonable prices, are they good quality ? I would rather buy a good quality older one than a half baked bit of far eastern junk , if you know what i mean.
Does anyone have any input ?
Nobby14/11/2013 18:43:09
587 forum posts
113 photos
HI Ronan
If you do buy an H.Gauge make sure that the scriber can reach the surface plate to read zero . some height gauges dont do this. The job/part has to be put on parallels take a reading etc
They may be more input on this.
Nobby
Mike Poole14/11/2013 18:48:11
3676 forum posts
82 photos
I own a shardlow and like the fine adjusment engaged at the flick of a lever, I have used Chesterman also and both are good quality tools.
Swarf, Mostly!14/11/2013 19:44:23
753 forum posts
80 photos
Hi there,
Chesterman are a good old British make. However, if you buy one, make sure that it comes with the scriber and clamp - they are as rare as hens teeth!
Best regards,
Swarf, Mostly!
Steve Withnell14/11/2013 19:49:46
858 forum posts
215 photos
Just got one from ARC. Perfectly serviceable for the home workshop.
Danny M2Z14/11/2013 21:05:56
963 forum posts
G'day.
Although far eastern, but not junk, it's hard to go past a Mitutoyo.
Regards from the land of the kangaroo
* Danny M *
jonathan heppel14/11/2013 21:24:28
99 forum posts
Most of those old timers were top quality. I suggest you look for a satin chrome or stainless one. Bear in mind speed of use- that's where the digital or dial ones score, particularly with a complex layout
It's wise to regard any electronics as essentially disposable, even premium brands.
Rotagrip advertise a reasonable looking twin column dial type.
Me? I use an APE microball, which is yet another style.
Just trying to cover a few bases!
Edited By jonathan heppel on 14/11/2013 21:32:02
Tony Pratt 114/11/2013 21:39:42
2319 forum posts
13 photos
Posted by Nobby on 14/11/2013 18:43:09:
HI Ronan
Nobby
Hi Nobby,
I have to confess as an apprentice I made a 'dog leg' scriber to get round this problem, another one of those tools we made to hone our skills and now consigned to my tool chest under the stairs. I personally now use a digital height gauge at home.
Tony
ronan walsh14/11/2013 23:00:33
546 forum posts
32 photos
Posted by Danny M2Z on 14/11/2013 21:05:56:
G'day.
* Danny M *
Mitutuoyo is not junk by any stretch of the imagination danny, but the prices take some swallowing though. What i meant was stuff of indeterminate origin and quality. Some of the tools i have bought, that i know were cheaper far eastern has been disappointing. I usually prefer secondhand professional tools , even if they are overkill sometimes.
WALLACE14/11/2013 23:24:39
304 forum posts
17 photos
Personally, I'd go for a non digital one. That way you know it will never have a flat battery and will never stop working !
W.
Michael Gilligan14/11/2013 23:41:24
23121 forum posts
1360 photos
Posted by WALLACE on 14/11/2013 23:24:39:
W.
By definition, a Vernier height gauge should not be digital
Clive Foster14/11/2013 23:42:44
3630 forum posts
128 photos
Like Jonathan I prefer the APE Microball type as I find the micrometer adjustment easier to read than a conventional vernier. Ageing eyes! For a normal vernier consider fitting a magnifier on a wire arm, it does help. Mitutoyo made some with a magnifier but, unfortunately, most of the ones so fitted are of indeterminate make although all those I have seen are clearly Mitutoyo copies.
The digital approach has its advantages but I can't be doing with the battery issue. Mind you I do have around 30 micrometers and a dozen or so verniers (one day I'll have a proper count!) about the place! Imperial and metric up to 12 inches / 300 mm including depth and internal soon add-up. A couple of 50 mm travel, sub micron resolution Heidenhain probes meet my digital needs.
Brian Warwick15/11/2013 00:33:29
30 forum posts
Posted by jonathan heppel on 14/11/2013 21:24:28:
WHY?
To me that's a strange statement, I do not wish to be offensive but I am totally at a loss as to why anyone would make such a wild statement with no explanation.
Bill Pudney15/11/2013 01:35:14
622 forum posts
24 photos
I too use an APE Microball. The micrometer adjustment is excellent, highly recommended.
cheers
Bill
Jo15/11/2013 08:25:22
198 forum posts
If you have a height vernier and are missing the scriber then M-DRO will sell you a replacement. I recently picked up one from them for my 24" Chesterman, ok it had a metric width but a little tickle with a milling cutter on each side of the shank took it to the right size. The scriber will not reach the surface plate on that one, only on the diddly little 12" ones.
One thing to look out for: My 12" Mitutoyo has a really useful magnifier lens mounted above the scale to help read the vernier guage. I must make one for the larger Chesterman.
Jo
Flywheel15/11/2013 08:35:00
34 forum posts
watched a tv program recently about the Rolls Royce factory building the Trent jet engines, noticed some Mitutoyo equipment in their factory, so if it's good enough for them its good enough for me!
Peter
Bill Pudney15/11/2013 08:55:53
622 forum posts
24 photos
Posted by Flywheel on 15/11/2013 08:35:00:
Peter
I'm not saying that Mitutoyo do not make top quality gear, because they clearly do. However I wouldn't count on the "whats good enough...." routine too much. The likelihood is that RR prepared a list of the equipment required, along with the standards required and sent it to 3 or 4 suppliers. Then they bought the cheapest package.
cheers
Bill
Brian Warwick15/11/2013 09:47:07
30 forum posts
Posted by Bill Pudney on 15/11/2013 08:55:53
cheers
Bill
chances are you are wrong in implying RR buy on price while I am certain they are careful with their money the SPECIFICATION will state what is fit for purpose and Accuracy and Reliability will be key factors
Clive Foster15/11/2013 09:58:31
3630 forum posts
128 photos
The disposable nature of modern electronics is, regrettably, an established fact due primarily to the main electronics gubbins being concentrated into model specific integrated circuits for which no spares are available. Even if you could extract the offending object given that the internal circuit boards are of minimal dimensions and designed for robotic assembly. Some of the premium brands may offer servicing but, realistically, the labor costs involved in stripping, cleaning, replacing the gubbins and rebuilding end up pretty comparable to simply buying a new widgit outright. Mass production makes things very cheap to build.
In principle you could make your own old style micrometer or vernier. No chance with the electronic version. I have a good idea how optical scales can be made and the readout electronics involved due to being associated with research laboratory efforts to build our own way back before commercial offerings appeared. Late 1970's I think. What we built was just about within home shop capability but it was big, bench mount, not hand. TTL & CMOS integrated circuits. No micros then.
For modern gear if cleaning and new batteries don't fix it you are pretty much stuffed although sometimes a display can be changed.
Whats really annoying is that the inexpensive stuff is made just that bit too cheaply so short life is certain due to things like processors inadequately sealed by a dollop of epoxy and so on. Whilst the good stuff market is limited so price is high.
jonathan heppel15/11/2013 10:25:52
99 forum posts
Posted by Brian Warwick on 15/11/2013 00:33:29:
WHY?
Not wild at all When they go wrong they are frequently either impossible or uneconomic to repair, particularly when a few years old. No different than most modern electronics. Check out Long Island Indicator Repair for authoritative though not infallible advice.
I'm not suggesting you shouldn't buy electronics, just not to treat them as heirlooms, My Mit calipers gave up after ten years or so of sterling service, so I bought new ones. That's it in a nutshell.
