Liam Heffernan | 06/09/2012 20:42:15 |
1 forum posts | Hey guys i have alot of spare time on my hands and am getting the urge to make somthing with my hands. I used to enjoy making models when I was younger .
I seen an add on tv for a big giant ship collect every week kind of thing but it would be very expensive to do that. I was looking at match stick builds too but not sure if thats a good way to go for first build Wheres the best place to look around for stuff to build?
Cheers |
Aestus57 | 07/09/2012 16:13:09 |
![]() 30 forum posts 2 photos | Hi Liam, If you're thinking of building model boats or ships have a look at the Model Boats Magazine or www.modelboatmayhem.co.uk forum on the web. Lots of good adviced there and a very friendly bunch too. If you're thinking about Model Engineering and steam look at Elmers Engines ( Google it!) Regards Peter |
Ady1 | 07/09/2012 16:36:07 |
![]() 6137 forum posts 893 photos | Use the netty and hunt about Big things wee things flying things static things Thanks to the netty, In the entire history of humanity, It's never been easier
http://modelenginenews.org/ http://www.ffscale.co.uk/index.htm
How about a pulse Jet engine? The neighbours will love you http://www.pulsejetengines.com/
Edited By Ady1 on 07/09/2012 16:41:14 |
Lambton | 07/09/2012 16:43:32 |
![]() 694 forum posts 2 photos | When I was a boy in South Shields 60 years ago a netty was the outside lavatory! |
Clive Hartland | 07/09/2012 22:39:20 |
![]() 2929 forum posts 41 photos | Hello Liam, First of all I would not commit to buying that ship advertised on TV, over the period of building it will cost £800 or so and would take nearly 3 years to receive all the bits and by then I would be bored !. Buy a few model mags. like model railway and Model boats and model airplanes. There is a Hobbies mag. in Smiths which is full of projects and suppliers of small tools etc. Clive
Bazyle | 07/09/2012 23:51:46 |
![]() 6956 forum posts 229 photos | If you continue to think boats have a look at the Springer section on Mayhem as linked above. This was designed as an introduction to boat building while providing a fun boat with good performance. If you can find an old fashioned drawer from a bit of furniture made out of real wood that is the ideal material - buying wood to make a springer is cheating. Maybe go along to a local club to get advice. It is only 3 weeks to the St Albans and District MES show if you are within range which would be an ideal opportunity. |
Springbok | 08/09/2012 00:15:42 |
![]() 879 forum posts 34 photos |
Hi liam, |
Wolfie | 08/09/2012 23:30:54 |
![]() 502 forum posts | There is no shame whatsoever in building a plastic kit neither. I have been doing that since I was less than 10 years old and now do it semi professionally. Its a good way to start modelling. The engineering bit comes with time. |
Ian S C | 09/09/2012 12:32:09 |
![]() 7468 forum posts 230 photos | I'v been out of the workshop for a few months with a crook leg, and am just getting back to it, so I started with something simple, a weather vane, in the form of a Cessna 185, this was the main aircraft type that I worked on, years ago. Now I'm getting back to my hot air / Stirling Engines. I don't, but you could, just to find out how they work, build one of the tin can hot air engines that you can find on the net, you then might like to build a machined version, or go to a steam/compressed air engine, plans of which may also be found on google. I started modeling by making tap wrenches, and die holders, some for sale, some to keep, and before making any models, started making parts for vintage cars, and tractors. Ian S C |
NJH | 09/09/2012 19:22:13 |
![]() 2314 forum posts 139 photos | Hi Liam I wouldn't dismiss Wolfie's suggestion of a plastic model out of hand. This can be a reasonably low cost option. Not too many tools required and reasonable assurance of a satisfactory result. It will require careful study of the plans, preparation of the parts, care with the application of adhesive and study of the techniques for good paint finishes and then the implementation of these. The level of complication in the model is down to your experience, taste and the depth of your pocket! You will learn care and patience in the process and, with care, will produce a pleasing result. You may then move on to other things but all you have learned will be of use in other diciplines. I agree with others - don't go with the "collect over the weeks" project. I've not come across anyone who has finished one. Regards Norman Good Luck! Edited By NJH on 09/09/2012 19:38:18 |
David Clark 1 | 10/09/2012 10:41:27 |
![]() 3357 forum posts 112 photos 10 articles | Hi There My sister in law did a collect over the weeks project, a dolls house. They discontinued publishing it about 2/3rds of the way through so she now has several hundred pounds worth of firewood (and lots of paper to start the fire). regards David
Edited By David Clark 1 on 10/09/2012 10:41:54 |
Ian S C | 10/09/2012 13:40:35 |
![]() 7468 forum posts 230 photos | One of the more interesting plastic models that I'v built was the Visable Radial Aircraft Engine. Stirling Engines on Google: (1) Notes on Hot Air Engines, by Robert Sier. (2) Boyd's Tin Can Stirling Hot Air Engines. (3) Lets Build Model Stirling Engines, by Koichi Hirata, this is a good site, with plans. Ian S C
Ian S C | 11/09/2012 06:11:44 |
![]() 7468 forum posts 230 photos | Got ME no., 4438 yesterday, Davids got a good start for you in that, page 376 "Junior Engineer-A vertical Oscillating Power Plant" By Tony Wright, A design and build of a little steam engine. Ian S C |
