Are your cap head/grub screws filling with swarf?
How to stop it happening!
OuBallie16/05/2013 10:23:52
1181 forum posts
669 photos
Honourable people, I salute you.
Are you being plagued with the cap head/grub screws on your worthy machines filling up with swarf?
Fear not desperate souls, for there is a perfect solution, to his problem, at hand!
Serious mode/
Fill them with silicone sealer, leaving a tale so as to be able to pull the plug out as and when needed.
They work a treat and reusable to boot.
Done this on my BH600G, after my experience with my V10P cap heads filling up with swarf, and then searching for an implement to dig the stuff out.
It bugged me beyond belief at the time.
Idea courtesy Martin P on uk.rec.models.engineering
/Serious mode
Geoff - New T-nut & stud awaiting delivery of a die to finish off. (never done screw cutting using lathe)
_Paul_16/05/2013 11:17:08
543 forum posts
31 photos
Why not just blow them out with an airline?
Paul
GaryM16/05/2013 11:23:44
314 forum posts
44 photos
Sounds like an idea worth trying. Alternatively you can fill them with grease. I use this on allen bolts on my bikes.
Gary
Gordon W16/05/2013 11:37:51
2011 forum posts
Good idea, would a wire "stalk" help? I've got some plastic rods of different sizes ,roughly hex in section, these can be cut into short lengths and stuck in a near size hole. They were originally meant for plugs in stone walls, for which they are useless. Also I have an old foot pump fitted with a suzy and a bit of small bore pipe, this is ideal for blowing out, chuck cleaning etc. Watch your eyes . PS Suzy is coiled plastic tube as found on HGV tractor units.
SteveW16/05/2013 11:51:24
140 forum posts
11 photos
Sounds like a good idea. I dislike any blowing of swarf esp brass - tends to get places I can't seedisgust
roy entwistle16/05/2013 12:03:20
1716 forum posts
I have tried to get 1/4 Whit x 3/4 long square headed set screws for my toolposts No luck so far I want a dozen if anyone has any ideas i'd be pleased otherwise I think i'm going to have to get some key steel and make my own
Roy
Jo16/05/2013 12:04:57
198 forum posts
I stick a piece of sellotape over the cap head screws on my tools etc.
Jo
David Jupp16/05/2013 12:17:22
978 forum posts
26 photos
If using the Silicone sealant method - be aware that most of these sealants evolve acetic acid during curing, which can lead to rusting.
Suggest only using on non-critical (or protected) surfaces.
If you look hard you can find 'neutral cure' Silicones (typically used in electronics).
Boiler Bri16/05/2013 12:44:49
856 forum posts
212 photos
I use the silicone method. never had a problem with rust either.
Such fun!!!!!
Ian S C16/05/2013 14:50:53
7468 forum posts
230 photos
I use a Dick Smith desoldering tool, those who live in NZ, or Austrailia will know these as a rubber bulb with a Teflon tip, normal use squeaze bulb, tip next to molten solder, let go, solder gone, but just as good as a blower. Ian S C
Thor 🇳🇴16/05/2013 15:02:08
1766 forum posts
46 photos
Well I get swarf in cap head/grub screws (and every place else), so silicone sealer is something I must try. Is it necessary to oil the inside first so it is possible to extract the plug?
Thor
Les Jones 116/05/2013 17:11:58
2292 forum posts
159 photos
Hot melt glue from a glue gun may also work if it contracts enough when it cools.
Les.
Alex Hapgood16/05/2013 17:43:59
7 forum posts
I have seen hot melt glue to set a zero clearance insert in a table saw. The area where the glue was to set was first coated with wax then the glue was place in the four spots, let cool a little, then the insert was placed in the still soft glue. The insert was leveled with the table top and after a minute or so the insert was removed leaving the glue attached to the insert with perfect alignment next time it was used. I haven't tried it but a spray on, dry lubricant should also work. As mentioned above silicone does pose a problem in relation to the acid but only while curing. These holes and screws are usually coated with oil or can be, so that would be a barrier to the acid released while the silicone cured.
Alex
S.D.L.16/05/2013 18:31:38
236 forum posts
37 photos
So how many would like a share of these to fit M5 cap head if I get a 1000 will split in 100s about £2.60 / 100 inc postage cash in envlope or paypay.
seems a simple solution
Shame they dont do 2.5mm for m5 grub screws then could get right length grub screws and cover.
Steve
Jeff Dayman16/05/2013 19:10:10
2356 forum posts
47 photos
Michael W - here's a link to square head screws. They even list metric sizes from M6 up!
These folks have darn near everything in industrial supplies and fasteners, at reasonable prices. Not sure if they ship to UK though.
I have seen some 1/4-20 sq hd setscrews recently in my local hardware store, believe it or not. Might be old stock.
The silicone-in-screwhead recess trick was the standard practice in the 1980's when GM started using Torx head screws on car brake calipers. If any rust built up in the recesses of these highly torqued screws the mechanics could not get them out. The designers compounded the sin by having the heads set in recesses in the castings so you couldn't get vise grips on the head OD either. Lovely. Anyway, mechanics soon learned to fill the screw heads with RTV silicone to keep them operable.
JD
Andrew Johnston16/05/2013 20:23:04
7061 forum posts
719 photos
I bought some square head screws for my Dickson toolholders from a UK seller on Ebay; not sure if he still lists them. As and when I need some new square head screws for my 4 way toolpost it shouldn't be beyond the wit of man to make some.
Yep, I still use a 4 way toolpost on the centre lathe, even though I've got a genuine Dickson toolpost and holders on the shelf. surprise
Andyf16/05/2013 20:32:23
392 forum posts
The non-environmentally friendly solution: a butane refill can for cigarette lighters. Insert delivery tube into SHCS or grubscrew, and press down momentarily on base of can. Sfety specs on, or eyes closed.
Andy
Bazyle16/05/2013 20:33:26
6956 forum posts
229 photos
bluetack & plasticine.
HomeUse16/05/2013 20:34:53
168 forum posts
12 photos
Hi Jeff D
Your link gives a plentifull supply of lots of goodies - ? Do they deliver to UK as they are in Atlanta ?
Jeff Dayman16/05/2013 21:28:53
2356 forum posts
47 photos
Hi HomeUse - Did you read this line in my post? "Not sure if they ship to UK though."
Those wanting items from McMaster Carr will need to enquire with them directly.
JD
