Ba studs
Where from
Dusty23/10/2012 19:02:02
498 forum posts
9 photos
I have the need for a number of 6BA studs of varying lengths. I have searched for it seems hours on tinternet for a source, without any luck apart from 1" length. I do not want to use studding (allthread). I cannot even buy material to make them without turning the blank stud first, which due to the number is not an option (well not if I want finish the project before i get to wear a wooden overcoat). Any ideas gents.
Maurice23/10/2012 19:09:20
469 forum posts
50 photos
You could ask Stuart Turner where they source the studs used in their engine kits, although the new owners are very busy at the moment, sorting everything out.
JasonB23/10/2012 19:19:12
Or Ask Andrew if you can borrow his new repetition lathesmile p
JasonB23/10/2012 19:31:53
Just looking at EKP I see they sell 7/64th steel rod so that saves having to machine it down to size.
J
NJH23/10/2012 19:43:27
2314 forum posts
139 photos
Dusty
I sympathise! I had need of some 8BA studs a while ago and had to resort to making them - I didn't have the right sized rod either but Idid have one of these. It worked well but then there is the problem of getting them all the same length.....and finishing the ends......I only needed about 20 but if you need lots............sad
Norman
Kevin Bennett23/10/2012 19:43:42
193 forum posts
56 photos
Hi i found this on eBay 6BA Steel Threaded Bar - Rod Studding - 6 BA - 6" or 12" Length
Item number: 280879919196
ty Kevin
Charlie,23/10/2012 20:25:04
76 forum posts
Hi Dusty
GLR Distributors do BA studding, Find them in the last issue of MEW,
JasonB23/10/2012 20:36:18
Dusty did say that he DID NOT want to use studding but proper studs - rod threaded at each end.
J
Phil P23/10/2012 20:51:12
851 forum posts
206 photos
A small Coventry die-head should be on your Christmas list.
Makes a much better job of studs than split dies ever could.
Phil
Colin G23/10/2012 21:26:19
25 forum posts
Try Mark at [email protected] He will make small quantities, maybe he has the
raw material to sell?
Colin
David Clark 123/10/2012 21:27:18
3357 forum posts
112 photos
10 articles
Hi There
For studs.
Try Items mail order.
I don't have contact details but a Google search will probably find them.
regards David
fizzy24/10/2012 00:22:36
1860 forum posts
121 photos
joe sells them at maccmodels
Dusty24/10/2012 08:50:43
498 forum posts
9 photos
Thanks Guys
Jason, I had completly missed EKP, looked everwhere else. Have ordered a few lengths will have some 'in the stores' for future use now.
The Forum comes to the rescue again.
Terryd24/10/2012 10:24:49
1946 forum posts
179 photos
Nice one Jason,
I see that they sell studs as well - that's one to bookmark
Best regards
Terry
JasonB24/10/2012 12:37:57
I had assumed Dusty tried EKP as he said that he had found 1" long studs but just thought he may have missed the raw material.
As they make the fixings for the majority of the ME suppliers they are my first place to look.
I do try to make the studs as I go along which helps prevent that massive amount at the end of a project.
J
Paul Clapham25/10/2012 05:19:16
19 forum posts
Dusty try ba-bolts.co.uk these have a fair selection of bolts, you might be able to get bolts the correct size and then remove the heads and you only have to thread one end.
Regards Paul.
AES25/10/2012 09:19:05
85 forum posts
@Dusty,
Try **LINK**
Though this company is primarily model oriented (aircraft, helicopters, etc) they have a surprisingly large range of "other" stuff, inc BA bolts & machine screws in stainless & brass. Not sure about studding but worth a check. Based on my own experience as a satisfied customer, very reliable & efficient.
Usual disclaimers.
AES
Edited By AES on 25/10/2012 09:19:50
Doubletop25/10/2012 10:22:07
439 forum posts
4 photos
Try Mark at BA Bolts
[email protected]
He appears to make to order "Just waiting for one of the items on your order, machine will be free later on today to make these small bolts" so just ask and see what he can do for you.
Pete
Dusty26/10/2012 18:05:54
498 forum posts
9 photos
Many thanks to all of you that have contributed to this thread. I now have the raw material to produce my own, as much as I would like to purchase the studs, those who manufacture such would I am sure not be too keen on producing the small numbers I want and I would not want to pay for them if they did, they are after all in buisiness to earn a living and producing 50 or so studs of varying lengths is not economic. We are talking in tens of one size a dozen of another and so on. Some of you appear to be getting confused with studding and studs, Studding is threaded all the way along its length and is not suitable for my needs whilst studs have a threaded portion at each end and the centre is full dia. Once again thank you for all your help and suggestions.
Andrew Johnston27/10/2012 10:57:03
7061 forum posts
719 photos
Posted by JasonB on 23/10/2012 19:19:12:
Oeeeer, I don't think you can get Coventry die sets that small. The smallest I've seen is 10BA, for a 1/4" diehead. The Britan did come with adaptors for conventional split dies and taps. The adaptors are quite clever, they rotate freely once the thread depth is achieved, but when the spindle is reversed they lock up and back the die/tap out. I guess the main problem with threads this small is stripping of the thread during manufacture. That is probably why the Coventry die sets don't go that small.
