Packmule | 27/01/2013 17:12:36 |
133 forum posts 6 photos | Just wondering if it is possible to turn" barley twists " on brass to make the familiar canopy supports on a showmans engine cheers, Bob |
JasonB | 27/01/2013 17:17:41 |
![]() 25215 forum posts 3105 photos 1 articles | I think the "tpi" would be far too great, certainly for spindle driven cutting but you may get away with driving the lead screw with a tool that has a shallow "D" shaped end and then give it all a good buff. Any reason for not buying the twisted olivers? also in the larger sizes they are tube not cut from solid Edited By JasonB on 27/01/2013 17:29:16 |
Packmule | 27/01/2013 17:24:16 |
133 forum posts 6 photos | Hi Jason, There was no particular reason ,just wondered how close you could get (or not )
JasonB | 27/01/2013 17:27:51 |
![]() 25215 forum posts 3105 photos 1 articles | I don't think the profile will look quite right, Barley twist can be done but that is not the same as a twisted square section, really depends on how much of a rivit counter is looking at the finished item.
J |
colin hawes | 27/01/2013 17:39:16 |
570 forum posts 18 photos | I would twist square bar using vice and large adjustable spanner. Colin |
Bazyle | 27/01/2013 20:57:38 |
![]() 6956 forum posts 229 photos | On a lathe once you get beyond a certain 'courseness of thread' you reverse the drive as it were and apply the drive power (ie by hand) to the leadscrew and let the gears drive the chuck round. So the gear train you are powering is a reduction. More likely to be wanted for wood turning / routing though router lathes use bits of wire wrapped round things to do it. Another technique is to use a milling machine and a universal dividing head to rotate the work as it is traversed under a suitably ball ended cutter. |
Jon | 27/01/2013 23:58:54 |
1001 forum posts 49 photos | Could make a jig up and keep pulling through by hand. Bit of wood will do, as you pull the bar back the wood of course would have to have the rotation required. Any old hss cutter will do its only brass. Once got working edge the others get easier. Barley twists as i know it are/were hammer forged. |
John Stevenson | 28/01/2013 00:17:33 |
![]() 5068 forum posts 3 photos | I was told that the ones on the showmans traction engines, which are very thin, probably only 16G, were formed by pulling a length of chain thru brass tubing. Can't see how these could be twisted being so thin or hammered |
Ian S C | 28/01/2013 11:23:56 |
![]() 7468 forum posts 230 photos | Back in my wood turning days, I used to make candle sticks with a hollow twist, mostly three bines, to do that, three helix are marked out along, and around the cylinder, then with the cylinder on V blocks, use the drill press to drill almost half way through the diameter, then the hard work starts cleaning out, and rounding the bines, at least the sold quite well at the local craft shop. Don't know if there are any hints in there. For wood there is a special lathe for forming a barley twist, haven't studied it, all strings and pullies. It is sold in a number of sizes for ornimental architecture work. Ian S C |
Bazyle | 01/02/2013 18:49:28 |
![]() 6956 forum posts 229 photos | here you go ebay listing |
Ian S C | 02/02/2013 09:33:19 |
![]() 7468 forum posts 230 photos | The last sentence I wrote above should have said that it was brass tube that is available in barley twist, also in a great many other patterns. The lathe I'm thinking of is made of four steel bars about 1.5M long and 30 mm dia. these are mounted parallel in a box form, and the top two form a guide for a router. The wooden cylinder that is being worked onis mounted between centers in the middle of the bed below the router. The center at the right hand end is turned by a hand crank, this has a pully on it with a string that is attached to the router, and as the crank is turned, the router is dragged along the bed. Its a whole lot cheaper, and simpler than the one on E-Bay. Ian S C |
RJW | 02/02/2013 09:42:28 |
343 forum posts 36 photos | Ian, it's called a 'Routerlathe', made by Trend, they get snapped up very quickly on eBay and fetch relative fortunes compared to what they originally cost! I've been looking for one for quite some time, but none ever become available within sane driving distance to me, and no one will post them due to their length (postal restrictions). John Edited By RJW on 02/02/2013 09:42:52 |
Stub Mandrel | 02/02/2013 21:12:17 |
![]() 4318 forum posts 291 photos 1 articles | Funnily enough Geoff Theasby mentions a barley twist lathe in Club Chat and shows a pic of a (tiny) table made with it. Geoff - could you let us have a few details? Neil |
Michael Gilligan | 02/02/2013 23:23:25 |
![]() 23121 forum posts 1360 photos | John [RJW] Trend provides quite a detailed, downloadable manual for the RouterLathe.
Looks like it should be possible to build something very similar MichaelG. |
John Stevenson | 02/02/2013 23:45:42 |
![]() 5068 forum posts 3 photos | Problem with the trend lathe is the distance travelled is always the same.
We used to have barley twist lathes at the piano factory but these were modified simple wood lathes and had a series of cable wheels made from plywood of different diameters.
Most of the barley twist we did were the open type for spindles in high class kitchen furniture which was a side line we did as well as piano actions. The lathes were to Taiwanese round bed wood lathes as brought into the UK by Poole Wood Equipment, since wound up.
JasonB | 03/02/2013 07:42:58 |
![]() 25215 forum posts 3105 photos 1 articles | A better version of the Router Lathe is the American Legacy ornamental mill, does far more intricate and complicated work.
Ian S C | 03/02/2013 09:17:35 |
![]() 7468 forum posts 230 photos | I'll post a photo over the next day or so in my gallery. I'm sure something like that could be made as an attachment for a millimg machine, or as a seperate machine. Ian S C |
RJW | 03/02/2013 09:43:49 |
Years ago I started to make a routerlathe, but life got in the way and it never happened,
If you can find one, possibly from an ex WD or machinery dealer etc, they have 3 alloy pulleys plus a larger one with a helical cut groove, the cable was under spring tension and the arrangement allowed the square to be pushed up and down the table and retain parallel travel, John Edited By RJW on 03/02/2013 09:45:53 |
Geoff Theasby | 03/02/2013 10:28:56 |
615 forum posts 21 photos | Hi Stub Mandrel, Sorry, I know very little more than I put in my column. Have a look at the club's website, or contact the club to get in touch with Peter Downes. Regards Geoff Theasby |
Stub Mandrel | 03/02/2013 11:05:27 |
![]() 4318 forum posts 291 photos 1 articles | Thanks Geoff, My interest is purely theoretical at the moment, but it might help Bob if he follows this up. Neil |
