Michael Gilligan | 19/02/2013 10:49:58 |
![]() 23121 forum posts 1360 photos | Very useful summary Thanks for posting MichaelG. |
Thor 🇳🇴 | 19/02/2013 12:05:57 |
![]() 1766 forum posts 46 photos | Hi Michael W, thanks for the thorough explanation, much appreciated. Rergards Thor |
Stub Mandrel | 19/02/2013 20:58:25 |
![]() 4318 forum posts 291 photos 1 articles | Wow, that's really interesting. The picture helps too. Thanks Michael. Now I get the method I can also see how to make a 60 degree 'square' with three buttons and a 30 degree one with four, arranged in a diamond, then removing one button. This could be the raw material of a useful artilc]e for one of the mags? Neil
Michael Gilligan | 19/02/2013 22:53:29 |
![]() 23121 forum posts 1360 photos | Of course [at the limit] the difficulty comes in Michael's first instruction; "Make some identical rollers". I am certain that Michael is perfectly aware of this; and in no way does it detract from the elegant method ... but [if striving for perfection] it is worth recognising. MichaelG.
Harold Hall 1 | 21/02/2013 10:11:55 |
418 forum posts 4 photos | Thanks Michael (W) very interesting! Initially, I had a problem making sense of number 4 but eventually it clicked, brain not as agile as it once was. I think though I will stick with what I call " Workshop Grade Cylindrical Squares" I am sure most will know, but for those that do not. Builders have in the past used three bars screwed together with distances between the screws probably being 3, 4 and 5 feet. I used the method when setting out walls in a new garden. For the mathematically minded 5, 12 and 13 also produces a perfect square, but of course much less practical. Harold Edited By Harold Hall 1 on 21/02/2013 10:15:53 |
Andrew Johnston | 21/02/2013 11:11:02 |
![]() 7061 forum posts 719 photos | Errr, I think that a number that is a perfect square is an integer that is a square of an integer, not related to right angle triangles. A right angle triangle where all the sides are integers is a Pythagorean triangle, and the integers that represent the three sides form a Pythagorean triple. Euclid's formula can be used to generate Pythagorean triples, given two postive non-equal integers. Regards, Andrew |
The Merry Miller | 21/02/2013 11:25:25 |
![]() 484 forum posts 97 photos |
That makes it all very clear now!!! Len. P.
Edited By The Merry Miller on 21/02/2013 11:25:43 |
Gordon W | 21/02/2013 11:42:58 |
2011 forum posts | Or :- the square on the hypotenuse equals the sum of the squares on the other two sides. |
Bazyle | 21/02/2013 12:59:03 |
![]() 6956 forum posts 229 photos | Doesn't making item (4) assume your cross slide is accuately at 90 to the bed which is won't be. The making of a cylindrical square in a trued up lathe specificly avoids that assumption as only the outermost rim touches the surface plate. 'Good enough for me'. I use a spacer from a horizontal arbor. Seems to have been made quite good and square to avoid introducing bend into the aerbor when clamped up. |
Michael Gilligan | 21/02/2013 13:14:45 |
Posted by Harold Hall 1 on 21/02/2013 10:11:55:
I am sure most will know, but for those that do not. Builders have in the past used three bars screwed together with distances between the screws probably being 3, 4 and 5 feet. I used the method when setting out walls in a new garden. For the mathematically minded 5, 12 and 13 also produces a perfect square, but of course much less practical. Harold . The real beauty of 3 4 5 is that [to Builders' tolerances] you can set out a right angle with nothing more than a piece of string. ... No need for any measuring instruments at all. Take a suitable length of string [maybe the full length of your proposed building] Fold it in half, then quarters; marking each fold. You now have something four units long, which can be used to "measure" strings of 3 and 5. .... Further investigation along the same lines will give you the Golden Ratio. Divine Proportion = Expediency ? : Let's Discuss MichaelG.
Joseph Ramon | 21/02/2013 13:21:36 |
![]() 107 forum posts | The squirrel on the hippopotamus is equal to the squirrels on the other two lions. Joey Well, it was all getting a bit too highbrow. |
Harold Hall 1 | 21/02/2013 15:03:09 |
418 forum posts 4 photos | I must remember the string method Michael (G) next time I lay out a brand new garden on a hillside, but that is unlikely. Too old now to even contemplate it on the flat. Sorry to say you final comment leaves me standing, will have to leave it at that. Joseph. Your translation of Pythagoras's Theorem is new to me, like it. Actually, my wife was only saying this morning that we had not seen the squirrels in our garden for a couple of months, I can now tell here were they have gone. Harold |
Trevor Drabble | 21/02/2013 16:26:57 |
![]() 339 forum posts 7 photos | For those who have reservations about their machine ability, may I suggest alternative sources of accurately machined bar such as the use of rollers from a roller bearing or silver steel or precision ground mild steel. All above may be obtained fairly cheaply if one is prepared to shop around for obsolete or odd-sized stock or even bar ends. |
jason udall | 21/02/2013 17:29:36 |
2032 forum posts 41 photos | Punch line of old joke.. " the squaw on the hippopotomus is equall to the sons of the squaws on the other two hides".. guess it was some sort of tug of (sq)war...... "kinky naughty canibals must ask zombies for supper"
pmm1 | 21/02/2013 18:24:45 |
25 forum posts 2 photos | Try coins. Old halfpennies were 1 inch diameter |
Andyf | 21/02/2013 22:33:59 |
392 forum posts | I don't know the tolerance on the diameter of the old 1/2d, Paul, but on the modern £1 coin it's 0.1mm either side of 22.5mm, so one brand new, unworn £1 might be 0.2mm or 0.008" bigger than the next. That's way outside the precision that Michael was describing in his original post. £1, £2 and "silver" UK coins wouldn't do anyway, because of their milled edges, which only leaves coppers. I suspect that tolerances on those may be wider, because vending machines, parking meters etc don't take them any more. Andy |
Michael Horner | 24/02/2013 08:53:05 |
229 forum posts 63 photos |
Now I know why they invented CNC! Cheers Michael. |
