Rich2502 | 26/08/2013 21:52:04 |
83 forum posts 3 photos | I have a very expensive Makita belt sander which needs a new rubber covered aluminium drive roller, thats a £60 + part ! Any ideas on how i would re - rubber the old roller ? could you turn the OD of rubber hose if it was hot shrunk fitted onto the roller ? Could you cast it on cold or hot ?
Bazyle | 26/08/2013 22:43:29 |
![]() 6956 forum posts 229 photos | You might research companies that recover printer rollers if they still exist in this laser printer world. |
Robert Dodds | 26/08/2013 23:30:24 |
324 forum posts 63 photos | Richard, Batchelor Polyurethane http://www.polyurethanemanufacturers.co.uk/index.html have helped me in the recent past with PU tube to my dimensions. Allow for a tight fit on your roller but you should check if you need to have the roller crowned and repeat that profile on the old roller hub if it is crowned. Batchelors do offer a roller re covering service but I don;t know if you will beat £60 for a one off. Bob D |
Rich2502 | 27/08/2013 21:16:26 |
83 forum posts 3 photos | My Googling research tells me a small belt sander would do the job with the roller in the lathe at slow speed. |
Martin Kyte | 28/08/2013 09:23:03 |
![]() 3445 forum posts 62 photos | Just a thought and I know it's a plastic not a rubber but have you considered black adhesive heat shrink sleeving. It's easy to apply and cheap to buy. If it doesn't work you have not lost much. Something like this maybe:- http://onecall.farnell.com/te-connectivity-raychem/dr-25-3-16-0-sp/heat-shrink-tubing-4-749mm-id-elastomer/dp/2316787 They do all sorts of diameters so pick the correct one for yourself. regards Martin |
Martin Kyte | 28/08/2013 09:45:17 |
![]() 3445 forum posts 62 photos | Oh and I forgot. If you do recover with rubber you can bring to size with a toolpost grinder (cylindrical grinding) as per printing industry practice. Martin |
Grizzly bear | 28/08/2013 14:21:44 |
337 forum posts 8 photos | Hi Richard, Look into old inkjet printers. What size dia. & length are you after? Regards, Bear.. |
Rich2502 | 28/08/2013 21:12:19 |
83 forum posts 3 photos | i think my best bet is to put some suitable hose in boiling water and force it on the roller with my hydraulic press, then grind it down to the correct size.
i could use another belt sander against the repaired one until the rubber is the right diameter. |
Clive Hartland | 29/08/2013 09:09:08 |
![]() 2929 forum posts 41 photos | Richard, find a rubber hose to fit the rollor with enough meat to allow you to take it down to size, Glue it with contact adhesive and then set up in the lathe with a coarse stone and then grind it off to size very slowly, this will give lots of black residue so you need a suction cleaner to collect before it gets everywhere. This works because I have done it but on smaller lengths, allow trhe contact adhesive time to dry well. Clive |
Stub Mandrel | 29/08/2013 21:13:42 |
![]() 4318 forum posts 291 photos 1 articles | Don't heat your hose, cool it. Rubber contracts if heated at normal temperatures. Pull a rubber band then hold it, stretched, against you top lip. I feels cool. let it relax, and it feels warm. As rubber heats up, the long chains whirl around in such a way that they bend more and hence contract. It's avery odd material. Neil |
Rich2502 | 02/11/2013 19:06:38 |
83 forum posts 3 photos | End of story. I coated the roller in evostik sticks like s**t, and left it while i went on holiday, then i sanded it down while running on the belt sander, checking the diameter with verniers, a lathe would have helped, in any case it's back to work now, and seems like a good repair job. Saved me £60.
Pinstrip | 02/11/2013 23:30:17 |
15 forum posts 34 photos | Hi
A friend had som rubber he got from this company to cast some rubber parts for a car I belive it is possible also to make som rubber rolls with this rubebr, or to coat a roller...grind to size after.. in a Lathe or similare It is available in Soft, Medium and Hard Rubber If the rubber is usable as replacement rubber pedal cover for cars it might be strong and durable But a little costly for making small cheap parts as it cost £ 60.77 > 500gr http://www.frost.co.uk/rubber-moulding-kits.html http://www.frost.co.uk
http://www.frost.co.uk/sugru-mouldable-silicone.html
Edited By Johnny Gleden on 02/11/2013 23:30:46 Edited By Johnny Gleden on 02/11/2013 23:31:33 |
Boiler Bri | 03/11/2013 08:59:59 |
![]() 856 forum posts 212 photos | Nelson rubber roller company in Huddersfield.
Bri |
Jerry Wray | 03/11/2013 09:09:23 |
84 forum posts 4 photos | You might try Alec Tiranti, in Thatcham, they supply all sorts of moulding materials, including rubber mould making products. Their main market is craft supplies but they have all sorts of useful non-engineering things Their website is **LINK** JerryNotts
Speedy Builder5 | 03/11/2013 09:22:04 |
2878 forum posts 248 photos | Have you looked on E-Bay ? A second hand sander may give you loads of spares. |
Ian S C | 04/11/2013 09:58:48 |
![]() 7468 forum posts 230 photos | The stuff used by the chap on Stirling engine forum is "Regia ABS Latex" the container says its for making skid proof socks (as in knitted woollen, feet for the use of). Ian S C |
jason udall | 04/11/2013 10:01:54 |
2032 forum posts 41 photos | Anyone tried sugru? |
jason udall | 04/11/2013 10:03:08 |
2032 forum posts 41 photos | Or maybe the homebrew ougo? ( I think) |
