M0BND | 14/04/2013 12:15:33 |
81 forum posts 9 photos | Here you can see what I am getting....
It is not good... Any advice or help would be greatfully received. Andy. |
Stub Mandrel | 14/04/2013 12:23:33 |
![]() 4318 forum posts 291 photos 1 articles | Hi Andy, We see a lot of pictures like that on this forum. First check, is the spacing of the bands the same as the pitch of the leadscrew? Neil |
M0BND | 14/04/2013 12:30:21 |
Neil. Andy. Jut seen the specs on my previous link....and I quote 'Pitches of three feed screws = 3mm'!!!! Edited By M0BND on 14/04/2013 12:35:14 |
Gray62 | 14/04/2013 13:43:33 |
1058 forum posts 16 photos | When you experience this 'banding effect' are you driving the saddle from the leadscrew or the feedshaft? as this will have a bearing on what is causing the poor surface finish. |
M0BND | 14/04/2013 13:44:08 |
81 forum posts 9 photos | Why would the lead screw have anything to do with the finish? Surely it's the feed screw below that moves the saddle or cross slide? Andy. Coalburner - I must have posted at the same time! Feedshaft is the answer. Edited By M0BND on 14/04/2013 13:45:14 Edited By M0BND on 14/04/2013 13:46:22 |
Andrew Johnston | 14/04/2013 13:48:04 |
![]() 7061 forum posts 719 photos | Andy, To follow up on your question in another thread; by worn bolt I mean that the threads were pretty much stripped, so the bolt wasn't doing much. Here's a picture of the banding I was getting on silver steel: The banding was actually a multi-start 'thread', difficult to tell how many, but certainly around 6 to 8 start. There didn't seem to be any obvious correlation between spindle or motor speed. I run from a true three phase supply, so no issues with single phase motor vibration. My lathe has a dedicated power feed shaft, so no issues with the leadscrew either. Here's a picture of the new bolts: Getting the compound slide clamped down properly cured the banding problem. Regards, Andrew |
M0BND | 14/04/2013 16:40:46 |
Thanks for showing the photos Andrew. Edited By M0BND on 14/04/2013 16:42:18 |
JA | 14/04/2013 18:03:56 |
![]() 1605 forum posts 83 photos | Andy Check the thrust washer between the lead screw and the lathe bed. If it is not flat or seated properly it will push the lead screw backwards and forwards as it rotates and you will get such as finish. You will also never cut a good thread using the lead screw. JA |
Stub Mandrel | 14/04/2013 18:37:42 |
![]() 4318 forum posts 291 photos 1 articles | Andy,
Some smaller lathes (like mine) don't have separate feedscrews and leadscrews. I see yours is a 1-ton monster with THREE 'lead feedscrews' according to the spec Neil |
M0BND | 14/04/2013 18:45:29 |
81 forum posts 9 photos | I'm not sure what the Chinese mean by three feed leadscrew? To me, this is a standard lathe set up, one lead screw, one feed screw. Lead screw is standard - possible 3mm pitch, and the feed screw is a slotted bar which as I am learning drives a keywayed gear mechanism to cross slide and saddle. I can take more photos if required to show the lathe a bit more close up than the link that I have provided. Andy. |
Andrew Johnston | 14/04/2013 19:15:37 |
I suspect the 'three lead feedscrews' is meaningless marketing guff. As far as I can see from the picture it looks pretty standard. Top is the leadscrew, middle is the drive for the saddle/cross-slide and bottom is simply a mechanical connection to the electrics to allow the spindle to be powered in forward or reverse from a convenient handle on the right hand side of the saddle. Regards, Andrew |
M0BND | 14/04/2013 19:27:35 |
Correct Andrew, exactly that. Outside diameter...
and bore... |
Lathejack | 15/04/2013 00:58:02 |
339 forum posts 337 photos | Hello Andy The problem you have was one of many faults i had with a new Warco 1330 lathe that i bought from them several years ago, and it is not uncommon. The lathe shown in your link has the same apron as mine, so i assume your lathe does too, but if not the cause may still be the same. You will find that the pitch of the banding is the same as the distance the carrage travels for every revolution of the feed shaft when longitudinal power feed is engaged. Behind the apron the feed shaft passes through a cast iron trough integral with the apron, the trough side walls are bored to support the feedshaft. Inside this trough sits the steel worm gear, with the feedshaft passing through it, and this worm meshes with and drives a bronze worm wheel above it. Two or three faults can often be found here that can cause the banding, and you may have one or more. The bores in the trough side walls can be oversize allowing the feedshaft to roll around as it rotates, taking the worm gear with it. The worm gear can also have a bore that is eccentric to its teeth, this gear can also be a sloppy fit on the feed shaft. These faults cause the worm gear to go in and out of mesh slightly with the bronze worm wheel when power feed is used, so the carrage does not travel at a constant rate. It is a little hard to imagine this having much affect on the surface finish, but it does, and can show up even worse on softer metals such as aluminium and bronze. One of my photo albums includes some of what i did to cure this problem. I also had to mount the worm gear on a mandrel and reskim the gear teeth concentric to the bore, there is not quite enough room to bore it out and bush it. It does not matter what feedrate you select, the carrage always travels the same distance per revolution of the feedshaft, so the pitch of the banding is always the same. The banding will show up more the finer the feedrate and the better the cutting tool. Hope this helps.
Edited By Lathejack on 15/04/2013 01:05:02 Edited By Lathejack on 15/04/2013 01:16:26 Edited By Lathejack on 15/04/2013 01:20:39 |
Michael Gilligan | 15/04/2013 08:03:45 |
![]() 23121 forum posts 1360 photos |
Posted by Stub Mandrel on 14/04/2013 18:37:42:
Andy,
Some smaller lathes (like mine) don't have separate feedscrews and leadscrews. I see yours is a 1-ton monster with THREE 'lead feedscrews' according to the spec Neil . Neil, ... looking at that spec sheet I suggest that | Pitches of three feed leadscrews | 3 mm | should read | Pitch of the feed leadscrew | 3 mm |
We can probably blame the "Grammar Checker" ... I'm sure mine would make a mess of Chinese Grammar ! MichaelG. |
Ian S C | 15/04/2013 14:52:12 |
![]() 7468 forum posts 230 photos | There is another thread on this subject. a year or two ago, but I can not find it. There was an item in ME a few (10 / 15)years ago, the cure was to isolate the motor from the lathe(motor mounted on back of the bed) with thick rubber sheet, and the bolt holes bushed with rubber tube. Also the V belts were replaced with link type belting. My own lathe does produce banding from time to time, I'v got the link belts, but have not got round to doing the rest. Ian S C |
Stub Mandrel | 15/04/2013 21:34:40 |
![]() 4318 forum posts 291 photos 1 articles | Michael/Andy, I think the clue is the geared arrangement for the cross slide. So screwcutting leadscrew and feedscrews for saddle AND cross slide, so that's three! Neil |
Andrew Johnston | 15/04/2013 22:26:30 |
![]() 7061 forum posts 719 photos | It's normal for the saddle and cross slide power feeds to be driven off the same feedscrew. A selector on the apron is used to select sliding or cross feed. Regards, Andrew |
Stub Mandrel | 16/04/2013 21:51:36 |
![]() 4318 forum posts 291 photos 1 articles | I don't disagree Andrew, i just think that's how they get to '3'! Neil
