Chris Shelton | 03/03/2013 19:40:29 |
![]() 92 forum posts 46 photos | Hope this is OK to post a link for youtube http://youtu.be/bybr-4OTxgA |
Ian S C | 09/03/2013 12:46:07 |
![]() 7468 forum posts 230 photos | Hi Chris, Maybe you could pop a picture on here as well as the vidio, youtube's abit of a bind as I at least am on dial up, and it takes ages to load. Even a photo from a web cam does OK. Ian S C |
Chris Shelton | 09/03/2013 13:23:53 |
![]() 92 forum posts 46 photos | Hi Ian, hope this helps
Clive Hartland | 09/03/2013 16:08:51 |
![]() 2929 forum posts 41 photos | Thats novel, using a pressure cooker to make steam. LOL. Clive |
Ian S C | 10/03/2013 07:50:59 |
![]() 7468 forum posts 230 photos | Chris, thats great, I thought of doing that with a pressure cooker on the S9, but my sister desided she needed it more than I did, so it headed off 40 K, but you have reinforced the idea thank you. Ian S C |
HomeUse | 10/03/2013 10:30:16 |
![]() 168 forum posts 12 photos |
Just one question - "can you cook the spuds at the same time??" - great idea for kitchen mobiles |
Ian S C | 10/03/2013 11:44:22 |
![]() 7468 forum posts 230 photos | No the idea came to me from the top end, WW2 Stuart Turner two cylinder steam engine for charging radio batteries, army pressure cooker, also used for transporting the engine/generator inside it (the cooker was a little larger than Chris's one. Ian S C Edited By Ian S C on 10/03/2013 11:46:47 |
MichaelR | 10/03/2013 11:54:28 |
![]() 528 forum posts 79 photos | |
SteveW | 10/03/2013 12:09:44 |
![]() 140 forum posts 11 photos |
That is great. While I worry about if I have the right size reamer and if ENxx will be OK you make an engine and have it running. I will try and learn from what you have done - many congratulations Steve W |
Chris Shelton | 10/03/2013 12:51:18 |
![]() 92 forum posts 46 photos | Ian and Steve, I cannot take credit for this, came across while searching for something else on youtube, and thought it would be interesting to other member's. |
HomeUse | 10/03/2013 14:17:56 |
![]() 168 forum posts 12 photos | Great inovation - did see preasure cooker used to produce steam to feed into low preasure tube which was used for steaming and then bending hardwoods - that was in back garden joinery works in "Aus" They made very high quality small joinery furniture (Dolls house scale 1/12 fullsize) ?Any one else knows of use for pressure cookers (Not Food Cooking)? |
Jens Eirik Skogstad | 10/03/2013 23:22:26 |
![]() 400 forum posts 22 photos |
You can whisk the sauce with steam engine while you are pressure cooking the food.
Ian S C | 11/03/2013 13:04:41 |
![]() 7468 forum posts 230 photos | I'vnot see it done, but I'v heard the suggestion to use a coffee machine, don't know much about them, I think they have some sort of boilerin them. Ian S C |
Stub Mandrel | 11/03/2013 16:56:18 |
![]() 4318 forum posts 291 photos 1 articles | Some, but not all, cappuccino machines have a boiler. the lid contains a safety valve and there are two 'take offs'. One uses steam pressure to force hot water through the coffe, the other is a steam jet for milk frothing. The former is no use to us, but the latter is a good source of steam at a fair pressure for small engines - just put a silicon pipe over the end. They can cope with being boiled dry (having thermal cutouts) and have a design so that they cannot be over-filled, the only limitation is the relatively small water volume. I have one of these boilers, removed from its case, the only reason I haven't done anything with it yet is the need to make an (electrically) insulated container that is also waterproof. Neil |
Speedy Builder5 | 11/03/2013 18:05:47 |
2878 forum posts 248 photos | Hmmm = I wonder if an electric shower could be re-worked into a flash steam boiler ? |
V8Eng | 11/03/2013 18:40:02 |
1826 forum posts 1 photos |
I'd love to see the club Boiler Inspector's face when presented with these. I couldn't get the smiley to go at the end of my post. Edited By V8Eng on 11/03/2013 18:47:11 |
Ian S C | 12/03/2013 11:23:16 |
![]() 7468 forum posts 230 photos | Thanks for that Neil, now I know a bit more about coffee, I use a spoon of instant in the cup, have got a plunger thing for when I have that sort of coffee, the only thing I'v had to do with perk coffee was making a sort of weight thingy out of a bit of 303 stainless for my brother in law, but I'm still at a loss to know what that was for. Enough about coffee, it will keep me awake. Ian S C |
Stub Mandrel | 12/03/2013 12:08:54 |
![]() 4318 forum posts 291 photos 1 articles | I'm an expert barrista.I usually drink tea instead of coffee because of the effect on my waterworks, but my wife insists on a fresh cappuccino every morning! Neil |
