terry callaghan | 16/09/2013 19:58:36 |
237 forum posts 10 photos | Hi chaps.I need a new boiler for a 7 1.2 rainhill locomotive. So far prices for a copper boiler have been around 2 to 3000 pounds for copper and around 400 less for steel. With only propane gas at home I don, t think I will have the heat needed to make one.so it looks like this loco will be display only.so my question is. Is there a less expensive way of keeping this loco rolling.michael |
Tony Pratt 1 | 16/09/2013 20:12:45 |
2319 forum posts 13 photos | I've never made a boiler but if you can aquire the skills and equipment needed building it yourself will be the cheapest way to go I would think? Tony |
Another JohnS | 16/09/2013 21:03:16 |
842 forum posts 56 photos | Terry - find the local model engineers club. Ours here do group builds for large boilers; 3-4 people helping out. Share the equipment, or borrow it. Also, borrow the expertise from others. Of course, none of our boilers are near what Helen Wirrall can produce, but they are less expensive, if more time consuming. BTW - finishing my 4th 3-1/2" gauge copper boiler; all of them done with a propane torch, but my favourite tool right now is a "Turbo Torch" (Air/Acetylene) torch - you need ear plugs to work near it, but it's great. Boiler building is lots of fun, at least in my book! (my 4th is going for it's initial hydro test shortly; I need to ensure that my boiler blanking plugs don't leak this time) Another JohnS. |
WALLACE | 17/09/2013 03:33:51 |
304 forum posts 17 photos | Flamefast based in the UK do a propane burner that also has a feed of air from a low pressure blower. I've seen them on ebay plus machine tool dealers at reasonable prices. They can be run from a normal compressor but I wouldn't recomend it as they swallow huge amounts of air and at low pressure so it's very wasteful of compressor electricity ! They don't go very hot - you won't weld with them ! - but they do shove out a LOT of heat for aything big. They roar like a rocket engine - I actually use ear defenders when I fire mine up. Safer than oxy acetylene and no nasty rental changes. ... certainly a useful bit of kit. W. Edited By WALLACE on 17/09/2013 03:37:44 |
julian atkins | 17/09/2013 07:16:16 |
![]() 1285 forum posts 353 photos | building a loco boiler is the most expensive part of building a loco - it always has been if done properly. there is no point starting a loco that you intend eventually to steam and run if you are likely to fall down at the boiler building stage, or cant afford a professionally made boiler. of course you can have many happy years building a working chassis if that's your thing (not mine!) and many do. very few of us can afford a sudden outlay for a boiler - in my case it is a case of stocking up on silver solder and the copper i need over a few years. in my case i dont build locos that have boilers beyond my capabilities size and pocket wise. ive spent far more over the years on copper and silver solder than i ever have on workshop machinery! a copper boiler is worth the extra cost compared to steel IMHO for all sorts of reasons not least the fact that the loco's re-sale value is enhanced by a well made copper boiler, if ever that need arises. i should add that ive only built 3.5"g and 5"g locos. quite big enough for me! cheers, julian |
roy entwistle | 17/09/2013 11:29:49 |
1716 forum posts | I thought a hobby was supposed to be a way of getting rid of money Roy |
terry callaghan | 17/09/2013 12:43:11 |
237 forum posts 10 photos | My wife thinks its a way of wasting money.Michael |
Springbok | 19/09/2013 16:20:07 |
![]() 879 forum posts 34 photos | Well that is one way of looking at it, when I had my wooden hulled yaught, I went into a woodmerchants, in Bristol to get a few planks of teak, and on his counter was a notice I consider myself a lucky chap as my wife enjoys our club meetings and visits to the club track. |
Stub Mandrel | 19/09/2013 18:56:34 |
![]() 4318 forum posts 291 photos 1 articles | > "Wooden hull boats all have a hole in the bottom where you pour money out" The same goes for fibreglass and steel IME. Neil |
jason udall | 19/09/2013 18:59:48 |
2032 forum posts 41 photos | ..re yacht. .. Hole in the water into which one pours money S Yachting. ..to simulate sailing ( yachting)..stand in ice cold shower and tear up ten pound notes. For full experience leave window's open... |
Diane Carney | 19/09/2013 21:53:39 |
419 forum posts 11 photos | Posted by Stub Mandrel on 19/09/2013 18:56:34:
> "Wooden hull boats all have a hole in the bottom where you pour money out" The same goes for fibreglass and steel IME. Neil Sentinels are just the same, I promise you! OT: Neil, I have sent you an email which needs immediate attention please. Thanks |
fizzy | 22/09/2013 20:08:53 |
![]() 1860 forum posts 121 photos |
The huge difference between a copper boiler and a steel boiler is the price if you build it yourself in steel. You do have to be a very competent welder - indeed anything less than a very experienced preffesional welder will not only produce unsound welds, but they will leak like a sieve when under pressure. If you can get someone to weld it as a favour then you are quids in. The rule book can be interpreted in different ways regarding the apropriate qualificatons, but I have found inspectors to be happy to accepr a valid profseional NTD weld certificate, which will set you back around £70 for the test, if the chap doing the welding isnt coded. |
Clive Hartland | 22/09/2013 22:13:19 |
![]() 2929 forum posts 41 photos | My Son has just chartered a yacht at a 1000 Euros for a week, its cheaper that way and you get the chance to assess what a certain make and type of yacht would be like under actual sailing conditions rather than finding out after spending many thousands for a new yacht. In this case it was a 37ft Benatau but I found it a poor boat and rather unbalanced with a severe judder at about 6 knots which got worse as the speed increased. It would not be my choice. Clive |
