Tony Jeffree | 07/11/2013 17:23:48 |
![]() 569 forum posts 20 photos | Take a look at this: Admittedly, the 3D printer used in this exercise cost half a million bucks, so it won't be available for hobby use any time soon, but it demonstrates very nicely just how accurate 3D printing can be, and also that the technology is capable of printing objects using more durable materials than plastic. Regards, Tony |
Thor 🇳🇴 | 07/11/2013 19:22:50 |
![]() 1766 forum posts 46 photos | Impressive results from that printer. Is this what we will have in our workshop in 10 years? Thor |
Springbok | 07/11/2013 19:36:04 |
![]() 879 forum posts 34 photos | hopefully not makeing guns Bob |
Speedy Builder5 | 07/11/2013 19:46:23 |
2878 forum posts 248 photos | Yes, guns are a bit 'Old Hat' now, but did you see 'Embarasing Bodies' on Tuesday eve.. - The man with half a face. Here was a patient who had half his face eaten away by cancer. Cheek, jawbone pallet etc etc. By use of 3-D printing, surgeons made a replica scull with bits bits missing, then making the missing bits. From these models, it was possible to make a a skeletal jaw 'bone' with teeth, pallet and last of all half a face including a false eye. Not perfect but a hell of a leap for the poor guy. |
Springbok | 07/11/2013 20:18:22 |
![]() 879 forum posts 34 photos | Wow Speedy Bob |
WALLACE | 07/11/2013 20:19:07 |
304 forum posts 17 photos | I can't see all the furore on printing a gun - they're not exactly difficult to knock up on the average lathe and mill ( I would imagine !). Years ago, my Dad turned up a model cannon at work - couldn't resist the temptation and charged it up with flash powder and a ball bearing. Which apparently embedded itself into the opposite wall.... W. |
David Jupp | 07/11/2013 22:06:14 |
978 forum posts 26 photos | Mostly it's simply that mentioning guns has proven to be an effective way to generate publicity/hype around 3D printing... much easier to get on the TV than most of the serious and technically interesting things it gets used for.
ken king, King Design | 07/11/2013 23:11:19 |
![]() 144 forum posts 239 photos | If you want a much more interesting and, for us model engineers, meaningful application of a variety of 3D technologies I suggest you google 'building the Miller race car' or very similar title. Sorry I can't provide a direct link at present, but promise that if you're interested in seeing what can be done, you will find the search worthwhile. Plenty of food for thought in this one. If you find it let's have your reactions. This is a fascinating technique, particularly now that very durable metallic prints can be made, plated etc. |
Springbok | 08/11/2013 07:37:19 |
![]() 879 forum posts 34 photos | here is link bob |
Springbok | 08/11/2013 07:53:39 |
![]() 879 forum posts 34 photos | All I now need is the dosh |
Tony Jeffree | 08/11/2013 09:02:37 |
![]() 569 forum posts 20 photos | Posted by WALLACE on 07/11/2013 20:19:07:
I can't see all the furore on printing a gun - they're not exactly difficult to knock up on the average lathe and mill ( I would imagine !). The point isn't that they made a gun - not at all interesting from my point of view to be able to make a gun - but it gives you some clues as to what the technology could be used for. If you can produce a metal gun barrel in a 3D printer and it is strong enough to withstand repeated firing with live rounds, then it isn't exactly a massive leap of the imagination to consider using the same technology to print a ready-bored cylinder block for an IC or steam engine, plus pistons with piston ring grooves, complete camshafts, .... etc. Download the plans, print the parts, job's a good 'un. Yes, as pointed out in the video, there is inevitably going to be a degree of finishing work needed on the printed parts, but even so, the potential uses are very interesting indeed, especially if they could reduce the size of the price tag by a couple of orders of magnitude. Given that you can now buy CNC laser cutters/engravers for an affordable (for the hobby user) price, it shouldn't be much of a stretch to build a laser-based printer for £5k, say that could print metal parts. Maybe not this year, but I would be very surprised if it isn't a reality in the next few years. Regards, Tony |
jason udall | 08/11/2013 12:22:08 |
2032 forum posts 41 photos | Maybe 3d printer might be nice project?... Enough mechanical build and electronics to be interesting even if some would turn there noses up at plastic filament build. . |
David Clark 1 | 08/11/2013 12:28:11 |
![]() 3357 forum posts 112 photos 10 articles | Hi There If these designs to print 3D guns are available on the Internet, what is there to stop somone taking the design and machining it manually or CNC milling it from solid metal or am I missing something? regards David |
Paul Boscott | 08/11/2013 12:48:42 |
![]() 99 forum posts 21 photos | I am assuming that the idea is that plastic passes through security more easily |
jason udall | 08/11/2013 12:49:30 |
2032 forum posts 41 photos | Quite The principles are not even hard for a scratch build.. An automatic might be challenging but a single shot muzzle loaded smooth bore is "just" a closed pipe. . .. |
Speedy Builder5 | 08/11/2013 12:50:51 |
2878 forum posts 248 photos | David, I think the attraction is one machine does all obviating the need for a mill, lathe, drill etc. Also as we seem to be adopting digital design and CNC etc etc, one could pass a file to your local 'foundry' who printed and sintered metal pieces for you. For me, its the sintering process which for MEs could be a real boon if the price were right. BobH |
jason udall | 08/11/2013 12:51:22 |
2032 forum posts 41 photos | Plastic/ceramic knives/guns..are available off the shelf...in the case of gunns you might ask why. |
jason udall | 08/11/2013 12:53:44 |
2032 forum posts 41 photos | There are published designs for plastic steam engine. ... |
Ed Duffner | 08/11/2013 13:05:15 |
863 forum posts 104 photos | I was recently thinking about the possibilities of 3D printing for the scenic railway modeller. All the architecture and line-side accessories and so on. It could also be used for some of the very ornate castings on old steam engines and spoked loco wheels, which could save on owning and powering a small furnace. |
John Stevenson | 08/11/2013 13:05:55 |
![]() 5068 forum posts 3 photos | I can see it being just another way forward for the hobby. OK not at the moment, cost wise but think on a few years. People with more computer skills than at present, software that's far more advanced than now. One machine that doesn't need a big draughty shed with probably three times the cost of the machines invested in various tools and accessories to make the machines do what you want [ dividing heads, taps dies , etc, etc. ]
Not saying it will take over traditional model engineering but I can see it making inroads.
Lets face it 10 - 15 years ago if someone told you you could have a CNC router, mill, lathe, laser cutter and 3D printer sat on your bench without having to win a lottery you would have laughed or been burn at the stake as a heretic.
By virtue of the flat earth society dying off any new blood coming into the game has to be younger and by this selection only they will arrive with a different skill set to the departing Jerry Hat Tricks.
For years plans have been sold for making Widget 1, some even sell plans and materials like castings and bar stock.
We are literally only 6 months to 2 years away from someone selling plans and G Code for a CNC to make Widget 1. |
