which ones
petro1head | 09/04/2013 11:07:29 |
![]() 984 forum posts 207 photos | Hi Have a Myford ML7 and need to buy some decnt turning tools. Should I be buying HSS or Indexing, pross and cons? Also which size, the toolpost has a 25mm base on it |
Nobby | 09/04/2013 11:25:47 |
![]() 587 forum posts 113 photos |
Hi Nobby |
petro1head | 09/04/2013 11:30:18 |
![]() 984 forum posts 207 photos | Hi To get the blue one ctr I need a small bit of packing. Are you saying that if I measure the tool with the packing that,s the size I would need |
Ian P | 09/04/2013 11:34:21 |
![]() 2747 forum posts 123 photos | If your main requirement is buying decent tools, buying them from a reputable supplier should ensure good quality. You are in luck if you are asking for someone to advise you which type of tooling to go for. It just so happens by some fortuitous chance this very subject has been mentioned before. Just do a search on this the forum.
IanP |
Nobby | 09/04/2013 11:52:48 |
Hi Nobby |
petro1head | 09/04/2013 11:59:58 |
![]() 984 forum posts 207 photos | So having a quick look it seems that its best to start with HSS, that was I will also learn about how to grind them. So I just need to know what size to go for. It may be nessessary to but a adjustable height quick change tool post, any suggestions as to which one Edited By petro1head on 09/04/2013 12:07:41 |
Ian S C | 09/04/2013 12:48:38 |
![]() 7468 forum posts 230 photos | !/4" HSS tooling in a tool holder would cover most of your machining, the tool holder holds the tool in a sq hole at an angle of about 15*, I have 3 of them One left, one right, and the other a straight one, by moving the tool in or out of the holder you either raise or lower the hight of the cutting edge. I'v got some bigger bits of HSS that just get clamped in the tool post with packing. Ian S C |
chris stephens | 09/04/2013 14:39:31 |
1049 forum posts 1 photos | Hi Petrolhead, The other alternative is to get or make a tangential tool, it will do 80/90% of your turning (well it does most of my turning and facing) and getting it on centre is a doddle. As for sharpening, no other tool is as easy to learn how to get it right first time every time, a beginners delight. It is very economic to use as it uses HSS, especially economic if it saves you going down the carbide route thinking it will save you time learning to sharpen. Keep carbide for really tough or awkward materials where they come into their own, at least they do in a home shop environment, industry is a whole other game. We may all secretly aspire to being professionals but being amateurs we don't have to worry about milliseconds on each job, so HSS is usually good enough. chriStephens |
Bazyle | 09/04/2013 15:55:21 |
![]() 6956 forum posts 229 photos | As Nobby says that 3/8 is suitable for a Myford I'd just get a 4 in length and make a different shape on each end. No need to get precious about special shapes as a basic knife tool (which is nothing like a knife) will both turn and face and chamfer so you only need to grind the other end when you find something you really can't do with what you've got. The usual suppliers do simple parting tools. Don't get seduced by fancy inserted tip ones as they are so wide every cut costs a fiver in wasted metal these days. There are a few websites with info on making tangential tool holders so as you have a milling machine you could consider that as a small learning project. Find bits of aluminium for your packing. steel gets magnetised and grows swarf fur.
John Hinkley | 09/04/2013 16:07:34 |
![]() 1545 forum posts 484 photos | Looks like you're sorted as far as suitable tooling is concerned. If I were you, though, I'd next turn my attention to whatever you used to measure the base. Unless your lathe is really massive, that looks a lot less than 25.7mm to me! (I have both carbide and HSS as well as a tangential tool holder. The latter is by far the most versatile and easy to use for a beginner like me.) John
petro1head | 09/04/2013 21:50:20 |
![]() 984 forum posts 207 photos | Your so right the tool is 10mm and the base is 5.75mm, dooh |
John C | 09/04/2013 22:01:26 |
273 forum posts 95 photos |
I'm with chris S on this - get or make a tangential holder. If you want to buy one don't be put off by the price - you could easily pay more in inserts for index tools! A well know supplier with a UK outlet no longer advertises on this site, but can be found on Harold Hall's 'Model Engineering Website' . Their advert is not placed centrally. Rgds, John |
Nobby | 09/04/2013 22:25:21 |
Carry on turning Nobby Edited By Nobby on 09/04/2013 22:27:55 |
petro1head | 09/04/2013 22:36:19 |
![]() 984 forum posts 207 photos | Hi Nobby, what's the difference between a roughing and finishing tool |
Nobby | 09/04/2013 22:55:15 |
Hi Nobby |
petro1head | 09/04/2013 23:34:11 |
![]() 984 forum posts 207 photos | So would a set like this be a good start http://www.warco.co.uk/high-speed-steel-tool-bits/302779-8-piece-set-high-speed-steel-ground-tools.html If not i having trouble finding somewhere to buy individual tools Edited By petro1head on 09/04/2013 23:35:13 |
chris stephens | 10/04/2013 00:54:11 |
1049 forum posts 1 photos | I'm sure they would fine for those who don't use their lathes or know what a really good finish looks like. Individual tools are ground from stock pieces of HSS, any engineering tool shop will sell you what is needed, but if possible steer clear of any marked "ch1na", the ones I have seen with those markings have shown themselves to be less than, ahem, ideal. It is not xenophobic to say buy British or from our cross pond cousins or for that matter our Euro cousins. There are some people on You tube, like "Mr. Pete222" or "Halligan142" who try to explain how to grind tools, there is also a Russian tutor but he does not yet have any subtitles which spoils things a little but worth watching all the same. Another alternative, if you can get to the SMEE HQ in south London, is to attend one of their grinding courses for a bit of personal tuition in a small group environment. If you try at home and get confused by all the different grind angles given in the books, forget them and pick an average value for rake, clearance and relief etc. All that is needed for you to start turning is a sharp edge, precise angles are far less important, no matter what material you are turning. chriStephens
petro1head | 10/04/2013 08:54:35 |
Posted by chris stephens on 10/04/2013 00:54:11:
I am not sure where the Warco ones are from however I live in newcastle upon tyne so a bit of a hike I agree that I need to get to grips with sharpening but I want to get started now so therefore want ready made tools. A a leter date I can then buy some blank tool steel and have a go myselt, that way should I flounder I still have some tool that will work |
MadMike | 10/04/2013 09:39:21 |
265 forum posts 4 photos | Try RDG or Chronos they have pre ground HSS tools. RDG are very prompt at delivering I might add. If you buy a set I would suggest that you also buy a few pieces of HSS to start grinding your own tools. The sooner you start the sooner you will be in a position to have the confidence to make all of your own. Other suppliers are available. HTH. |
Russell Eberhardt | 10/04/2013 10:44:57 |
![]() 2785 forum posts 87 photos | Don't use HSS bigger than you really need. 1/4 in should do for most ME jobs. Remember that the amount of material you need to grind away increases with the cube of the size so, for example a 3/8 tool will need more than three times the amount of material removed for a given shape than a 1/4 tool. Russell. |
