mick | 17/11/2012 12:03:29 |
421 forum posts 49 photos | Doe's anyone know of a supplier who stocks 1/16th BSP taps and dies, as an on-line search hasn't produced anything smaller than 1/8th having just bought five elbows that are threaded 1/16th BSP I really to able to screw one end of each elbow into different parts of a crank case in order to produce a lubrication system. Thanks in anticipation. |
KWIL | 17/11/2012 12:14:04 |
3681 forum posts 70 photos | Cromwell Tools sell 1/16" BSP taps (but not apparently dies) |
John Stevenson | 17/11/2012 12:28:53 |
![]() 5068 forum posts 3 photos |
And a bargain at £30 |
roy entwistle | 17/11/2012 15:50:10 |
1716 forum posts | Mick try Tracey Tools in thier catalogue they are about £5 each |
mick | 17/11/2012 16:10:40 |
421 forum posts 49 photos | Hi. roy. Their on-line catalogue doesn't list any 1/16'' BSP taps or dies, but I've sent them an e-mail so I should know on Monday, thanks for the info. |
KWIL | 17/11/2012 16:33:34 |
3681 forum posts 70 photos | Roy, Where did you find 1/16" BSP in Tracy Tools cat, not in my Winter 2012 paper catalogue nor on their web as far as I can see? |
NJH | 17/11/2012 17:21:39 |
![]() 2314 forum posts 139 photos | Can't see them in the Winter 2010 Cat either. Hope you're lucky on Monday Mick |
Steve Withnell | 17/11/2012 17:30:15 |
![]() 858 forum posts 215 photos | Can you not re-cut the threads to something a liitle more common? (Or as I did, solder the buggers on)
Steve |
roy entwistle | 17/11/2012 19:28:15 |
1716 forum posts | sorry guys my catalogue is 2008 i just assumed they still did bsp taps 7 dies that size |
roy entwistle | 17/11/2012 20:49:08 |
1716 forum posts | Appologies again I must have been having a senior moment ( at 78 I get one or two) it seems that 1/8 bsp is the smallest size This I have just confirmed by Machinery Handbook and Zeus |
JasonB | 17/11/2012 21:03:08 |
![]() 25215 forum posts 3105 photos 1 articles | Although Tracy don't list 1/16 BSP they do list 5/16"x28 which is the same pitch, thread angle (Whit form)and only 0.008" larger than the BSP which may do the job.
J |
Trevor Drabble | 17/11/2012 21:05:31 |
![]() 339 forum posts 7 photos | Mick, Have just seen an advert in one of the vintage steam mags for a company who may be able to help. They claim any tap,any die, any thread. Contact details are 01454 324564 or www.avontapdie.co.uk Hope you will find this info of help. Trevor |
Ian S C | 18/11/2012 10:00:58 |
![]() 7468 forum posts 230 photos | Did'nt think there was 1/16" bsp, but looked it up, and on one site it showed 1/8" to 2" bsp, then the next page same site, it showed 1/16"bsp, pipe OD .304, 28 tpi, tapping size 6.6 mm/ Letter G drill. Also shown on Wikipedia BSP theads. Ian S C |
KWIL | 18/11/2012 10:27:01 |
3681 forum posts 70 photos | Machinery's Handbook 27th Ed (2004) clearly shows 1/16" BSP as being part of BS 21:1973 |
KWIL | 18/11/2012 10:29:09 |
3681 forum posts 70 photos | Trevor, if you visit avontapdie.co.uk you will see their BSP taps start at 1/8" BSP |
JasonB | 18/11/2012 13:28:32 |
![]() 25215 forum posts 3105 photos 1 articles | The other alternative is to by unmachined elbows which allows you to thread them with whatever you have to hand - 5/16x40 or 5/16x32 is what I use and always keep a few elbows in stock
martin perman | 18/11/2012 14:40:53 |
![]() 2095 forum posts 75 photos | Gentlemen, I stand corrected if I'm wrong but would it not be possible to make your own tap and die out of say Silver Steel suitably heat treated afterwards. Martin P
Ian S C | 19/11/2012 11:26:01 |
![]() 7468 forum posts 230 photos | I,m doing a recovery job on a Stuart Turner S9, the drain cocks are threaded 5/32 ME, 40 TPI, the oilers on the main, and big end bearings look like 3/16 ME. The inlet, and exhaust flanges are also ME thread. ME or any fine thread, ie., UNEF would be ideal for the little stuff. Ian S C |
mick | 19/11/2012 12:30:27 |
421 forum posts 49 photos | Been quoted £25.0 + VAT + P&P Tracey tools £30.0 + VAT + P&P from another supplier. Remembered CTC Just ordered two 1/16th BSP taps + insured air mail from Hong Kong for $13.49 !!!!!!!!!!!!!!! I can wait the seven days it usually takes to come half way round the world |
