Ed Duffner | 18/01/2013 16:42:21 |
863 forum posts 104 photos | Peco Setrack 1:1 scale? or part of the Hadron Collider? |
JasonB | 18/01/2013 16:58:27 |
![]() 25215 forum posts 3105 photos 1 articles | I sould think the decimal points were missing maybe it should be 6.000" +- 0.002" |
Durhambuilder | 18/01/2013 17:08:13 |
77 forum posts 5 photos | Hmm, doesn't necessarily need to be a complete circle, it could be a short arc? |
Martin W | 18/01/2013 17:31:15 |
940 forum posts 30 photos | How about something like plates for a large fuel storage tank or a piece of railway track. Where they will finalise the diameter/radius on site by pulling into final shape. |
Stub Mandrel | 18/01/2013 17:33:41 |
![]() 4318 forum posts 291 photos 1 articles | Something like a point frog? 500 feet +/- quite a lot sounds like the spec for full size rail radius. Neil |
jason udall | 19/01/2013 00:40:46 |
2032 forum posts 41 photos |
Moderate sized....?say 12"long .so approx 2 milli radians 0.1 degree or 6 minutes......or somthing like 3 thou on 6 "(3 thou each end of 12" I have programmed such radii to compensate for "barrel"shapes in journals...
6000+/-200...seems a realistic Toll...in percentage terms... I have had (automotive production) drawings such that a drawn feature may disapear if other dimensions are at the extreem of their tolerence...(think three lengths ....over all. and two lengths in from opposing ends).... I sometimes wonder if anyone reads these before issue.
_Paul_ | 19/01/2013 00:50:10 |
![]() 543 forum posts 31 photos | Modest size, simple & part of an aero engine..... could it be the curvature of a rocker arm? or perhaps the prop boss? |
Stovepipe | 19/01/2013 09:19:41 |
196 forum posts | Looking at Argos website yesterday - a "Dremel" accessory set, weight 450 KG. Blimey, some accessory ! Dennis
Ed Duffner | 19/01/2013 13:52:50 |
Posted by MICHAEL WILLIAMS on 19/01/2013 09:11:47:
Hi Jason , Close enough ! The pins and journals on some Bristol radials were crowned to reduce local stresses . 6000 inches +/- 200 inches was a typical value . Don't know what the good component yield percentage was in manufacture but they would certainly have been inspected and approved/rejected individually . Regards , Michael Williams Edited By MICHAEL WILLIAMS on 19/01/2013 09:19:32
But how would you go about checking this tolerance? Isn't it more sensible to reduce the figures to workable/measurable values? |
Phil P | 20/01/2013 19:19:44 |
851 forum posts 206 photos | I once had a mate who got sacked for being a thou out on one job. He worked in a bank at the time. Phil |
jason udall | 21/01/2013 00:19:57 |
Posted by MICHAEL WILLIAMS on 20/01/2013 19:14:58:
Hi Ed , The crowning has to be of very large radius compared to the component - really its just a very slight reduction of diameter of pin (or whatever) at outer ends . The 6000 inch +/- 200 inch figures appeared on engine drawings which were done in the 1930 to 1950 period . Crowning is still very important on many engineering components but the means of specifying on drawings and means of manufacture have moved on considerably . Regards , Michael Williams .
It would be , "even" today be a near impossible dimention to check with linear 1D instruments..the "radius" would be Calculated from a cloud of 2D or 3D points.... many features today are more difficult to measure/verify than they are to generate..(both in the DO and in the factory)......
Stub Mandrel | 21/01/2013 21:13:16 |
![]() 4318 forum posts 291 photos 1 articles | Jason - how would you actually machine such a radius - some complex geometrical too to generate the radius without having a 6000 inch bar? or would you simply lap the journal concave? Neil |
jason udall | 22/01/2013 00:56:52 |
2032 forum posts 41 photos | How would I? Cnc if not ground.( or if less that 1000)
Centerless grinder from ("parallel" ) with profiled wheels if ground finish..(or more than 1000 pcs) Diamond dresser cam / former CNC generated and verified as below...
The above deals with making it..checking/inspection of 6000" radius would be the real chalenge..I would use our 2D "height" gauge and rely on mathematics to derive radius from three points.....serveral times Just how I work in the day job...
Michael Gilligan | 22/01/2013 08:06:52 |
![]() 23121 forum posts 1360 photos |
Hi Jason , Close enough ! The pins and journals on some Bristol radials were crowned to reduce local stresses . 6000 inches +/- 200 inches was a typical value . Don't know what the good component yield percentage was in manufacture but they would certainly have been inspected and approved/rejected individually . Regards , Michael Williams Edited By MICHAEL WILLIAMS on 19/01/2013 09:19:32 . It would be interesting to know a little more about these components ... Length, Diameter, Surface Finish ... Whilst I have no historical evidence to support this; I suspect that 6000" radius +/- 200" was intended to prescribe "tramlines" within which the actual shape [including its Straightness and Surface Finish] could be whatever suited the manufacturing process. Jason's expert description shows how he would make it now; I remain intrigued by how they would have done it in the 1930s MichaelG. . P.S. Whilst browsing, I just found this eBook about the Packard Diesel Radial.
Edited By Michael Gilligan on 22/01/2013 08:32:40 |
jason udall | 22/01/2013 10:20:42 |
2032 forum posts 41 photos | in 30's... either centerless or between center grinding .
As to measuring it....well in production I would expect 3 "snap" mikes or dial indicators ( I have 1/10,000 " clocks in my collection...) ...mounted in fixture controlling/fixing the postion along the part..... but I would be guessing... |
Andrew Johnston | 22/01/2013 11:50:06 |
![]() 7061 forum posts 719 photos | Hmmmm, if I've got my calculations right, and assuming the journal is 2" wide, I make that a difference of 0.000083" on the radius. In other words less than a 10th of a thou. The tolerance variation would be rather smaller. Under wartime pressures to get engines off the production line I suspect it may have been quietly ignored, plus a certain amount of muttering by machinists about draughtsmen who came up with the tolerance in the first place. Regards, Andrew |
jason udall | 22/01/2013 12:47:34 |
Posted by Andrew Johnston on 22/01/2013 11:50:06:
Quite... inspection would be challenging
Joseph Ramon | 22/01/2013 13:08:51 |
![]() 107 forum posts | Perhaps just hand held emery to relieve the centre would do the job. Joey |
Michael Gilligan | 22/01/2013 23:55:43 |
Posted by MICHAEL WILLIAMS on 22/01/2013 23:27:59:
Quick and often used ' workshop ' test for crowning is to spin component on glass (barrel wise ) . If it spins freely crowning is present and probably adequate . Michael Williams .
Thanks ... I will remember that one! Bound to come in useful sometime. MichaelG. |
mick | 23/01/2013 11:27:33 |
421 forum posts 49 photos | Back when god was a boy I was shown a method of checking very large diameters with a suitable steel bar with points turned at either end. One end was held on the bottom ID while the point on the other end was arched across until it touched one side of the ID and a chalk mark made, it was then arched to touch the opposite side of the ID and another chalk mark made. The diameter could then be calculated to a few thousandths of inch by triangulation. |
