A & R Precision 'Dickson' Toolpost -- Screws Used
joegib22/04/2013 16:48:12
154 forum posts
18 photos
Hi,
I picked up one of these toolposts plus some toolholders a few weeks ago and I'm pretty happy with the kit. But, I'd like to replace the capscrews supplied with grubscrews. The screw diameter measures about 4.90mm so I assume these are M5 x 0.80mm pitch.
Unfortunately, I've mislaid my Metric screw gauge so I can't verify this. Can anyone who's already made this change confirm that the screws are indeed M5, please?
Thanks
Joe
Brian Wood22/04/2013 17:06:12
2742 forum posts
39 photos
Hello Joe,
I've just checked mine and get a good match for 0.8mm pitch.
Just a word of caution though, M5 can be mistaken for 3/16 BSF at 32 TPI; 0,8mm pitch is equivalent to 31.75 TPI and the diameters are close, so I would say older holders might be Imperial, newer will certainly be Metric
joegib22/04/2013 18:21:54
154 forum posts
18 photos
Hi Brian,
Your reply led me to look around a bit more. I gather the M5 'major diameter' is 4.91 which is more or less spot on with the A & R screw I measured. As it happens I rooted out some nominally M5 screws I'd forgotten (obtained from Lidl!). These measured 4.88mm and were a slightly more 'wiggly' fit in the toolholder. I looked up the 3/16 BSF specs following your reply and these show a major diameter of 4.763mm which would make for an even more wiggly fit. That pretty much settles the issue for me — M5 it is.
Thanks for your trouble.
Joe
Ziggar22/04/2013 19:55:05
115 forum posts
or you could just email them and ask......
JohnF22/04/2013 23:15:42
1243 forum posts
202 photos
Joe, Why are you changing to grub screws?
They are indeed 5mm and the original Myford ones are 3/16 BSF, I have both types plus some others of variouse parentage, Myford and A & R being the best by far.
Mike Poole22/04/2013 23:22:30
3676 forum posts
82 photos
2BA is another thread very close to M5x0.8. Myford use both on the ML7R cross slide adjusment and locking screws be careful not to mix them up.
Edited By Michael Poole on 22/04/2013 23:25:02
joegib23/04/2013 09:59:00
154 forum posts
18 photos
Hi gents,
Well, I've some sympathy with the view that Dickson toolposts have too many 'sticking-up bits'. When looking at DavoJ's project to make 40+ Dickson-type toolholders posted a week or so ago I was struck by how the use of grubscrews rather than capscrews neatened up the appearance of the units.
In particular, use of a capscrew as the locking screw for the height adjuster looks a bit clumsy to me — I'd rather use a grubscrew that disappears within the head of the adjuster. But I accept this is a taste and fancy thing and probably doesn't bother most people.
Joe
Mike Poole23/04/2013 13:32:14
3676 forum posts
82 photos
I find the biggest irratation with cap screws is that the socket fills with swarf, the larger sizes use square heads and don't retain swarf.
mike
David Clark 123/04/2013 15:42:15
3357 forum posts
112 photos
10 articles
Hi Michael
Fill the hexagon with a blob of plasticine,
Keeps the swarf out.
regards David
Peter Tucker23/04/2013 19:47:53
185 forum posts
Hi Michael,
I keep a piece of blu-tack secreted about my machine for cleaning swarf from places like cap screw sockets.
Peter.
Stub Mandrel23/04/2013 20:11:18
4318 forum posts
291 photos
Surely grub screws are even more vulnerable to swarf than cap screws? I can see that square topped screws would work well.
Personally I like the convenience being able to use the same 5mm long handle allen key for most machine adjustments.
Ian P23/04/2013 22:05:00
2747 forum posts
123 photos
I may as well add my 0.02p to this thread since it has long since answered the original question. I think the choice of screws used in quick change toolholders is partly to do with personal preferences and partly to do with what is available.
In my case I prefer the square headed bolts (5/16" UNC) but I accept that these are probably not available in 2BA or M5. I do have some toolholders with grub screws and I use those for tools that never need to be changed (indexable tips/parting blade etc). Because I dont have many holders the square headed bolts are a boon because they never get filled with swarf.
As regards putting plasticene in hex sockets! words nearly fail me, it falls into the 'shake and vac' category (throw stuff on the carpet and then remove it!). May as well screw a plate over the front door letterbox to stop draughts, you can always remove it when the postman comes. With Dickson type toolholders just unclamp and tip out the swarf.
Maybe someone should write an article showing how to make a set of polished brass dome topped, O ring sealed covers for protecting cap head bolts. (put in ME though as I take MEW)
I think 'sticking up bits' are what make Dickson toolpost so useful, and far less hazardous than the three (usually two) sharp tools poking out of 4 way toolposts.
Ian P
Edited By Ian Phillips on 23/04/2013 22:06:42
Lynne15/05/2013 23:52:54
117 forum posts
32 photos
A & R Precision tell me that the bore of their qctp is 16mm. The toolpost on my Myford lathe lathe is 7/16" I am puzzled why the popularity with Myford owners, or am I missing something glaringly obvious. Regards DLJ
Michael Gilligan16/05/2013 07:29:42
23121 forum posts
1360 photos
Posted by Ian Phillips on 23/04/2013 22:05:00:
... the square headed bolts are a boon because they never get filled with swarf.
... As regards putting plasticene in hex sockets! words nearly fail me
I'm with you there, Ian
An interesting "modern" alternative to Square Head might be 12 point
... I haven't yet found a UK stockist, but they are made in M5
joegib16/05/2013 07:36:18
154 forum posts
18 photos
(1) The unit is supplied with a 7/16" 'top hat' adaptor for the Myford topslide post.
(2) It's British-made, conforms to the original spec (as opposed to some of the Chinese clones) and from A & R Precision, at least, is reasonably priced.
(3) I quite liked the look of some of the American-made alternative styles but they're not generally available over here.
In the end I decided to use grubscrews for the height adjusters only.
Joe
geoff walker 124/03/2015 09:00:16
521 forum posts
217 photos
I recently bought a Dickson tool post with 4 holders from A&R precision.
All seems well until I clamp the tool holder in the tool post.
The "problem" is that it clamps too soon, nowhere near TDC on the eccentric.
The holder locks in place but it just doesn't feel right, not really secure?
Is there an optimum clamping position for an eccentric. Should it be close to TDC?
I can see a solution to the "problem", if indeed it is a problem.
Any thoughts anyone
Lambton24/03/2015 10:12:40
694 forum posts
Geoff,
If the clamp locked out too near TDC then even slight wear or stretching of the clamping system parts would mean permanently loose clamping as even going a little past TDC would be detrimental. . Over the years even genuine Dickson clamping "bolts" become a bit distorted and flare out a little. I would not worry about the situation unless tool holders become loose which being used.
Lambton24/03/2015 10:21:43
694 forum posts
Geoff,
I forgot to ask if you have spoken to A & R about your concerns if so what was their opinion.
Harry Wilkes24/03/2015 10:23:15
1613 forum posts
72 photos
Mine are the imperial ones
H
Posted by JohnF on 22/04/2013 23:15:42:
Roderick Jenkins24/03/2015 10:26:07
2376 forum posts
800 photos
Hi Geoff,
I had a similar problem with some spare holders recently purchased from A&R: the flange on the bottom of the height adjusting nut was too thick. These nuts are hardened, or at least toughened, but I managed to skim the bottom with a TC tool. I was a little disappointed . Still, they're OK now.
Rod
