Mike Gibbs | 15/06/2013 20:01:19 |
![]() 14 forum posts | I'm getting close to finisdhing my Polly Engineering O&K "Suzanne", and need to bend the annealed copper pipes for the water and oil feeds. The pipe is ~5mm diameter, and I can only find benders down to 1/4". Any suggestions? Thanks. Mike |
Stub Mandrel | 15/06/2013 20:12:31 |
![]() 4318 forum posts 291 photos 1 articles | Bending springs, i think Chronos do them. They fit OUTSIDE the tube -at least that's how I use them. Neil |
Thor 🇳🇴 | 15/06/2013 20:23:37 |
![]() 1766 forum posts 46 photos | Hi Mike, If you want to buy one may be this will be OK? You can of course build your own tube bender. You may have to fill the tubes with salt or something before bending. This will reduce the chance of the pipe collapsing when bending. Place the tube in water after bending to dissolve the salt. Thor |
roy entwistle | 15/06/2013 20:27:10 |
1716 forum posts | Can one still get Woods Metal or Cerrobend ? Roy |
JasonB | 15/06/2013 20:30:51 |
![]() 25215 forum posts 3105 photos 1 articles | Alex Tiranti do Woods Metal
J |
1 | 15/06/2013 22:11:39 |
65 forum posts 1 photos | Chronos do a tube bender the same as the HF item in Thor's link. I have one and find it works well providing I fill the tube before bending to avoid it collapsing. I use fine dry sand and have found that crimping a couple of mm at the ends of the tube retains it OK. Jim |
Brian in OZ | 15/06/2013 23:12:29 |
63 forum posts | Hello Thor, The link to Harbor Freight is great only problem is postage to this part of the world is humongous. I can't find the plans for the small pipe bender listed in the the link you gave, guess the picture says it all, but wondering if you by chance had a copy of the plans. Regards Brian |
AndyP | 16/06/2013 00:12:57 |
189 forum posts 30 photos | Brian, Original plan on web is here , neat little bender! Andy |
Brian in OZ | 16/06/2013 02:24:43 |
63 forum posts | Thanks Andy, That is a great collection of little bits and pieces. Brian |
Thor 🇳🇴 | 16/06/2013 06:56:53 |
![]() 1766 forum posts 46 photos | Hi Brian, sorry I forgot to link to the plan, glad Andy solved that. Here's another plan for another tube bender. Roy, if you can get Woods metal that works well for filling the tubes before bending. Thor |
Speedy Builder5 | 16/06/2013 07:31:03 |
2878 forum posts 248 photos | Look on E-bay for CERROBEND - I have seen it there sometimes 12 quid a kilo - seems cheap! BobH |
Paul Lousick | 16/06/2013 09:27:08 |
2276 forum posts 801 photos | Fill tube with fine dry sand and plug both ends and heat tube where bend is required. You could also machine a groove to suit the tube and bend radius in a piece of round bar and use this as a former for bending the heated tube. Heat the former as well as the tube so heat is not sucked out while bending. |
Robin King | 16/06/2013 14:22:10 |
137 forum posts 1 photos | So as you are aware there is a problem with Colin Binnie's bender design in that you can't pull back both arms parallel to allow feeding in a straight length of tube first - I'd built it before the penny dropped! It needs redesigning with the pivot offset from the centre line of one arm/aligned with the centre line of the other so the arms fold back flat against each other. This might not be important to you depending on what form your pipework takes; otherwise there's a lot going for the simple construction. Robin |
Stub Mandrel | 16/06/2013 17:01:53 |
![]() 4318 forum posts 291 photos 1 articles | Cerro are still in business, I've driven past them: **LINK** But Cerrobend is now made by CS Alloys and imaginatively called "CS Alloys Bend" LOL! http://www.csalloys.com/products-cerrobend-alloy.html Neil Edited By Stub Mandrel on 16/06/2013 17:05:44 |
Speedy Builder5 | 16/06/2013 18:29:40 |
2878 forum posts 248 photos | When I was an apprentice, we used to bend 2" and 3" thin walled stainless tube filled with ROSIN which I believe is a product of Pine Tar. Once the tubes were bent on a hydraulic tube bender, a steel ball was 'hammered' down the tube by placing a slightly smaller ball or two behind it and shaking them down. Rosin can be found in musical instrument shops for treating violin bow strings. Once heated, it melts and flows like syrup, going hard when cold. For smaller tubes, we used CERROBEND. A bit of a laugh to saw a teaspoon in half and join the two halves with a bit of cerrobend, and slip them into the mug on the tea trolley. Sit back and wait for the rude remarks !! Life were fun then. |
The Merry Miller | 22/06/2013 17:01:55 |
![]() 484 forum posts 97 photos |
Mike, I came away from the "Hobbies" shop in Norfolk yesterday with a 2013 catalogue. In it were a set of pipe/tube bending springs (external type). They are in sets of five and will bend from 3/16" O.D. down to 1/16" O.D. Price for the set is £3.85 Their website is: www.alwayshobbies.com. As most of us oldies know, Hobbies have been going for many, many years and the Hobbies annual used to be a longed for birthday or Christmas present. Len.
Mike Gibbs | 24/06/2013 08:39:29 |
![]() 14 forum posts | Many thanks everyone. I have purchased the Chronos bending toll, and a set of pipe bending sprinmgs from the same source. Practice on some brass tube has generated perfectly bent pipe. Today it will be the copper pipes! |
